How to clean a SAK with wooden scales
Maties · 14 · 2706
Offline Maties
on: May 25, 2023, 11:38:30 AM
Hi everyone,
I recently bought a second hand wenger SAK with wooden evo scales. It's nice and in a very good condition, but it's dirty and smelly, and it needs a good cleaning, and I don't know how to do it. I think water could damage the wooden scales.
How do you clean wooden scales SAKs?
Enviat des del meu Pixel 3a usant Tapatalk
us Offline Bunk Tuppins
Re: How to clean a SAK with wooden scales
Reply #1 on: May 25, 2023, 12:27:09 PM
My suggestions:
-Don't immerse it in water.  Wood swells up and the shape can become distorted.
-You can wash the metal parts using cloth or paper towel, etc with soap and water, and/or rubbing alcohol.  Try not to get too much alcohol or water on the wood and wipe off any spills immediately.
-Once you have got it all cleaned up (and the wood is quite dry), put a thin layer or two of beeswax on the wood.
If the odor is something that has soaked into the wood (sweat, perfume, etc) you may be out of luck.  Wood is porous and rubbing with a damp cloth or even sanding it may not remove odors.  If nothing works you can try wrapping the knife with cloth and putting it in a box with baking soda (or charcoal) for a week or two.
« Last Edit: May 25, 2023, 12:46:26 PM by Bunk Tuppins »
no Offline nakken
Reply #2 on: May 25, 2023, 01:17:34 PM
I have been wondering about the same for my Hiker wood. This seems like some great tips, cheers Bunk :tu:
And good luck, Maties. If you do get around to it, some before and after pictures are always welcome :D
Offline Maties
Reply #3 on: May 25, 2023, 03:32:19 PM
Thank you, Bunk Tuppins, for the tips. I will try it.
I will make photos and post it if it works, nakken!
us Offline HarleyXJGuy
Reply #4 on: May 25, 2023, 04:04:19 PM
Hi everyone,
Unfortunately you can’t.
Once they get dirty you must send them in. I’ll PM you the address.
 :pok:
Offline Maties
Reply #5 on: May 25, 2023, 04:19:42 PM
 :pok:
I'll try anyway. I think it can get much better than it is
Now I've been googling and found something from the victorinox web page.
https://www.victorinox.com/global/en/Wood-%E2%80%93-the-material/cms/wood#Care
Cheers!
Reply #6 on: May 25, 2023, 04:42:29 PM
Cheers!
I think the wood cleaning and maintenance info in the link mainly applies to cutting boards but it is fairly good advice for wooden knife scales.
Chances are good you can clean the wood up a bit (scrub with an old toothbrush and water then dry) and maybe deodorize it.  I've been avoiding buying used wooden pocket knives because they are pretty hard to clean and wood has a tendency to get scratches and dents.
Offline Maties
Reply #7 on: May 27, 2023, 03:38:09 PM
Well, it's done and I'm satisfied with the result.
First I cleaned it with warm water and a toothbrush, after drying it I cleaned it with vinegar, then water again and drying. At this point the bad smell had gone completely.
Then I sanded it a little bit with a 250 grit sandpaper, and finally I applied a thin layer of oil for wood.
I don't think you can see much difference, but I leave a few images.
Before
After
Reply #8 on: May 27, 2023, 04:17:56 PM
Looks good!  Has a nice grain on the scales.
gb Offline Rizio Il Ghiro
Reply #9 on: May 27, 2023, 06:04:51 PM
 :iagree: Nicely done!
Offline Maties
Reply #10 on: May 27, 2023, 06:42:54 PM
Thanks! That proves it's possible to clean and mantain wooden scales on a SAK. Just don't soak it in water too much time... And don't do that very often.
Two more pics
Enviat des del meu 21051182G usant Tapatalk
Reply #11 on: May 27, 2023, 07:13:05 PM
That looks like an Evowood 10.  I have the Delemont version of it.  It has become my favorite knife!   I have a bunch of SAKs sitting on my desk and I generally find myself reaching for this one.  I even bought a backup.  It's small and light and unobtrusive in the pocket.  Has all the tools I need (and I can take a 74 or 58 with scissors if I need them).  I enjoy handling wood somewhat more than plastic.  Of course plastic is better in situations where you might encounter water or grease and I do have a red Delemont version too...
Offline Maties
Reply #12 on: May 27, 2023, 07:35:54 PM
Well, I looked for this model on the sakwiki and I see it's an Evowood 14. Scales are made from swiss wallnut. It has scissors, but you can't see that in the photos.
I don't think I will use it usually, because for an EDC I usually carry SAKs with cellidor scales or alox, but I keep this with wooden scales becouse I find it beautiful, and I like the touch feel. I guess I'll carry it occasionally, when I want something a bit more elegant in my pocket.
Reply #13 on: May 27, 2023, 07:52:30 PM
I have a Delemont version of the Evowood 14 too.  Nice knife.
Total Receipts: $105.65
PayPal Fees: $6.36
Net Balance: $99.29
Below Goal: $200.71
33%
