Giants of June/Big Blades Challenge - June 2024
nate j · 209 · 13756
Re: Giants of June/Big Blades Challenge - June 2024
Reply #150 on: June 20, 2024, 08:26:41 AM
Day 19
FX- there is no loop on back, the sheath is meant to be carried in the waist band, the brass stud is to keep the sheath from sliding too far down.
Today's knife is this Philippino Barong.  It is an older knife, a tourist trade knife I believe- it says Philippines on the side.  I believe it has a horn handle.
That's pretty cool.
Handle is probably water buffalo horn.
Day 19
1 of the few knives I have that are made by my father. He's retired from knifemaking for a number of years.
This boot knife is from when he was making Loveless style knives,blade is a little under 5 inches (actual blade length is 125mm).
The handle is African blackwood.
I carry it in a kydex sheath slipped into my waistband.
Sent from my SM-G965F using Tapatalk
Reply #151 on: June 20, 2024, 11:14:40 PM
You're probably right. It's a cool piece! :like:
He did a terrific job on that one! :drool:
Day 20
Both the No. 12 and Old Hickory got to work on a chunk of brisket. Turns out that briskets are kinda unwieldy, so no action shots. Hopefully they turned out okay...I'll find out shortly.
Reply #152 on: June 21, 2024, 05:17:49 AM
Day 18
This is an older (back when they were made in Japan) Cold Steel XL Voyager.
It’s 5” blade is AUS8 IIRC.  It features dual thumb studs, and can also be wrist flicked open when properly lubricated.
I did carry and use this one some.  The steel is pretty pedestrian by today’s standards, but the knife is still a decent quality piece.  And at 5.1 oz, not terribly heavy for a 5”-bladed folder.
It came with a pocket clip for tip up RH carry only, but I got this during my anti-pocket clip phase, so I promptly removed and subsequently lost the pocket clip.
Reply #153 on: June 21, 2024, 05:18:57 AM
Day 19
This is the SOG Spec Elite II.  I’m thinking that its Japanese-made ~5” blade is either AUS8 or VG-10, but it isn’t marked and I can’t recall.
The blade has dual thumb studs, but wrist flicks open easily and smoothly, and locks with SOG’s Arc Lock.
I carried this one a bit, but at 6.7 oz it is a bit brickish in the pocket.
It came with a pocket clip for tip up only RH or LH carry, but I got this during my anti-pocket clip phase, so I promptly removed and subsequently lost the pocket clip.
Reply #154 on: June 21, 2024, 05:21:16 AM
Day 20
This is the Gerber Strongarm.  This less common variation features grey rubberized handles and a 5” blade of BDZ1 steel.
The knife is overall well designed and balanced.  It feels good in the hand, although the texture of the rubberized handle is a bit too aggressive for my taste.
Apparently, someone at Gerber felt compelled to indulge their inner mall ninja and put a “striking pommel” on this knife.
Does anyone actually use these things?  If so, what for?
The sheath is garbage, I’m afraid.  It originally came with more pieces to facilitate multiple mounting options; not sure where those other pieces are now.  With indentations on the sides of the handle designed to engage the sheath, one might expect that the knife would snap securely into the sheath.  However, this assumption is incorrect.  It quickly fails the shake test with only mild to moderate shaking.
I haven’t really carried or used this one, which is too bad because I would like to take it out and put it through its paces.  However, I don’t trust the factory sheath, and haven’t brought myself to shell out the $50+ it would probably cost for a quality kydex replacement.
Reply #155 on: June 21, 2024, 08:05:40 AM
Day 20
Thanks Farmer X
My son and I are building a smoker (for the past few years),maybe we'll actually finish it this year
Reply #156 on: June 21, 2024, 08:07:21 AM
Day 19
I always liked this knife,clean lines,no frills
Reply #157 on: June 21, 2024, 08:15:59 AM
Day 20
This is another Gerber that appealed to me,I haven't pulled the trigger yet.
I agree re the sheath,it seems too much,but,I think,this,and the striking pommel, was for the tactical/combat knife crowd.
Day 20
Another dagger,the Kershaw Trooper,was a gift from my father in 1990,IIRC.
I was gifted 1 other knife by him,a CRK Jereboam (made in SA ),in 88,which I passed down to my son a few years ago. I used to carry that knife,and had an interesting encounter with the police in 1990 or 91 with it
Reply #158 on: June 22, 2024, 01:53:24 AM
I got this during my anti-pocket clip phase...
I'm very much in that phase right now.
Apparently, someone at Gerber felt compelled to indulge their inner mall ninja and put a “striking pommel” on this knife. Does anyone actually use these things?
I've never used one, but mall ninjas do seem to dig 'em. Maybe to crack a coconut open? :dunno: I'd definitely want a more substantial finger guard were I to use the Strongarm's "skull crusher."
