Since you obviously like the Charge, you should get the orange Charge G10.
If not, I see a disturbing lack of Skeletools in your collection. I consider the CX a "must have", and the RX is very cool too.
If you consider yourself a collector, then you'll eventually want one of everything. If that is the case, just buy the most expensive tools that you don't have yet. Even though you might not like the Free P4, you know you'll want it in your collection.
It sounds as if you're looking for a safe queen rather than a user? My top pick for a safe queen would be a topo Signal. For a user, I'd be torn between a Rebar and a Wave; I'd get those in black oxide. But that's just me...
You seem to be lacking in the Supertool dept. I would start there Perhaps the Heritage PST reissue for your collection.
anyone know how this works? https://www.leatherman.com/removable-bit-driver-126.html
You've got all the usual suspects it seems. Only thing I can think of is a collector what about the Tread?I didn't see a Raptor either. Whatever you get Thank you for your service and enjoy the new tool/s.
It's for the ST300, Rebar and Bond. You just push it onto your Philips driver (Image removed from quote.)(I didn't have a better photo, the middle one)
Super tool 300M is quite a tool, now has the bit driver, the long awl/scraper and pry tool have extended its capability. I work in the security industry and I use the long awl to scoop out door pin holes in the transom now and then. Used the pry,nail puller to open small banded crate. A bit heavy to carry, mine was from the bay so I need to get the new style bit adaptor.
Glad i got out before the GWOT.
You mentioned a Crunch, but there’s already one in your list. In your position, I reckon it’s between the 300M and the 300EOD, with a Curl as another possibility. If you have that many Waves and Charges and a couple of Surges, you clearly likely be one handed opening style more than the classics.If you were just looking to add to your collection and didn’t need to buy directly from Leatherman to use the discount, hunting down a Darkside would seem like the obvious move.
I served during that period.Are you any closer to a decision?
i'm teetering between the crunch and another ratchet.
I thought from your list you already had a Crunch. It’d be top of my list without a doubt.
i do have one, but 2 would be twice as good, right?
what ship were you on?
Both USS Lake Champlain (CG-57) and USS Peleliu (LHA-5). I did two deployments aboard Peleliu.
