As mentioned, recessed screws are impossible. That is why I like having a Wera bit holder that works with the cap lifter or any of my other SAKs with inline or back phillips drivers. On the plus side, you can also use the can opener on some Allen head screws and Torx 15 and 20.
Pretty much the only limitation I've found so far has been a slight re-direction of force, resulting in the can opener closing on my fingers.
If they are only slightly recessed, a lot of times the can opener will still work, especially if you angle it a bit. But I agree that deeply recessed screws are the main Achilles heel of the can opener screwdriver. Whether you run into enough of those in your day-to-day to justify carrying a model with a dedicated 3D Phillips is of course an individual decision.If I find myself applying more force, I often choke up and grab the tool (rather than the handle) directly with my thumb and forefinger so that it can’t close on my fingers.If I run across a really stubborn screw, I’ll pull my Alox Bantam out of my wallet, lock its combo tool onto the can opener/screwdriver (or bottle opener/screwdriver) of the 91 mm or 93 mm SAK, and use the Bantam to generate the required torque. It’s the same idea as if you have a screwdriver that has a square or hex shank, you can put a wrench on it if you need the extra torque.
Anyone else ever run into the limits of using the can opener as a Phillips driver? What were your experiences like?
I am going to have to try this technique. Very interesting and I would never have thought about until now...thanks!
