Sharpening A Knife With A Leather Strop: Great For SAK's!!!
Guest · 34 · 6715
us Offline Gadget Guy
Mods: I wasn't sure where to post this. If it's in the wrong place, please move it for me.  :tu:
I found this great video on sharpening using a strop. I always thought a strop was used for the final edge after you have used a stone, but I tried the technique used in the video and I've had great success! This works especially well on SAK's for some reason.  :think:  Anyway, give it a try.  :tu:
us Offline eodtech
Re: Sharpening A Knife With A Leather Strop: Great For SAK's!!!
Reply #1 on: January 28, 2009, 05:28:45 AM
Why do I carry a 45 ?
Reply #2 on: January 28, 2009, 05:33:58 AM
Reply #3 on: January 28, 2009, 07:00:47 AM
Great links guys :tu:
Reply #4 on: January 28, 2009, 07:08:43 AM
Thanks!  :cheers:  BTW, I've found that a hand held board with a strop attached works best for pocket knives. Something like this:
This is the actual one that I use.  :tu:
Reply #5 on: February 02, 2009, 07:47:17 AM
Can you say Strop? I knew you could!  :D
Reply #6 on: February 02, 2009, 10:04:37 AM
Good links guys.  I always reach for the strop first if my knife has gone a bit dull.  Most of the time it's all that is needed.  It's only if that doesn't work do I go for a stone.
Reply #7 on: February 02, 2009, 12:55:00 PM
Looks like I'll have to invest in a strop soon then.
Reply #8 on: February 02, 2009, 03:04:32 PM
You can just use your mouse mat, or belt in the mean time :)
Reply #9 on: February 04, 2009, 03:06:10 AM
This is the one I got. A bit pricey perhaps, but it's nicely finished and hand made in the UK. He includes a little bottle of stropping fluid, (that looks remarkably like Brasso to me).
This is an old photo, but it gives you an idea of size etc:
Reply #10 on: February 04, 2009, 10:44:24 AM
Not a bad price for what you get.
Reply #11 on: February 04, 2009, 01:15:48 PM
Could be engraved I supose too ;)
Reply #12 on: February 04, 2009, 07:51:09 PM
I think 10 quid is a really good price. I would like a couple of them!  :tu:
ca Offline jzmtl
Reply #13 on: March 01, 2009, 02:32:00 AM
I just tried power strop with dremel and polishing wheel, can clearly tell the knife (previsouly sharpened to 1500 grit) lost quite a bit of slicing cut power but gained lots of pushing cut power, not sure if I like that. Nevertheless I'll track down some leather and make a proper strop and see what I can do.
Reply #14 on: March 01, 2009, 04:34:27 AM
I have recently been using my work belt for stropping and it does seem to get you to a new level of sharpness :o
I first get it as sharp as I can with my Sharpmaker then hit it on the belt quite a bit and you really can tell the difference :tu:
I believe I may go the route of a handmade strop
I live about 5 miles from a good leather shop I may go and buy some of there remnants and give it a go :tu:
Offline Styerman
Reply #15 on: March 02, 2009, 07:28:44 PM
Looks good , also very usefull for correcting your significant other .
Chris
Reply #16 on: March 03, 2009, 03:33:42 AM
Chris
 :twak: :D Probably not a good idea :think: she would probably take it away and give me 1 :o :twak: :ahhh :ahhh :D
Offline cgk
Reply #17 on: March 03, 2009, 06:08:28 AM
Chris
My wife would just yell at me and tell me Im doing it wrong.
Offline Styerman
Reply #18 on: March 03, 2009, 03:58:07 PM
Chris
Your biggest worry is when she says "harder harder" or tells you that you hit like a girl !
Chris
Offline cgk
Reply #19 on: March 03, 2009, 04:26:37 PM
Chris
Chris
...or, your brother hits harder than you  :o
ca Offline jzmtl
Reply #20 on: March 03, 2009, 10:46:30 PM
Just made one from block of oak and thick leather that I got from a local leather shop, glue is drying under weight, I'll see how well it works tomorrow. This one is 2.5"x12", still have enough leather to make three or four more.
Reply #21 on: March 03, 2009, 11:19:57 PM
 :tu: Tell us the end results jzmtl :)
us Offline Mike
  • Shop smart, shop S-Mart.
Reply #22 on: March 04, 2009, 12:48:56 AM
Yep, that's where I got the leather for mine too, a local leather shop.
Mike
ca Offline jzmtl
Reply #23 on: March 04, 2009, 04:11:29 AM
Well I loaded it up with polishing compound and tried it on my freshly sharpened tenacious. I can definitely tell strop made it sharper when testing on thin paper. Although I think I'm getting the angle wrong and makes the edge more obtuse than original sharpening angle, Guess I need more practice.
Oh anyone know which is finer, jeweler's rouge or green polishing compound? I tried both but couldn't tell from scratch pattern.
« Last Edit: March 04, 2009, 04:20:21 AM by jzmtl »
Offline Anthony
  • Improvise.
Reply #24 on: March 04, 2009, 04:23:17 AM
You got to come in really shallow and use almost no pressure.  I also have a small peice of jasper that I "wipe" the blade across after stropping.
ca Offline jzmtl
Reply #25 on: March 04, 2009, 04:42:45 AM
Hmm, no pressure eh? That may be my problem.
Offline max6166
Reply #26 on: March 04, 2009, 04:44:49 AM
I think there are some good stropping videos on YouTube which demonstrate the technique.
Reply #27 on: March 04, 2009, 11:57:16 AM
It's hard to imagine an edge that can be even sharper than a Sharpmaker.
Hopefully one of the guys at the UK meet can demonstrate for me.
ca Offline jzmtl
Reply #28 on: March 05, 2009, 08:18:42 AM
Okay I did some more testing, the improvement isn't as big as I thought. With side by side comparison there just isn't significant amount of gain to warrant the effort.
Reply #29 on: March 06, 2009, 05:00:31 AM
but the strop is good for touching up an edge after you have sharpened and the edge has just dulled a little :tu:
a few hits on it and it's back to shaving sharp again :D