The Kershaw Trooper,was a gift from my father in 1990...
Nice dagger! :tu: Hope the smoker gets finished soon, too.
Day 21
It was time to get a fresh can of nicotine pouches ready. The Garberg got the call to shorten the plastic wrap around the remaining two cans in the roll.
The tip of the Garberg's blade proved plenty acute and sharp for this task. And it was easily controlled. Win-win.
Reply #159 on: June 23, 2024, 12:44:00 AM
And here I am again...
Day 22
I used the Old Hickory to cut a dinner-sized piece off the pork tenderloin. I thought I'd gotten an action shot, but I was wrong.
And yes, I put mayonnaise on my French fries. :D
us Offline TexasAKM
Reply #160 on: June 23, 2024, 03:56:25 AM
That's pretty cool.
Day 19
Water buffalo horn!  Thank you!  Good to know.
That dagger your father made is a beauty! :tu:
us Offline TexasAKM
Reply #161 on: June 23, 2024, 04:17:57 AM
Day 20
Brisket...... :drool: :drool: :drool:
 8)
us Offline TexasAKM
Reply #162 on: June 23, 2024, 05:04:47 AM
Day 20
This is a Cold Steel short Seax machete.  Definitely a user.
Reply #163 on: June 23, 2024, 07:47:14 AM
Day 21
thanks Farmer.
yeah,we're taking too many...smoke breaks  ::)
how are those nicotine pouches used?
Reply #164 on: June 23, 2024, 07:47:57 AM
thank you Sir  :salute:
Day 21
The original Sog Seal series is a favorite, I'm fond of military knives,but did not really start a collection (maybe 1 day soon...).
I bought a used "set" off 1 of the knife forums maybe 17 years ago.
My son took the Seal Pup (with kydex sheath) to use as a diving knife when we started to snorkel again,with the aim of starting spearfishing (those plans were scuppered when our city sewage treatment went to smurf causing high ecoli levels in the beaches for miles along Durban's coasts. We had some good dives,but haven't been in a couple years).
I carried the Seal 2K as a diving knife.
I acquired a second,new,Seal Pup a few years ago,this 1 in the nylon sheath.
I think that the Pup is practical for edc and most tasks.
« Last Edit: June 23, 2024, 07:58:06 AM by Humayd A R Mahomedy »
Reply #165 on: June 23, 2024, 06:07:30 PM
Day 22
Trying to take up the slack,today it's the Sog SK2K.
The finish is worn from sand getting into the sheath.
I wear the SK on a separate belt when it's used as a diving knife since,in an emergency, the weight belt is expendable
Reply #166 on: June 23, 2024, 09:02:24 PM
thanks Farmer.
They go between your cheek and gum, just like dip. You can move them around (as I do) or just leave them in place. The fruit-flavored ones can go about 15 minutes, the mint-flavored ones longer. Best of all. there are none of the objectionable by-products associated with tobacco.
I used to have one, and it was a daily carrier for a while. It's a decent enough blade, but my taste in fixies these days runs more toward ESEE.
Day 23
The task was to remove the ribbon from the flash drive. Here's what I started with:
The No. 12 handled the area between flash drive and rivet thing well.
But the area between rivet thing and snap hook...not so much. I probably could have gotten it done with the No. 12, but it was quicker and safer to use a No. 4 instead.
If awl goes well, I will have successfully posted photos while using my PC.
Reply #167 on: June 24, 2024, 09:01:37 AM
Day 23
thanks Farmer.
Day 23
Seal Team 3
I planned on getting a Tigershark as well,but never pulled the trigger. And another SK2K
« Last Edit: June 24, 2024, 09:07:08 AM by Humayd A R Mahomedy »
Reply #168 on: June 24, 2024, 04:47:26 PM
thanks Farmer.
Day 23
Seal Team 3
Nice SOGs!
Reply #169 on: June 24, 2024, 04:50:19 PM
Day 21
This is the Nisaku Yamagatana.  It’s a Japanese outdoor/gardening tool, and a close relative, if not subtype, of the Japanese hori hori digging knife.
It has a 7 1/2 blade of DSR-1K6 stainless steel.  The blade comes to a sharp point and is double edged, with one PE and one SE.  It features an unusual dished cross section, which facilitates using the knife as a spade/small shovel.  It also has depth markings on the concave side.
It is a functional specialized tool, and can be a lot more effective than a spade at digging in harder soils.
Check your local laws if considering carrying one of these, as they might potentially run afoul of blade length limits and or prohibitions on daggers.
The hard plastic sheath is basic but functional.
These are very affordable, typically around $25 - $30.
I do generally carry this one on my hiking pack.
