Just a Rebar Scissor Mod
gb Offline Qubit
on: November 11, 2021, 01:20:37 PM
Finally got around to modding my Rebar with some Leatherman scissors.   I chose to lose the lanyard ring as I never use it and re-arrange the tools to fit without having to add anything to prevent tools sticking through the handles, I also put the 2 flat drivers together as I had previously discovered on my Kick I can very securely use this to put into a 1/4 bit driver.   Can then use a range of hex drivers, philips screwdrivers, torx etc.    Currently decided against a diamond file for now, that may come later.
us Offline Adam5
Re: Just a Rebar Scissor Mod
Reply #1 on: November 11, 2021, 01:38:26 PM
Personally, I think good scissors are a great upgrade for most MTs. I have gone from never using scissors to wanting them on every MT I carry.
Reply #2 on: November 11, 2021, 02:40:26 PM
Great job on the mod :tu: :like: :like:
If you haven't bought one then the LM Removable Bit Driver adapter for the square shank Phillips is also a great upgrade to carry with the Rebar :salute:
Reply #3 on: November 12, 2021, 05:48:25 AM
Nice job !    :tu:
Reply #4 on: November 12, 2021, 05:49:14 AM
Don't forget to apply for your Hacker badge   :tu:
00 Offline Dutch_Tooler
Reply #5 on: November 12, 2021, 07:59:10 AM
... and to make an entry in the Showcase thread please  :cheers:
Especially the info on the two flat drivers may help other modders  :tu:
Cheers!
Dutch_Tooler
gb Offline Qubit
Reply #6 on: November 16, 2021, 12:42:33 AM
Haven't got a LM Bit Driver adapater as yet, might not get one to use with this Rebar but will probably end up getting one anyway!  :D
gb Offline Qubit
Reply #7 on: November 16, 2021, 12:44:21 AM
Yeh, completely agree  :tu:.  I think they're a must, although I guess it depends what you're using your multitool for obviously.
gb Offline Qubit
Reply #8 on: November 16, 2021, 12:47:33 AM
Ooo, didnt know about that - will do.  Cheers  :tu:
Sure thing DT, thanks   :salute:   If someone else can benefit then great.  Must admit Ive taken to using it as one half of my torx bit holders when modding/adjusting tools that require 2, like the Wave, Multiforce etc.
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
