Sterling silver scales
z1913 · 15 · 1192
cz Offline z1913
on: November 29, 2023, 09:00:21 AM
Couple month back I bought used Classic SD with Tiffany sterling silver scales.
The knife was in a reasonable condition and I liked both the look and the heft of the knife.
The only issue I noticed was that the scales felt tiny bit out of place (but still firmly attached) and the T&T were difficult to pull out. I assigned it to the softness of the scale material - that the scales got sligtly deformed over time.
But about a week ago the front scales fell off. I tried to attach it back again but I was not able to. I did not want to use too much force not to damage it so I am sending it today to Ibach to service.
But if you ever wondered how the sterling silver scales look from the inside, I am attaching some pictures. I was bit surprised to see the tape/glue resisuals inside it. I do not know if it is factory original or whether the pervious owners removed the scales and re-attached it with the glue (that would explain why the scales were bit off from the beginning).
* sterling1.jpg (Filesize: 63.81 KB)
* sterling2.jpg (Filesize: 54.96 KB)
gb Offline Rizio Il Ghiro
Re: Sterling silver scales
Reply #1 on: November 29, 2023, 09:50:59 AM
Interesting view indeed! Many thanks for sharing!  :cheers:
Reply #2 on: November 29, 2023, 10:30:47 AM
:iagree: :tu:
au Offline Huntsman
Reply #3 on: November 29, 2023, 11:20:04 AM
Hey the rivets/pins look a bit wrong - They seem really flush with the liner - Or is that just an illusion ( ;) ) / the photo?
Also the dimples for the pins in the scale loos like they are filled in - Strange   :think:
cz Offline z1913
Reply #4 on: November 29, 2023, 12:03:14 PM
The pins are indeed flush with the liner - perfectly aligned.
There are no corresponding dimples in the scales. The dots on the scales visible in the picture are just imprints on the glue - probably just a reaction to different material of the pin. I guess they could not use the standard system used for cellidor models (rivet and corresponding hole in the scales) because of the silver? So some kind of glue to atttach it is needed.
I was even thinking whether I did not get a counterfeit here... We will see what Ibach says.
Reply #5 on: November 29, 2023, 04:27:46 PM
Yes.  The flexibility of the material of cellidor and nylon scales (and of course their design) allows them to “pop” (friction fit) onto the rivets.  When more rigid scale materials (e.g. metal, wood) are used, the scales must be attached by other means, such as adhesive (as here) or pinning through the scales (Alox models).
Reply #6 on: November 29, 2023, 04:37:02 PM
Interesting.  Thank you for posting.  I would have thought they'd be glued/epoxied on?
au Offline Huntsman
Reply #7 on: November 29, 2023, 09:45:43 PM
Hmm so how is the knife held together?  ???
The pins aren't just to hold the scales?
I guess they must overlap the holes a little!
cz Offline z1913
Reply #8 on: November 29, 2023, 10:15:45 PM
Hmm, good question - the one not covered by the tape/glue felt fully aligned with the liner. Unfortunately I already shipped the knife for service so I can’t further check. Maybe the holes in the liner are bevelled?
Reply #9 on: November 29, 2023, 10:22:07 PM
If the holes are countersunk, the pins can be flush and still hold the knife together.
cz Offline z1913
Reply #10 on: February 23, 2024, 10:54:15 PM
My Tiffany classic came back from the service today. The scales are re-attached, all cleaned, the T&T are easy to pull out again.
Thank you, Victorinox! What a great service for a total of 75CZK (=3€!).
* IMG_2540.jpg (Filesize: 299.91 KB)
Reply #11 on: February 23, 2024, 11:46:33 PM
Looks great.  Congrats.
Reply #12 on: February 24, 2024, 02:29:56 AM
 :iagree: :like:
Reply #13 on: February 24, 2024, 08:27:05 AM
 :iagree: :like: :like: That’s a lovely looking knife!
Reply #14 on: February 24, 2024, 12:25:19 PM
I would have expected nothing less from Vic, but glad to hear they did right by you.
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $96.97
PayPal Fees: $5.86
Net Balance: $91.11
Below Goal: $208.89
30%
January Donations
