Where I am you rarely see temperatures below -7c (19F).
A bit chilly, but not what I would consider dangerously cold.A few other things to possibly consider…A UPS for your cable modem might possibly enable you to keep your landline phone working through the outages. You would need to investigate this further, figure out what size UPS you would need, etc.A winter sleeping bag can be nice to have, but probably overkill unless you’re anticipating longer outages or you’ll use it for camping anyway.
[...]Cooking - I have a gas hob so should be ok if services stay on as they say.[...]
It boils down to shortage of gas for our power stations due to the Russia/ Ukraine war, and also lack of imports of power from Europe[...]
Well bugger, that would be a bit of a cramp in working from home. Guess the budget will have to find space for a Jackery or some such
Three hours without power isn't too bad. It gets annoying when it's much longer than that. I have gone for nearly a month after a major storm. If it happens when you're not home it could affect the safety of the food you have in your refrigerator and freezer. I learned a trick long ago to know if you had a power outage while you were away from home. Freeze a glass of water solid and put a coin on top of the ice. If the power goes out your freezer should stay cold for at least 24 hours since nobody is opening it. So, if you get home from a trip and the coin is at the bottom of the glass then your power was likely out for longer than 48 hours and your food may have spoiled. Another trick I learned dealing with power failures is to put a clear glass vase filled with water on a 6 volt flashlight and the vase filled with water diffuses the light to light up a whole room. Also, solar powered pathway lights can be charged outside and then brought in and distributed around the house at night. I charge about 10 of them in a bucket in my yard during the day and bring them in as soon as it starts getting dark and they light up.
Temperatures here might go -30 to -40 celsius (-22F to -40F) on coldest time so its bit weird that they let powers go down since heating up takes much more energy than they plan to save on those power shortages.
It may be that they are threatening the power cuts to try to get people to conserve energy, with little to no intention of actually implementing them.
How long till the water boils
No, they've begun trials of that and it's been a complete failure (a sample group of only 300,000 households). Where as the practice runs power power cuts have been carried out and deemed a complete success.
My 6 volt flashlights are all LED, so if you're waiting for tea it may be a while.
Oh boy
