January OHT Challenge
Rich_SD · 766 · 32226
us Online LoopCutter
Re: January OHT Challenge
Reply #330 on: January 11, 2024, 05:42:15 PM
Day 11
Sort of a failure, mostly operator :facepalm:
Making my crockpot concoction yesterday, I forgot to add the French Onion Soup. So when I returned home a couple hours later I remembered,  it was an older style can, no pull lid tab.
I tried the oHT opener/cap lifter, pierced the can, caught the lip and successfully completed two lifts and cuts, then the lip gave way,  I had to resort to a traditional can opener.
I will admit, the few times I have needed to open a can, LM is not my go to, a SAK or a sturdy knife blade is 1st choice. ☺️
Reply #331 on: January 11, 2024, 05:49:23 PM
Thanks LC! Speaking of pliers, for Day 11 I used the excellent cutters to cut a zip tie
Nice job Barry!
For me, I prefer a pair Diagonal cutters for trimming  nylon zip ties, or the serrated blade to allow me to trim to the locking block. I just hate getting my hand or arm scratched by the sharp edges defy by a bypass cutter since they can not get flush.  Mainly because most areas I have to secure wires/cables were with tight quarters or cabinets.
nz Offline Pauldmmwc
Reply #332 on: January 11, 2024, 09:33:12 PM
Hello to day 11.
I get paid to look at cracks in concrete floors and write up reports. Some people think this a very strange and sad life.
Normally there are pictures involved   and I need to label them.
The OHT  was used to trim labels to size before photos are taken.
The card is called a crack width indicator.
Nice pics from the rest of the team.
Semper Sitienti !!
Reply #333 on: January 11, 2024, 09:59:08 PM
That is interesting, kinda like CSI gauge!
Cement Seperation Indicator 🙄
Reply #334 on: January 12, 2024, 01:08:24 AM
 :iagree: I've made them work when I had to, but the SAK opener is hard to top.
Day 11
Reply #335 on: January 12, 2024, 01:09:26 AM
I'll have to try the serrated blade truck LC!
Nice job Barry!
Reply #336 on: January 12, 2024, 01:11:25 AM
 :cheers: Paul and the same to you!  I've never seen that done.
I've been around for cracks in asphalt, and I measure structural cracks on large trucks but I'd love to see you at work.
Hello to day 11.
us Offline FolderBeholder
Reply #337 on: January 12, 2024, 02:36:47 AM
Day 11
Just some package opening with the straight edge and a glamour shot.
Reply #338 on: January 12, 2024, 03:21:15 AM
 :tu: :like: :tu:
pr Offline Juan el Boricua
Reply #339 on: January 12, 2024, 05:04:42 AM
Looking good people; really enjoying the challenge (albeit from the grandstands :facepalm:); Lisa, loving your calendar!!! :like: :tu:
Reply #340 on: January 12, 2024, 08:05:33 AM
Excellent pics and OHT's everyone  :like:
Day 11
The LM opener is the best working for me on cans.
Bottles do work too but not as good as the Victorinox one.
Reply #341 on: January 12, 2024, 02:33:09 PM
 :drool: :cheers:
Reply #342 on: January 12, 2024, 02:34:22 PM
Day 12: Playing with the saw :ahhh
Reply #343 on: January 12, 2024, 05:15:18 PM
That is pretty bold to try cutting that tree with the saw blade. I think that the smaller side branch would be more suitable attempt.
Let us know your experience!
us Offline Rich_SD
Reply #344 on: January 12, 2024, 05:21:33 PM
Day 11
Reply #345 on: January 12, 2024, 05:22:54 PM
Day 12
Mounting a display case, found that the instructions were misleading, and the result was two brackets were not in the correct position on the wall.
So, removed the two brackets, OHT pliers held the inserts while I backed out the screws.
Aplied masking tap to top on cabinet marked center points held to the wall locked into the correct mounts and transferred marks to center the remaining two.
Drilled the holes and mounted 👍
OHT helped…
Now to remove the protection of the plexiglass.
But in side on a shelf
us Offline Rich_SD
Reply #346 on: January 12, 2024, 07:07:53 PM
Day 11
Where's mine?   :cheers:
I love Leatherman's combo bottle and can opener.  While it may not be the best at either job, I rarely ever (almost never) need a can or bottle opener on my multitool, so I really appreciate that it takes up only 1 tool slot instead of 2.   :tu:
« Last Edit: January 12, 2024, 07:20:09 PM by Rich_SD »
us Offline Rich_SD
Reply #347 on: January 12, 2024, 07:18:59 PM
Day 12
I'm sitting here in front of my computer, and I decided to test the wire cutters.  They cut very n.....  :ahhh
Reply #348 on: January 12, 2024, 08:52:57 PM
 :cheers: LC!  It got it done, but I can honestly say that this saw is a "survival" saw.  It felt awkward in my hand while I was using it.  It seems about a 1/4 inch short.  Other than that, it's a cutter!
Reply #349 on: January 12, 2024, 08:53:34 PM
I love Leatherman cutters!
Day 12
Reply #350 on: January 12, 2024, 08:54:09 PM
That's a great point Rich  :tu:
Reply #351 on: January 12, 2024, 10:16:27 PM
I will agree with you on the  two points, it is a “survival” saw tool.  Prepping small branches for a camp fire is what I have used for in a couple of outings.  And yes , it should and could be longer if LTG considered a serious tool.   Placing the smallest flat screwdriver blade on the saw side a longer saw would fit nicely, just requiring the flat base to be open prior to the saw.  Then put the can/lifter in the flat screw blade place.
Otherwise a 1/4” saw blade should fit in the same location.   I think somebody read the blue prints wrong🤪
 :cheers:  Thanks for mug, 2nd round on me :hatsoff:
Reply #352 on: January 12, 2024, 10:49:19 PM
I think a couple of revisions by LTG and this tool would be a superstar.  It's a good solid multitool, and I can testify to it's ruggedness.  I wish they'd have given it another round at bat.  The reviews I've read were almost all positive.  My oldest, Noah, used his in a maintenance job and said it would take a beating and still come back for more.  I really like carrying mine!
I'll take you up on that mug my friend!
Reply #353 on: January 12, 2024, 11:00:38 PM
Reply #354 on: January 12, 2024, 11:03:44 PM
Day 11
 :like:    I was in San Diego's Sea World in '95. Had an awesome time  :dd:
Reply #355 on: January 12, 2024, 11:05:32 PM
Day 12
OHT helped…
Great job and action shots LC  :2tu:
Reply #356 on: January 12, 2024, 11:13:33 PM
It is mounted, and the pliers help to pull over the sheathing protecting the plexiglass as I warmed with a hair dryer.
Now  to select my beauties😁
Reply #357 on: January 12, 2024, 11:15:04 PM
Day 12
Reply #358 on: January 12, 2024, 11:17:20 PM
Awesome displayCase LC   :o
That reminds me... I wanted to look for a Peanut  :think:
Reply #359 on: January 12, 2024, 11:26:16 PM
I'm with you Barry.
It seems these days less and less companies  bother perfecting their products but instead replace it with something new ever so often  :dunno:
Total Receipts: $55.09
PayPal Fees: $3.15
Net Balance: $51.94
Below Goal: $248.06
17%
