Sweet mod
Awesome mod. What size pivot screws you used? Only Tools Matters
I tried to find some pivots in this size without much luck. Is there any chance you could share your supplier or link to where you picked them up? Thanks, Matt
Hi I’m totally fine to share. You can buy at aliex:https://a.aliexpress.com/_opNpiiYYou should buy a set of size 11 and a set of size 16 because the plier side require longer pivot than the blades side.
