What size brass rods to replace / add a layer to my 91mm Cellidor 352
New User Posts: 2
« on: January 13, 2022, 08:27:28 AM »
I'd like to try my hand at modding an Victorinox Sportsman,  I just want to swap out the corkscrew for a Phillips.
What size brass rods and drill bits do I nee to get?
Thanks
Paul
Full Member Posts: 227 Galaxy-hopping garbage-man
Re: What size brass rods to replace / add a layer to my 91mm Cellidor
« Reply #1 on: January 13, 2022, 10:17:59 AM »
This is a rather good starters guide:
https://forum.multitool.org/index.php/topic,9808.0.html
No Life Club Posts: 2,893
« Reply #2 on: January 13, 2022, 05:04:26 PM »
You need 2.2mm brass rod, unless you reuse the pins and do ‘open heart surgery’ like I do.
There is a guide written the needs new pin stock written here:
https://forum.multitool.org/index.php/topic,83228.msg2043063.html#msg2043063
It uses grinding to remove the entire pin head. I remove the pin so it can be reused and re-peened. Driving a new 3rd pin in the back should use a slightly tapered pin, IMO. Rounded or chamfered at the very least.
Two different 3rd pin only techniques I use either 1) do not remove any material from this rivet or 2) do not remove any pin length. Either of these techniques leave enough to re-peen the rivet and only back it out enough to replace the CS/Phillips or whatever backside tools for the intended swap like chisel and small SD, which are the same size. Those are my only hints and tips on this subject. Good luck with the swap.
New User Posts: 2
« Reply #3 on: January 13, 2022, 07:38:24 PM »
Any suggestions on where I might find these rods?  All I find is 2mm for instance...
Thanks for all the help!
Paul
Sr. Member Posts: 372
« Reply #4 on: January 13, 2022, 07:50:25 PM »
Paul
It’s a real pain to find 2.2mm brass rod; I have yet to find a good source. I normally take 2.5mm rod and grind it down until it fits through the 2.2 mm holes in the liners. It’s a crude method, but it works for me.
Current SAKs: Explorer, SwissChamp, Handyman (modded), Climber, Super Tinker, Tinker, Woodsman (modded), Electrician, Pioneer, SwissTool
Boomer Sooner!
« Reply #5 on: January 13, 2022, 09:51:11 PM »
Search the forum for 2.2mm…a source from the UK should pop up. I think the seller in Germany with Adler pin stock dried up. I haven’t seen him list the 2.2 material lately.
There’s other 2.2mm material available globally that will work too.
Full Member Posts: 122
« Reply #6 on: January 14, 2022, 11:41:05 AM »
The British cannot buy SAKs on Ebay and EBay’s shipping costs are extortionate compared to a standard USPS service, and Americans struggle to purchase 2.2mm brass rod.
Perhaps we can negotiate a mutual aid pact?
(I have some that I can send you if you get stuck).
« Last Edit: January 14, 2022, 11:48:01 AM by SAKTaschenmesser »
« Reply #7 on: January 14, 2022, 06:52:37 PM »
This is a great idea for anyone willing to do it. (Not me)
My suggestion for anyone in the states shipping to the UK is to list any items as ‘MULTITOOL’ to avoid potential issues.
I’ve considered stocking enough 2.2mm brass to distribute, but there’s no way it would be worth the effort and time for me. Whatever price I could reasonably set would just end up getting undercut by a domestic competitor. And it just got worse this year for small/home businesses and IRS reporting requirements.  :(
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $152.47
PayPal Fees: $9.67
Net Balance: $142.80
Below Goal: $157.20
January Donations
SMF 2.0.18 | SMF © 2020, Simple Machines
Page created in 0.048 seconds with 47 queries.
© 2018 Defender Web & Tool
