Login
Register
Menu
Home
Help
Forum
Tool Talk
Gerber Tools
Repaired Grappler
Repaired Grappler
Trilby
22 ·
2480
« previous
next »
Print
Pages:
1
Go Down
Trilby
Newbie
32
Repaired Grappler
on:
May 28, 2024, 08:22:59 PM
Recently i cheaply got a broken Grappler.
Unfortunately it is a Gen1 Model with the badly designed Part for the Adjustment Screw.
Obviously in a woeful State with the Pliers basically useless
Last Edit: May 28, 2024, 08:56:40 PM by Trilby
Trilby
Newbie
32
Re: Repaired Grappler
Reply #1 on:
May 28, 2024, 08:24:13 PM
I disassembled it and straightened the broken Part
Trilby
Newbie
32
Reply #2 on:
May 28, 2024, 08:26:13 PM
Finally i taped the Hole and bridged the "Chasm" with a short M4 SetScrew
Trilby
Newbie
32
Reply #3 on:
May 28, 2024, 08:31:45 PM
It is perfectly usable again. Only requires a slightly different Technique to retract the Pliers. That big Hole which is now filled with the SetScrew was providing Clearance for the Pin of the ReleaseButton. So to depress the Button fully (to release the Pliers), the Handles have to be opened slightly. No Issue at all
I strongly recommend this cheap Hack for Anyone that has the same Gen1 Grappler. That Part will break sooner or later at the huge Hole for the Pin. Simply filling it with a SetScrew provides the needed Stability for Years to come
Last Edit: May 28, 2024, 08:50:37 PM by Trilby
Trilby
Newbie
32
Reply #4 on:
May 28, 2024, 08:43:07 PM
Perfect Combo
Juan el Boricua
No Life Club
3,742
Reply #5 on:
May 28, 2024, 11:46:42 PM
Congratulations on having such a unique locking pliers and, kudos on a job well done!
Merit Badges
Alan K.
Thread Killer 2019
Absolutely No Life Club
7,744
Reply #6 on:
May 29, 2024, 02:55:12 AM
Brilliant repair! Did you weld in the set screw? It would need something to make the two parts one again.
Merit Badges
IMR4198
5,611
Reply #7 on:
May 29, 2024, 03:11:29 AM
It almost seems like the set screw just provides enough tension to keep the parts in line. He said he cut threads with a tap then just turned in a brass set screw. That would have been tricky. Evidently he got it to work. I don't think I would have thought to repair it that way. Best wishes. G
Merit Badges
Trilby
Newbie
32
Reply #8 on:
May 29, 2024, 09:00:51 AM
Quote from: Alan K. on May 29, 2024, 02:55:12 AM
No Weld, just Locktite and a snug Fit. That SetScrew is not going anywhere and is sufficiently handling the Load when using the Pliers for Light- to Medium-Duty Tasks. I would never trust a Grappler anyway with Heavy-Duty gripping ..
Trilby
Newbie
32
Reply #9 on:
May 29, 2024, 12:37:36 PM
To compare the Changes ..
Here is Gen2 of the Grappler with the Part for the AdjustmentScrew vastly improved. They shortened the Screw and used the free Space to beef up the Part properly.
Pic taken from latest available Grappler Page
https://web.archive.org/web/20111020195924/http://www.gerbergear.com/Industrial/Tools/grappler_31-000333
Page
IMR4198
5,611
Reply #10 on:
May 29, 2024, 12:45:00 PM
Now I know what to look for if I ever run across an old Grappler. Nice photos all around. Best wishes. G
Merit Badges
Trilby
Newbie
32
Reply #11 on:
June 05, 2024, 11:07:28 PM
This is the shoddy Part modeled in 3D, ready to be printed/sintered. Note that this mixes Gen1/2 and requires shortening the AdjustmentScrew quite a Bit (just like in Gen2). Forum does not allow arcane Attachments .. so rename *.stl.doc to *.stl. Sizes in mm. Make sure to look around for resonable Offers. Here in Germany i can get this in Titanium for 100$
Last Edit: June 05, 2024, 11:15:38 PM by Trilby
Barry Rowland
Point Of No Return
30,624
Bon Journee!!
Reply #12 on:
June 06, 2024, 01:32:38 AM
I forgot about the Grappler! The used ones are mighty salty on the used market
Merit Badges
Trilby
Newbie
32
Reply #13 on:
June 07, 2024, 03:37:10 PM
Some minor but important Refinements to the 3D-File. Again, rename *.stl.doc to *.stl
IMR4198
5,611
Reply #14 on:
June 09, 2024, 11:34:25 PM
Trilby, I think you are the Grappler expert. I didn't realize the prices of these things on the secondhand market until Barry mentioned it. Wowsers. Best wishes. G
Merit Badges
Trilby
Newbie
32
Reply #15 on:
June 10, 2024, 02:32:38 PM
Again some minor Refinements ..
Rename *stl.doc to *.stl
Trilby
Newbie
32
Reply #16 on:
June 11, 2024, 12:15:34 PM
Optional v24 with added 2.5mm Hole for a M3x3mm SetScrew to retain the PivotAxle (needs to get threaded) ( M3x4mm will also work)
You can preview these in 3D at
https://www.thingiverse.com/thing:6652755
If You do not need this extra SetScrew, use v22 above
Rename *.stl.doc to *stl
Trilby
Newbie
32
Reply #17 on:
June 12, 2024, 01:42:51 PM
V25 w. smoothed AxleBore from 32 to 320 Faces.
V26 likewise plus the extra 2.5mm Bore for optional RetentionScrew (Thread for M3. M3x3 or M3x4 will fit)
Preview in 3D on
Rename *.stl.doc to *.stl
Trilby
Newbie
32
Reply #18 on:
November 19, 2024, 09:13:13 PM
Freshly printed from Steel in CN. Replaces the broken Part just fine
Trilby
Newbie
32
Reply #19 on:
November 19, 2024, 09:16:13 PM
Requires only very little FineTuning with a small File. And the small Clearance Hole at the Side could be larger. Use DieGrinder or 4mm HSS Drill to bevel it a Bit
Last Edit: November 19, 2024, 09:21:51 PM by Trilby
Trilby
Newbie
32
Reply #20 on:
November 19, 2024, 09:18:53 PM
Old vs. New
Barry Rowland
Point Of No Return
30,624
Bon Journee!!
Reply #21 on:
November 28, 2024, 02:23:42 AM
Great job!!
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
Gerber Tools
Repaired Grappler
May Goal:
$300.00
Due Date:
May 31
Total Receipts:
$21.00
PayPal Fees:
$1.42
Net Balance:
$19.58
Below Goal:
$280.42
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
