Help for an adapter (3D print or other option)
Sos24 · 15 · 2029
on: June 03, 2022, 11:10:55 PM
For hiking water filter, I really like the HydroBlu Versa or Sawyer Squeeze screwed onto a collapsible water bottle.
Recently I started using and really like the Source Nomadic collapsible water bottle.  I want to use it when I go out hiking, but it uses a proprietary opening size.
I figured out one solution to use the filter bottle combination, but would really like a better adapter.  I’ve tried making one myself using caps and epoxy, but haven’t had luck.  I was thinking a 3D printer adapter would be great but those are skills & equipment I lack.  I know 3D printing is said not to be food safe, but if it is prior to a filter I think it should be ok.
Does anyone know where I could get some help or have an alternative idea that wouldn’t require a lot of skill or equipment.
Source is considering making an adapter but we all know that could take a while
This is what I trying to make as one piece.
Re: Help for an adapter (3D print or other option)
Reply #1 on: June 03, 2022, 11:49:48 PM
What about buying one of these
https://sourceoutdoor.com/product/short-tube-adapter/
then cutting the tube and inserting the Sawyer filter?
Reply #2 on: June 04, 2022, 01:04:06 AM
That is part of the solution I use now.
But f I could get one piece with no hose, it would be ideal.  Plus if I had the adapter, I could use it as a lid when the filter wasn’t attached.
00 Offline Dutch_Tooler
Reply #3 on: June 04, 2022, 09:47:00 AM
Not to want to sound too sceptical, but if the plastic used in 3D FDM printing is not safe for food, I don't think the usual drinking water filters will change that... I'm not a chemist though.
Mechanically it would work, although screw thread is not easy to model in the 3D design programs I have used.
Cheers!
Dutch_Tooler
Reply #4 on: June 04, 2022, 11:53:22 AM
Thanks for your thoughts.  You may be right.  I’ll have to look into it more.
no Offline Vidar
Reply #5 on: June 06, 2022, 12:51:26 AM
3D programs I've used will model threads easily enough, but you will still have the issue of measuring the existing threads to a sufficient precision to know what to model. And with 3D print there will typically be some scaling or shrinking issue. Nothing that can't be solved with a trial run or two to get the necessary adjustment. A somewhat flexible material will also be more forgiving I imagine.
I do believe there are food safe material alternatives for 3D printing. I'm pretty sure I've seen them offered when I've purchased various others earlier.
For this though I would likely have tried to make a mold for casting directly since you already have a physical model you want to copy. There are food safe silicon casting alternatives out there ("Bakesil" being one), or alternatively food safe thermoplastics like polyethylene.
"Simple is hard"
"Hard is hard too"
nz Offline Syncop8r
Reply #6 on: June 06, 2022, 12:59:48 AM
Biological contaminants tend to stick to sediment so filtering out the sediment removes most of them. Filtration does not remove chemicals.
nz Offline Syncop8r
Reply #7 on: June 06, 2022, 01:02:58 AM
Without looking too much into your issue, is this any help? https://sourceoutdoor.com/product/convertube/
Reply #8 on: June 06, 2022, 01:25:37 AM
Unfortunately, not.  You would think one of the group would fit, but they didn’t make a size to fit their own soft bottle.
nz Offline Syncop8r
Reply #9 on: June 06, 2022, 01:55:34 AM
If you're on Facebook, Homemade Wanderlust is a good group to ask in.
Reply #10 on: June 06, 2022, 02:20:31 AM
Thanks for the suggestion.
nz Offline Syncop8r
Reply #11 on: June 22, 2022, 11:07:41 AM
Now I'm getting Source Outdoor ads on Facebook.  ::)
Reply #12 on: July 03, 2022, 09:49:41 PM
I hate when that happens.
Reply #13 on: July 03, 2022, 10:10:14 PM
If your using an epoxy it’s probably already not food safe, but what two parts are you joining, I can’t see, where the thread meets the flat?
Reply #14 on: July 05, 2022, 12:48:57 AM
The picture is just an example of what I want showing a failed attempt at using a food safe silicone epoxy to join the two pieces (bottom piece has a small lip that the 28mm threaded piece sits inside).  It did not hold up to the repeated screwing.on/off without leaking.
The current solution is using the Source tube adapter and Sawyer inline adapter.  The Sawyer snaps into the Source lid when the tube is removed.  It is not as secure as one pieces would be but does work at least for day outings
For multi-day hikes I use a different system that I trust more.
« Last Edit: July 05, 2022, 12:57:14 AM by Sos24 »
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $98.14
PayPal Fees: $5.55
Net Balance: $92.59
Below Goal: $207.41
31%
March Donations
