Spirit: Got Hooked on a Tool Addition
us Offline Outback in Idaho
on: February 09, 2022, 03:55:49 AM
  Was pulled over last night. License plate lights were out. Did not get a ticket. (Whew) This meant having to pull them lights fixtures out, which being rear ended a few years ago made things... interesting. In any case got them pulled out, found some LED light replacements I bought 2 years ago.
  [/url]
  Got one installed using the Spirit tool. The other connecter slipped up inside! :ahhh Fished around using the can opener, no bites. Tried that hook feature, pointless. Was headed inside the house for some wire when I seen this small bungee cord laying by the door. :think: I wonder...
  Was a very tight fit onto the Philips shaft! reached up in that hole, first try, got a bite! :woohoo: Pulled it out and got it mounted back in. Thinking these small hooks are going to be in my kit if I can find a place for them, as this really saved the day. Maybe I can coat them with something rubbery to prevent shorts. To remove the spring was fun. Hooked it under the bumper and gave a tug.
¬ Outback in Idaho
Re: Spirit: Got Hooked on a Tool Addition
Reply #1 on: February 09, 2022, 05:26:19 AM
Nice job!!
se Offline RF52
Reply #2 on: February 09, 2022, 05:59:50 AM
That's great :like:
As for coating on the hooks, you could try plastidip/rubber spray :tu:
Reply #3 on: February 09, 2022, 06:46:19 AM
  This was taken after retrieving the bugger from up in its rabbit hole. I could barely see a corner of the connector... and that snap-on hook worked!  :D
¬ Outback in Idaho
us Offline mashguy4077
Reply #4 on: February 09, 2022, 09:40:50 AM
You pulled a macgyver!
us Offline VICMAN
Reply #5 on: February 09, 2022, 07:14:06 PM
Nicely done!  :tu: :tu:
Very good use of the Spirit with what you had available! :cheers:
Reply #6 on: February 09, 2022, 09:27:59 PM
Very nice Macgyver  :salute:
I second the plastidip.
pr Offline Juan el Boricua
Reply #7 on: February 09, 2022, 11:16:47 PM
Great story, great conclusion; very ingenious!
Thanks for such a great idea, OiI. :tu: :hatsoff:
As for protection, what others have said: Plasti Dip; also, spray on bedliner or shrink tubing over the hook end.
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $91.95
PayPal Fees: $4.93
Net Balance: $87.02
Below Goal: $212.98
29%
June Donations
