9 Charge Mods and more to come (suit Wave+ as well)
au Offline mbischa
  • EDC-Charge TTi+ w/mods, Bits, Bit Driver & Ferro
on: December 30, 2023, 04:06:54 AM
I have had many SAK, a few Gerber Multitools, and a few Leatherman .
Always wanted a few more tools and finally after finding this forum, I have headed down the Mod path.
My full Mod List so far is as follows, this can be done on Wave+ or Charge Series.
1/ Rebar Awl swapped in place of Large Blade Screwdriver.(Straight Swap)
2/ moved Lanyard Loop to other side of handle.(To make more space near Saw)
3/ Sharpened Chisel end in Serrated Blade also gives space for Lanyard Loop.
4/ fitted titanium spacer tube to Saw end of handle.(To make space for extra removable tools that clip in with lock)
5/ Got removable Titanium Scribe/Pick from aliexpress and lives on spacer near Saw.(and locks in with blade lock)
6/ Tweezers (Leatherman) live under file in Belt Clip slot.
7/ Filed a notch in end cap/spacer allows SAK Toothpick to sit under Main Blade.
8/ Replaced the Hard Wire Cutters for EOD Cutters in Plier jaws so you can cut stranded wire.
     (Hard wire cutters have a flat edge where EOD cutters have a sharp edge)
9/ Already had Hook Blade on Serrated Knife but you can file on Wave Serrated Knife.
...more to come...
- I still have 2mm of space beside the Scribe/Pick, for a thicker version of the scribe/pick with a rounded point as a marlin spike.
- I am looking at colour anodising & laser engraving the scales with a fibre laser.
I find I use the extra tools a lot and together with the Case, Bit Kit, Ratchet Driver Extension the Leatherman kit and Mods get used many times a day.
Leatherman - 4 x Charge TTi+, Charge Ti, P4, Wave+,
    Wingman, 2 x Rebar , Sidekick, Skeletool, Bit Kit Set, Ratchet Driver.
Gerber - Command 1, MT Suspension
SAK - Rescue Tool, Forester
Spyderco - Cara Cara Rescue2 FRN Orange
Mora 748MG green, Companion Spark
Michael - Brisbane, Australia.
us Online IMR4198
Re: 9 Charge Mods and more to come (suit Wave+ as well)
Reply #1 on: December 30, 2023, 12:12:28 PM
Hi Michael,
     Great post and photo.  We like pictures here.  It is a friendly spot on this site.  Very unusual for the internet.  You will see that in time.  Lots of Aussies here, and folks from all over.  Make some friends.  Best wishes.  Gary (IMR)
Reply #2 on: December 30, 2023, 04:19:36 PM
Thats some might fine work.  Love the scribe.  Welcome to MTO.
Offline kimchi
Reply #3 on: December 30, 2023, 06:39:42 PM
Brilliant work, well done mate! Lots more photos would be brilliant if you don't mind, these are some great mods but I can't quite picture how some have been done.
Sent from my SAK using Tapatalk
Reply #4 on: January 03, 2024, 12:25:46 PM
+1
Thanks for sharing.
 :cheers: :tu:
