World Driving Tour '24
Poll
What month works for you for a 30 day Challenge?
February
April
May
June
Other?
gb Offline SurgeUk
Re: World Driving Tour '24 Day 19
Reply #360 on: February 19, 2024, 06:42:50 PM
DAY 19
A bit of hinge adjustment on a newly installed front door. The D/F handled it admirably  ;)
They don't like it up 'em!
Reply #361 on: February 19, 2024, 08:37:00 PM
Day 20 of 30
Today needed DF help to remove another door panel. Installed new speakers to it and also tried to fix inside door handle, it wont open door and wire was in place. Gonna continue tomorrow and figure out whats wrong, maybe childlock engaged wrong (yes i checked child lock first)
Only Tools Matters
Reply #362 on: February 19, 2024, 09:46:28 PM
us Offline JonesE
Reply #363 on: February 20, 2024, 02:18:37 AM
Day 20.
Took the day off to start a painting project for my son’s room. Used the CD to remove the switch and outlet plates and drop a light fixture so I could tape it off with some painters tape. Got the primer coat on.
Reply #364 on: February 20, 2024, 03:52:21 AM
The Center Drive is a carpenter's and handyman's perfect tool.  That bit driver is so good!  Having an easily accessible blade doesn't hurt either.
us Offline JonesE
Reply #365 on: February 20, 2024, 04:33:27 AM
 :iagree: On this painting project it has been very useful. I really enjoy the one had deployment on the bit driver. No stopping to insert a dit driver. Just deploy and got to town. The knife blade I mainly use as a scraper, but it occasionally cuts stuff. Just need to remember to sharpen it this coming weekend. I am still struggling with the spring loaded pliers. It has been the one feature after all this time with the CD that I still have a hard time getting use to.
us Offline Rich_SD
Reply #366 on: February 20, 2024, 05:21:18 AM
Day 20
Reply #367 on: February 20, 2024, 06:15:19 AM
WDT '24 Day 20
I discovered the problem with trying to use the DF and the CD interchangeably in this challenge when I nearly broke my wrist this evening trying inadvertently to flick out the pliers on the DF
us Offline David Bowen
  • Multitool Enthusiast
  • Site Manager
Reply #368 on: February 20, 2024, 12:41:06 PM
Day 20
Sent from my SM-G996U using Tapatalk
  • Site Manager
Reply #369 on: February 20, 2024, 12:42:48 PM
Day 21
Dang bronchitis is kicking my butt and it's maybe the last cold snap before Easter
Reply #370 on: February 20, 2024, 01:09:31 PM
I understand that David.  I hope you're feeling better soon!  Cold snap here today too, 16 degrees F.  Been cold here the last couple of days.
  • Site Manager
Reply #371 on: February 20, 2024, 01:20:55 PM
I'll make it @Barry Rowland. It hasn't been too cold this winter but colder than the last few.
Reply #372 on: February 20, 2024, 01:52:40 PM
 :tu: :tu:
Reply #373 on: February 20, 2024, 01:54:37 PM
Day 21: Finally got to use the cat's paw for prying.  It does a great job!  Besides the bit driver, this is the coolest tool on the CD in my opinion.
Reply #374 on: February 20, 2024, 02:11:25 PM
Powernoodle Day 21
I used this scraper thing on the Center Drive to clean Mrs. Powernoodle's shoes.
Reply #375 on: February 20, 2024, 03:34:10 PM
Works every time!
Reply #376 on: February 20, 2024, 04:45:14 PM
The cap lifter on the Armbar Slim would have worked nicely as a scraper too.
Reply #377 on: February 20, 2024, 05:12:24 PM
WDT '24 Day 21
I do like the Center Drive pry tool but it sure does take up a lot of real estate. By comparison the pry tool/chisel/scraper in a Vic Spirit is only a little wider than a standard blade.  The pry tool/chisel/scraper in the Dual Force is ok, I guess, and massive to match the rest of the DF, but it has these funny shallow grooves cut into it, which I can barely feel, that makes it look almost like a file. It might actually have been useful as a file if only Gerber had cut the grooves a little deeper and got the heat treat just right to properly harden it.
 :oops:
« Last Edit: February 20, 2024, 05:18:46 PM by Alan K. »
us Offline Rich_SD
Reply #378 on: February 20, 2024, 05:37:38 PM
Day 21
A little better...
Reply #379 on: February 20, 2024, 05:48:26 PM
Day 21 of 30
Wohoo i was able to fix door lock, lock mechanis was jumped bit over so it didnt open door and i was able to fix it easily. Used DF to remove once again screws from door panel
Only Tools Matters
Reply #380 on: February 20, 2024, 09:31:41 PM
 :iagree: It leaves little room for anything else.  I saw a modder on YouTube remove the pry tool and replace it with a can opener from the MP600.  It's been awhile, so I can't remember what else he put in the freed up space.  It definitely is big for what it's worth..
The Gerber file is okay, but I like the Leatherman and Vic versions a lot more!
WDT '24 Day 21
 :oops:
Reply #381 on: February 20, 2024, 09:32:09 PM
 :cheers: and great pic Antti!
Day 21 of 30
Wohoo i was able to fix door lock, lock mechanis was jumped bit over so it didnt open door and i was able to fix it easily. Used DF to remove once again screws from door panel(Image removed from quote.)
Only Tools Matters
Reply #382 on: February 20, 2024, 09:32:48 PM
 :like: Looking sharp Rich!  :D :tu:
Day 21
A little better...
Reply #383 on: February 20, 2024, 09:34:02 PM
I never saw it before PN.  That's an interesting design!
(Image removed from quote.)  (Image removed from quote.)  (Image removed from quote.)
gb Offline SurgeUk
Re: World Driving Tour '24 Day 20
Reply #384 on: February 20, 2024, 11:50:38 PM
DAY 20
Pretty much the same as yesterday!
Mrs Surge decreed that the spice cupboard door needed adjustment (who am I to argue  :dunno: :twak:)
'twas done
I know my place  :pok:
us Offline Rich_SD
Reply #385 on: February 21, 2024, 12:45:21 AM
Day 21 Bonus Pic
Inception...
Reply #386 on: February 21, 2024, 03:46:07 AM
Cheers Surge! Better keep Mrs Surge happy!
Reply #387 on: February 21, 2024, 03:46:52 AM
Reply #388 on: February 21, 2024, 03:29:53 PM
Day 22: Coming down the home stretch.  I used the pliers to pull out the ash bin from my pellet stove.  It gets it done every time!  About the only complaint I have with the CD pliers are the girth.  It makes it difficult to get a grip on some things.  For example, I wish I had modded mine to a blunt nose configuration when the battery in my car went kaput.  I couldn't get into the terminal but with the CD pliers.  Luckily, a short walk into the station and I found a wrench that fit.  I was amazed we had one to be honest  :facepalm:
Reply #389 on: February 21, 2024, 05:25:31 PM
WDT '24 Day 22
Late breakfast or early lunch hasn't been determined yet, but the CD blade was employed to cut it in half.
