The wire stripper on SAKs 2268
No Life Club Posts: 3,994 Improvise.
« on: March 16, 2007, 03:30:43 AM »
Anyone else find the little notch at the base of the bottle opener a pain to use?  Maybe because I've always used pliers...using the wire cutters to score/cut the insulation, then popping the insulation off from there...but I was just trying it with my Pioneer...cutting the insulation with the blade is a pain also..you don't want to cut TOO deep and have the blade touch the wire...
If that little notch was sharpened (like a single serration), I'd find it a lot easier.
Absolutely No Life Club Posts: 7,580
Re: The wire stripper on SAKs
« Reply #1 on: March 16, 2007, 12:38:42 PM »
I've always preferred using a knife blade to strip insulation.  You evenually get the "feel" of it and don't have to worry about cutting into the wire.  I don't especially like the notch either, and I never use it, but I really like the stripper on the Victorinox Electrician.
- Terry
Head Turd Polisher Administrator Just Bananas Posts: 61,826 Optimum instrumentum est inter aures
« Reply #2 on: March 16, 2007, 01:02:16 PM »
Depending on what I am doing (and bear in mind my frequent disagreements with electricity!) i will cut the insulation with the pen blade, then switch to the stripper notch to pull it off.  Last week I installed a new stereo in my car using that method.  I had to splice a wiring harness to the stereo and I think there were about 20 wires all told, so I cut them all then stripped them all.  Took no time to do and worked like a charm.
Of course, if you are only doing one or two wires then switching back and forth would probably be a pain.
No Life Club Posts: 1,346 Right Wing Psychopath!
« Reply #3 on: March 16, 2007, 02:15:53 PM »
I have used the notch on the SAK quite often when I used to do electronics work.  I found that it will work in a pinch (on small jobs stripping no more than a few wires) but, I always had a wire cutter/crimper/stripper tool in my gear bag and used it for serious work.  Now that I think about it, I might sharpen the notch on one of my SAKs.  It seems like a great Idea.
July Goal: $300.00
Due Date: Jul 31
Total Receipts: $98.19
PayPal Fees: $6.07
Net Balance: $92.12
Below Goal: $207.88
31%
July Donations
Page created in 0.033 seconds with 33 queries.
© 2018 Defender Web & Tool
