Or go with a hex bit coupler on the inline Phillips of an Explorer or Swiss Champ.
Yep, that's exactly right. You only need a champ. That's it, one and done.Oh and maybe a farmer, yup should have a farmer for sure. Oh yeah and a pioneer and maybe a huntsman. Well of course you need a rambler, and everyone needs a spartan. Now that I think about it a explorer would be handy too.....
There's one other restriction - Literally... Tight spaces. I can usually just about manage with an Explorer screwdriver at right angles, but the CT driver is sometimes too long to fit the tight spaces, especially in some SFF PCs. For this reason and the need for a wider range of bits, I tend to supplement a SAK with a ratchet set like the one from SwissTool kits. Ideally you'd have layers with both a bit driver and a ratchet driver in 6mm, but the knife would be getting pretty hefty at that point.
Yes. I think the solution to your problem is to get both. Sorry.
I think the best way is known to all of us...GET EM ALL !!
This Forum will do that to you my friend!! I started out with the Huntsman that I carried for 32 years. I found the Forum and it began. At last count I was over 50 SAKs
My son said that anyone who collects SAKs needs a Swisschamp.
As the OP of this thread jsut wanted to update...I still haven't bought another SAK since picking up the Swiss Champ. It's also Turing out to be the one I use the most.
Thanks for the update. I’m always curious if a new Champ user will fall into one of two camps…that the size is fine for carry and use. Or the other group that feels it’s just too big. Which is a legitimate concern when giving advice to others for what to carry. I fall into the former group and have no problem with ‘large’-ish SAKs. Glad you found what you needed Dr. B.
For full disclosure, I don't EDC it. It sits on my desk at home and I've found that I use it more around the house than anything else. I EDC other knives or SAK's, but honestly never really even use them.
I'm in the latter, if I'm honest, at least as far as my perspectives and experiences of what a SAK is supposed to be. The Ranger is about the ideal, while the Handyman is pushing it a bit, in the same way having a large executive car will often be...In that same analogy, a SwissChamp and other similarly sized models (Cybertool Lite) are the equivalent of driving one of those ridiculously big 4x4 pickups, just to pop to th supermarket. I do still carry my SC every day though... at least until I get a second one and mod out a couple of the least-used/useful tools.
Now that you think you have it all figured out Dr. B., I’ll tell you the real secret…Everyone needs a Champ. Maybe a Workchamp too, but I digress a bit. Then they need a mod that has all the favorites. One (perhaps regular production) mid size-ish with the most used tools. And one minimal that has the stuff you really hate being without. One that ‘pushes’ you out of your comfort zone. I’ve enjoyed reading your posts since you’ve joined. I hope you continue to have more to share!
Just get it done. What tools would you ditch?
My main problem with the SwissChamp is its width in hand while using the large blade.
Fish descaler and the pliers. I've no use for any functions on the former, and the latter just aren't as good as I'd hope, especially the wire cutter. I've already notched it from trying to cut a bit of 0.75mm electrical wire!
Not as easy as 'just doing it', as I have other expenses at the minute and I still need to get some tools - I'm geared up for wood, not metal.
That’s one knife I think Victorinox should make even if I wouldn’t get one myself. The difficulty in helping Victorinox ‘see’ it would be a good model is that it’s essentially a Champion plus without a scaler. While I don’t hate the scaler myself, I view it as the tool that hasn’t ‘pulled its own weight’ over the years.
Like this?
While I don’t hate the scaler myself, I view it as the tool that hasn’t ‘pulled its own weight’ over the years. I accept the pliers as they are. I do wish they were better as I’d would love a set that worked like Knipex.
Exactly like that!!ISTR seeing this a while ago in passing - Didn't you even settle on a name for it?
