new member
Offline alanp
  • New User
new member
on: April 06, 2023, 12:58:26 PM
Hi
I am having laminate floor fitted in my home, the fitter has advised In purchase a multi tool to remove the original laminate flooring.
Can anyone recommend a model please, its worth adding I cannot see me using it on a regular basis after i remove the flooring.
Re: new member
Reply #1 on: April 06, 2023, 01:56:53 PM
Hello and welcome !   :cheers:
Where are you located ?   If you have a Harbor Freight or Menards locally I would go with one of there off brand Mufti tools. Don't bother with cordless for what you need it for.
https://www.harborfreight.com/power-tools/rotary-oscillating-tools/oscillating-multi-tools.html
I have this one and it works just fine for how often I need it.
https://www.menards.com/main/tools/power-tools/oscillating-tools/tool-shop-reg-2-amp-corded-oscillating-multi-tool-kit-7-piece/2418503/p-1455839708341-c-12869.htm?
tid=26921e31-b7bb-41b5-9440-0f0f4caa38d8&ipos=1&exp=false
Re: new member
Reply #2 on: April 07, 2023, 12:53:56 PM
Welcome to :MTO:  :iagree: with, Steve :cheers:
us Offline Explorer
Re: new member
Reply #3 on: April 07, 2023, 01:45:38 PM
I bought a Makita 18 volt multi-tool less than a year ago and after about 10 months of very light use the battery just suddenly stopped working so I'd avoid Makita but YMMV
Wish you luck on your home project and welcome to
 :MTO:
no Offline nakken
Re: new member
Reply #4 on: April 09, 2023, 07:50:50 AM
Welcome to the forum, alanp :cheers:
Explorer, that sounds like Makita alright. Our company switched to Milwaukee since almost all our batteries stopped working. These are the best multi cutters I've ever used, but they sure are pricey. Like Steve said, off brand corded are probably more than enough. Good luck :tu:
us Offline HarleyXJGuy
Re: new member
Reply #5 on: April 10, 2023, 04:18:25 PM
Welcome!
fi Online Antti Lammi
Re: new member
Reply #6 on: April 10, 2023, 09:44:01 PM
I have cordless Bosch Professional Multi Cutter at work, all cordless one are handy but downside on battery version are thise are heavier than regular versions, i recommend to look Multitool/MultiCutter with cord, if your planning only use that at home.
Usually cord versions are bit cheaper than battery version and i would dare say even better than battery even when cord sometimes get in way.
Only Tools Matters
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $62.07
PayPal Fees: $3.62
Net Balance: $58.45
Below Goal: $241.55
19%
January Donations
