A stack of advice to benefit a handful of enthusiasts. The vast majority of consumers won't even care enough to post opinions on the internet. They certainly won't be debating things like level of liner-edge polish or steel types used. SAKs are not pretty custom collector or gimmicky enthusiast pieces. They're tools, meant to be used.
My advice for Victorinox is to make a pliers based keychain tool like the Leatherman PS4. It would sell like hot cakes!And yes I know Victorinox already makes a bunch Of keychain knives, but none pliers based like The Leatherman PS4.I know I would buy at least 3.
They are actually all of those things to different people, and more.
6) Now regarding those flipper style knives that are outselling your products. Create a line of flippers that make all others pale in comparison. Yes, use some different steel. Make them open easily and lock when open as a choice.
My dislike of the situation is that weapon type knives are so popular and I can not see how this is not hurting Victorinox's bottom line.
Personally, I’ve never understood the purpose of the oversized “flipper” knives you see so many of these days. I mean, beyond the obvious commercial purpose the companies who make them have discovered - ie, selling them to people who think they are going to cut through God knows what with them. I mean, people should spend their money however they like, different strokes and all that. But I’ve never seen the point in owning a modern “flipper”. SAKs and other traditional pocket knives all the way for me.
...But valid points on cellidor scales and 84mm scissors. We could definitely use a more durable and environmentally friendly alternative to cellidor....
1. Rather than making the scales more scratch resistant, I’d rather see them return to solid scales rather than hollow ones, for the sake of actual durability as opposed to superficial scratch resistance. 2. Polishing the liner edges would only provide more surfaces to collect scratches (see your first complaint). 3. The tools are already very well polished (enough to display fingerprints out of the box), so what are you asking for? A mirror finish? Plus, see previous comment about polishing and collecting scratches. 4. Victorinox just needs to switch from peened pins to screws to allow users to disassemble their own knives. The parts for each knife size are interchangeable already. 5. I agree 110%. 6. I don’t want Victorinox to start a line of flipper knives, because it would almost certainly be at the expense of retiring other knives. They’ve already retired too many models. I’d rather see them resurrect the 74mm line than introduce a line of flippers.
I may be way off here... but isn't part of the reason that Victorinox uses the plastic that it does for the scales is that it is plant-based and not made with petroleum or its by-products? At least that's what I understood, though I will readily admit that I might be totally wrong about that.
They are not simply weapons and that’s a completely invalid assumption of intent.
