Hello everyone, I had this idea kicking around for the last few weeks and got it done today.
The idea:
84 mm golfer using wenger scissors and a phillips in place of the corkscrew. A hidden file tossed in the liner as well.
The donors:
Waiter - combo tool, spacer, blade, back-spring, liners
Recruit - back-spring, liner
Traveler - scissors, spacer
Tinker - phillips
Classic SD - file
So after looking through the threads about wenger scissors I was a bit confused because some people had them on the small end and some on the large end. After trying both ways I thought the small side was most doable. Getting the spacers right was a bit of fiddling but in the end pretty simple.
I kind of slacked on process photos since I got carried away, but this was my most careful mod yet, I mostly resisted the temptation to rush it.
The cons: while I got the scissor snap to be pretty perfect, there are some other minor issues. Due to my setup the spring sits lopsided with the scissor side poking out a bit and the spacer side sunken in a bit, nothing obscene but not perfect. Along with this there is a bit of play in the closed position of the scissors which allows it to bounce back up a bit if its closed in a certain way. Again, not obscene but imperfect. It closes perfectly when I close them my usual way, and it is not loose or jostling around at all when closed.
Anyway, I can’t carry it due to the camper challenge, but once I do I will report back. If anyone has any pointers on the wenger scissor and recruit spring setup it would be great to hear.