Reply #170 on: June 24, 2024, 08:37:12 PM
Nice SOGs!
thank you sir  :salute:
Day 21
that's a really interesting tool Nate.
i realize that isn't the primary purpose,but what's the cutting capability like?
Day 24
Giants of June,finally.
This Smatchet belonged to a friend of mine,and,some years ago,he asked me to change the molded plastic grip scales for slimmer micarta scales.
I used threaded brass inserts to secure the scales to the tang,and red fibre liners with the scales.
A few years after that,he gifted the Smatchet to another friend,who then gifted it to me after some time.
The lanyard and bead was fitted by the the first friend.
I've never carried this beast,but it was reserved for it's intended purpose with my family,should it come to that,during the July '21 unpleasantries here.
Fortunately it didn't.
« Last Edit: June 24, 2024, 08:45:12 PM by Humayd A R Mahomedy »
Reply #171 on: June 24, 2024, 11:31:58 PM
I can see that being mistaken for a dagger. Looks like it could be a very useful tool, though.
This Smatchet belonged to a friend of mine...
Day 24
The action shot is blurry and probably crap, but today the No. 12 handled the nicotine pouch can wrapper. As expected, it did the job well.
I'm not going through these things all that fast, so this should be the last time y'awl are subjected to them.
us Offline TexasAKM
Reply #172 on: June 25, 2024, 06:53:16 AM
Day 21!
Here are both of my Spyderco Resiliences together.   You can tell how the one on the left has had some rework done.
Reply #173 on: June 25, 2024, 05:09:40 PM
Well, it’s far sharper than a typical shovel, but not a good substitute for a dedicated knife IMO.
Reply #174 on: June 25, 2024, 05:14:23 PM
Day 22
This is the Spyderco Native Chief Lightweight.
It features a 4” blade of CTS BD1N.  The full-flat ground blade is ground thin toward the edge and tip, making this knife a great cutter and slicer.
The point is very acute, which I generally like for functionality/utility, but it’s so thin and acute that I’m concerned about the potential for accidental breakage.
The blade is easy (though not terribly quick) to OHO with either hand due to the recognizable Spyderhole.  I like that Spyderco managed to incorporate it into this design without making the blade a strange shape.  I also find it easy to OHC, by depressing the lock with my thumb and closing the blade against my thigh.
My least favorite feature of the blade is the finger choil.  It’s just worthless, and I would much rather have had the extra sharp edge length instead.
The FRN handle contributes to a low overall weight for its size of 3.1 oz.
The handle is drilled and tapped to facilitate carrying in any position, i.e. RH or LH with tip up or down.  Some people feel this negatively impacts the aesthetics of the knife, but I’m generally more of a function over aesthetics guy, so I think it is good to have these options.  I’ve left the clip in the default RH tip up position thus far.
My only other gripe is that the angle of the blade relative to the handle is too far from 0/180, i.e. the point is too far out of line with the handle.
I’ve been carrying this as my primary pocket knife here at camp for the last several days.  It’s cut up apples, trimmed wristbands, cleaned and whittled my fingernails, and probably other things as well, and I’m fairly pleased with it thus far.
Reply #175 on: June 25, 2024, 05:22:46 PM
Day 23
Two of the knives I’ve previously covered in this thread, the Nisaku Yamagatana and the TOPS Brothers of Bushcraft Fieldcraft, in their usual positions on my pack.
Reply #176 on: June 25, 2024, 09:31:17 PM
Day 24
these posts makes me want to try these pouches  :D
Day 21!
cool shot  :tu:
Day 22
i really dig the Native Chief,thanks for the mini review.
Day 23
nice setup,easy to access.
Reply #177 on: June 25, 2024, 10:02:39 PM
I can spot a few subtle differences. What was done to the one on the left?
I like the lines of the Native Chief. It reminds me a little of an upsized Manix lightweight.
It would probably be a nightmare to ship them internationally. If not, I'll see what I can do when my financial health improves.
Day 25
If the Old Hickory could talk, it would probably tell me it's upset that the next few nights' dinners will be "heat and eat" deals. Naturally, I didn't hear the "instant pot" beep over the roar of the window A/C. Now I have to hope the rice isn't ruined. :ahhh :ahhh :ahhh
Reply #178 on: June 25, 2024, 10:14:22 PM
Day 25
Thanks for the offer man,I'm sure there'll be something similar in the local tobacconists.
Day 25
This was the first custom knife I bought,back when I thought chisel ground tantos were the best think since sliced bread. Think it was in '96.
This knife was made by Stuart Ackerman,it's 1/8 thick N690,10 inches oal with 5 1/4 inch blade.
I'm not sure what the handle is,some sort of black composite or plastic.
I carried this for a few years in a shoulder rig my wife made for me.
I "customized" it,with a convexed top edge,grooved scales,and thumb notch.
Reply #179 on: June 25, 2024, 10:36:11 PM
