Charge + rebar compatability
Offline Xk6m6m5x
  • New User
on: December 11, 2021, 08:11:20 PM
New here so forgive me if i missed it, are any of the charge+ tools compatible with the rebar? I want to swap the charge serrated blade with the current rebar blade and replace the plain blade with the micro bits
Re: Charge + rebar compatability
Reply #1 on: December 11, 2021, 09:00:38 PM
Welcome to  :MTO:  :cheers: The internal Wave tools all have the same lock design as the Rebar but the outside tools are liner lock and won't work in a Rebar without lots of grinding :salute:
I do have a diamond file in a Rebar from a Wave (thanks again Steve :) ) but it required a complete reshaping and new pivot hole to be able to work otherwise the Rebar :salute:
Offline Xk6m6m5x
  • New User
Reply #2 on: December 11, 2021, 09:12:56 PM
Ill have to do some work then! Thanks
Reply #3 on: December 11, 2021, 10:39:22 PM
Yep :hatsoff: if you need any guidance we have plenty of modders here that are excellent that would answer any questions you might have to the best of their abilities  :tu:
Reply #4 on: December 11, 2021, 11:04:40 PM
 :iagree: and welcome to the forum !
