The Payback
us Offline Adam5
Re: The Payback
Reply #30 on: May 20, 2022, 03:24:23 AM
Also could you do a thread on modding the bit driver or link to one you used?  I have heard it takes welding on some extra material to the Center Drives bit driver.  Is that true?
When I enlarged the pivot hole, I did it somewhat off center from the original hole so that there was enough metal to engage the lock. I couldn't use the drill press because the drill bit would bend and align with the center of the existing hole. So I had to use my rotary tool and a couple of different sizes of Dremel chainsaw sharpening stones (5/32" and 7/32") to create a hole slightly larger than 7/32" and centered slight further away from the back end of the bit driver.
I wish I had documented the process. But I was focused on working out how to do the modifications and not so much on recording what I figured out.
« Last Edit: May 20, 2022, 03:47:10 AM by Adam5 »
Offline Hvac budget
Re: The Payback
Reply #31 on: May 21, 2022, 02:39:45 AM
Thanks.  It ended up fantastic!
Re: The Payback
Reply #32 on: May 22, 2022, 01:57:43 AM
 :woohoo: :like:
August Goal: $300.00
Due Date: Aug 31
Total Receipts: $36.00
PayPal Fees: $2.24
Net Balance: $33.76
Below Goal: $266.24
 11%
August Donations
