An error has occurred!
on: July 13, 2022, 06:06:27 PM
Though it's more of an annoyance than anything else, I'll not keep silent about this any longer. More often than not, when I attempt to log in, I get the sentence in the subject line. It is accompanied by the following:
Quote
Session verification failed. Please try logging out and back in again, and then try again.
No indication as to possible causes is given. This happens on both my phone (Android using Chrome) and tablet (Fire using Silk). Unless I enter my password incorrectly, the second attempt is always successful.
I cleared my browsing history a few moments before posting this topic, and that seemed to help. I don't know if that is the only fix, or if there may be a better one. Any ideas of the cause of this little annoyance and how to remedy it?
Re: An error has occurred!
Reply #1 on: July 13, 2022, 06:25:16 PM
I haven't seen that issue myself  :dunno:
It could be an old session cookie that was stuck in your browser cache, so deleting that would have helped you there  :salute:
Reply #2 on: July 13, 2022, 06:36:34 PM
I just stay logged in   :dunno:
Reply #3 on: July 13, 2022, 06:52:57 PM
That's a good idea too  :tu:
Reply #4 on: July 13, 2022, 10:09:59 PM
I'll see about clearing the cache, and maybe just stay logged in.
Perhaps it's worth noting that the other forum I frequent runs phpBB, and I don't have such issues there. Could my issue possibly be a quirk or peculiarity of Simple Machines? :dunno:
Reply #5 on: July 13, 2022, 10:17:15 PM
 :dunno:
I'd suggest to wait and see if others report this problem too.
Reply #6 on: July 13, 2022, 11:13:23 PM
Sounds like a cookie problem to me too. The stitched up one's advice should do the trick. Let us know if it doesn't
Reply #7 on: July 14, 2022, 12:05:18 AM
 :iagree: with Stitchy and Enki :cheers:
I hope you can get the problem fixed, Farmer :salute: :tu:
Reply #8 on: July 14, 2022, 04:52:59 PM
MTo knows you're in another forum.
MTo is not amused.
MTo is warning you.
Heed MTo's warning.
 :twak: :twak: :twak: :twak:
Reply #9 on: August 01, 2022, 04:27:00 AM
Not too long ago, I logged in from a thread. The error did not occur. I got the same result while logging in this time around. Seems the errors only occur when I log in from the forum homepage. Weird.
fr Offline Whoey
  • I am geek, hear me code
Reply #10 on: August 01, 2022, 02:56:41 PM
I did change some settings for testing purposes (to find the posting bug) such as sessions to database (which might have spit an error but still worked) but that has been reverted.
maybe it's time for a new cookie name and try DB sessions for a while...
Reply #11 on: August 02, 2022, 03:55:17 AM
I'll give that a go...once I figure out what awl that means and how to implement it. :think:
fr Offline Whoey
Reply #12 on: August 02, 2022, 10:47:35 AM
Sorry, it's actually something I need to do and setup
Reply #13 on: August 03, 2022, 05:01:55 AM
That explains why it flew right over my head! :D
Reply #14 on: August 05, 2022, 10:51:04 PM
Well, so much for logging in from a topic. That now gives me the error, too. Thanks to Whoey for looking into this! :cheers:
Reply #15 on: June 04, 2024, 01:39:38 PM
This is still going on. The error message is accompanied by the following:
Quote
Only the tablet and phones are affected. Maybe I'd have better luck with my PC, whose cache looks a lot less like the Oreo/Chips Ahoy/Nutter Butter factory floor. :D
Reply #16 on: June 05, 2024, 01:22:14 AM
 :dunno:   No one else has reported a login problem. Sorry that it's happening to you. Did it ever resolve or has it been ongoing ?
Reply #17 on: June 05, 2024, 01:57:45 AM
Very much ongoing. I still haven't tried with the PC, which may give better results.
Reply #18 on: June 05, 2024, 05:50:41 AM
Maybe just stay logged in and avoid the issue.
Reply #19 on: June 05, 2024, 10:28:12 AM
have you tried cleaning browser history fully and then try login
Reply #20 on: June 05, 2024, 02:17:57 PM
I did try that, and got the same results. Clearing the browser history comes with an additional pain: the bank's Web site no longer recognizes me, and I have to go through the PITA of proving that I'm really me all over again. :crash: I won't get into what I feel should happen to the smurfbirds who perpetrate identity theft, stealing account information, and such. :twak:
Reply #21 on: July 03, 2024, 12:34:38 AM
I've logged in on the PC quite a few times since making the post above this one. Thus far, I've had no issues logging in on the PC. Why, I don't know. :dunno:
Reply #22 on: July 06, 2024, 11:24:55 PM
Glad the issue is resolved for you :salute: I am on PC right now but I mostly use my phone for :MTO: and haven't really had a problem logging in at all :dunno: :salute:
Reply #23 on: July 06, 2024, 11:29:28 PM
My most recent PC logon saw the message again. I'll clear out the cookies and whatnot before shutting it down and see what happens tomorrow.
Reply #24 on: October 24, 2025, 07:13:47 PM
This is still ongoing. Before logging in successfully, I used my brain and made a note of the URL for the error page. It contained this:
index.php?action=login2
Perhaps that little tidbit will result in a solution.
One other thought: might it be because I'm one of the 32 users who persist with the ShelfLife theme? :think:
Reply #25 on: October 25, 2025, 02:05:00 PM
It would be easy to test, try using the default for a while and see if it solves the problem. I think you will get to like Sunrise if you give it a try.
Reply #26 on: October 25, 2025, 09:38:12 PM
I'll give it a shot. :hatsoff:
Reply #27 on: October 26, 2025, 02:15:28 AM
I switched over to Sunrise and didn't get the error message when I logged in for this session. But I'm not fond of the Sunrise theme. I may try one of the other themes and see if anything changes.
us Offline IMR4198
Reply #28 on: October 26, 2025, 02:52:05 AM
Try both versions of the Sunrise.  Light and Dark.  I use the Blackout or Dark mode.  Best wishes.  G
Reply #29 on: October 26, 2025, 07:57:26 PM
I prefer light mode. My gripe with Sunrise is that when browsing the Q and A section, and I try to return to the Site Use FAQs, it bumps me to the top of the forum main page. I don't have that problem with the other two available themes. Were it not for that issue, I'd have probably fully committed to Sunrise by now.
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
