Hollow rivet
us Offline Enginears
Hollow rivet
on: January 30, 2024, 05:11:24 PM
Who has done work with the hollow rivet? I want to try it out and was looking at tube stock.
 Is it as simple as cutting the tube to length and bending out/down?
What are the dimensions (ID, OD) of the original soldier hollow rivets?
Thanks in advance.
us Offline tattoosteve99
Re: Hollow rivet
Reply #1 on: January 30, 2024, 05:51:06 PM
We are trying to do the same thing. When I said bail I meant hollow rivet. Now we can both be on this journey together  :cheers:
Re: Hollow rivet
Reply #2 on: January 30, 2024, 06:05:45 PM
Excellent. I have found a lot of tube that is unavailable right now. I am looking at capillary tube that is stainless and it looks to be .9mm thick, which seems too thin? I will hunt around more and update anything I find.
Re: Hollow rivet
Reply #3 on: January 30, 2024, 06:24:46 PM
I have 3 different sizes coming in today and some stainless to make the actual bail itself also. The last one I ordered was to small. It had a wall of .4mm which is to small so I ordered .5 and .6mm wall size. One of those will be the correct size as the .4 was just slightly bigger.
Re: Hollow rivet
Reply #4 on: January 31, 2024, 04:08:40 PM
I have some different sizes coming in tomorrow, and I am going to hopefully be able to piece together a 93mm Recruit. I will keep you posted.
Re: Hollow rivet
Reply #5 on: February 01, 2024, 04:02:13 AM
I’m fairly certain syph made one. I can’t find the thread anymore or even know what to search for  :dunno:
Re: Hollow rivet
Reply #6 on: February 01, 2024, 04:34:45 AM
I'm interested in knowing what y'all end up going with.  I have some SAK-A-Likes that I'd like to fix up a bit but they both use hollow rivets.
Click here for cool free stuff from the Surpise Box GAW!
🏆 🚂 Train Fixer Award
-for most trains repaired using classic
wales Offline magentus
  • mmmmm SAKrelicious
Re: Hollow rivet
Reply #7 on: February 01, 2024, 05:03:03 PM
I did one on an alox Farmer or Soldier quite a few years back now, and used 2.5mm brass. Can't remember the inside dimension but I think it was 0.9mm thick. Cut it to size and used a fluted Allan bit to gently widen the exposed rivet to fill the countersunk scale. Then I used a ball peen hammer to flatten it all out. Took me a couple of tries as it was a tricky process.
Can't find any pics but I believe I sent it to a member of the forum - maybe they still have it and could post pics.....
Re: Hollow rivet
Reply #8 on: February 11, 2024, 09:28:08 PM
Alright so here is my first try.. I was going to do some tests to practice but figured I would just jump in and try this first. It is a 93mm recruit with 2 hollow pins. Turned out functional but quite ugly.
* IMG_6094-compressed.jpg (Filesize: 202.3 KB)
* IMG_6093-compressed.jpg (Filesize: 197.68 KB)
Here you can see one spot where I split the tube as it hammered out and down.
* IMG_6099-compressed.jpg (Filesize: 275.44 KB)
Offline Cleanser
Re: Hollow rivet
Reply #9 on: February 14, 2024, 09:41:34 PM
If you are trying to add a bail - why not peen a bail on (like a 1950s 91mm)?
Re: Hollow rivet
Reply #10 on: February 14, 2024, 10:14:04 PM
Hey cleanser, confusingly enough we have a similar thread going where we are discussing this https://forum.multitool.org/index.php/topic,91934.0.html
I guess I am chasing the hollow rivet because I want to have something lower profile than a permanent bail, like a cord/lanyard directly through the pivot. Add to that I have never been able to have a hollow rivet knife and they seem cool.
Offline kimchi
Re: Hollow rivet
Reply #11 on: February 16, 2024, 10:53:11 AM
I used to make fixed blade knives and the best method I found for making hollow rivets was to cut the tube fractionally longer than required and anneal it. Then find two countersunk headed screws with shanks that fit into the tube while leaving the heads outside and trim so only a short bit of shank remains on each one. Insert the tube into the handle and place one piece of screw in each end of it then slowly tighten in a vice. The countersunk heads will flare the tube consistently and gently so you can get it just right, then carefully file flush. It might be a struggle with the diameters you are talking about here but it does make nice tube rivets if you can find countersunk screws in the right size.
Sent from my SAK using Tapatalk
Re: Hollow rivet
Reply #12 on: February 17, 2024, 01:55:33 AM
That’s an excellent idea. Thanks for sharing! In my thread which is about the same as this one, I have pics of some flaring tools. I might have to give your idea a try.
Offline kimchi
Re: Hollow rivet
Reply #13 on: February 17, 2024, 09:33:36 AM
I should have said, although it's obvious, that the tube hole in the scale needs slightly countersinking too so that the tube has something to flare into
Re: Hollow rivet
Reply #14 on: February 27, 2024, 07:43:31 PM
 :like: :tu:
Re: Hollow rivet
Reply #15 on: March 12, 2024, 02:22:47 PM
Yesterday I posted a sak mod and afterwards had some issues with the scale cracking slightly. I had to take it apart for reassembly and my brass bail broke :twak: it was super thin around the pin.
So I took the opportunity to risk the whole mod and attempt the hollow rivet in a wooden scale. So far it is doing well, I removed the lanyard string for the pics, and will make a bail to clip in soon.
* IMG_6435-compressed.jpg (Filesize: 166.51 KB)
* IMG_6436-compressed.jpg (Filesize: 153.77 KB)
* IMG_6438-compressed.jpg (Filesize: 111.9 KB)
Offline kimchi
Re: Hollow rivet
Reply #16 on: March 12, 2024, 02:45:37 PM
Very nice! How did you fit the rivet?
Re: Hollow rivet
Reply #17 on: March 12, 2024, 03:01:48 PM
Very nice!
Why did the scale start cracking if you don't mind my asking?
Re: Hollow rivet
Reply #18 on: March 13, 2024, 06:00:43 AM
I will post a pic of the tool I made from a broken punch tomorrow, but I sawed off the tube so it was just above the surface, and started slowly working it with the tool to expand it out. Then alternated in hits with my hammer to flatten as it expanded out.
Very nice!
It cracked from the outside at the site of the solid pin. I think I was working with too much material and it mushroomed out too much causing the crack. It immediately had play in the blades and I figured if I kept going it would just shred it. On the fish knife mod it worked so much better with way less material to hammer on.
To start again I epoxied the wood to the scale, and used less material. Crack is visible, but I have no play and everything feels solid. I may wipe some epoxy in the crack just for ongoing security. This probably wont be a heavy user anyway.
Re: Hollow rivet
Reply #19 on: March 13, 2024, 02:31:54 PM
Pic of the tool I made.
* IMG_6446-compressed.jpg (Filesize: 255.22 KB)
