Adding Vic scissors to a Wave/Charge is quite easy because it's a liner lock, which by design is quite forgiving. Getting it to work in a Rebar will be more difficult, as you will have to match the locking mechanism more precisely. However, it should be possible if there is enough material at the tang (which I haven't checked).
Disassembling alox is done like the cellidor models but drilling the rivets is more difficult since they're domed (so the drill tends to slip) and they're harder (nickel silver vs brass and even stainless steel for the center one in recent Pioneer X). I recommend using carbide drill bits and going very slowly (if you slip the drill will go deep in the softer aluminium in no time). The redeeming quality of silver alox is that minor scratches don't show much.
Good luck and keep us posted
