Spartan lite, replacing the led
erich · 10 · 1221
Offline erich
  • New User
on: August 01, 2024, 05:01:52 PM
Hi there,
I would like to know if you need to disassemble the knife in order to change the led? Only the 2 cell batteries seem to be accessible by opening the grey led case but not the led itself
Also do you have any reference for led replacement?
Thanks a lot!
Eric
us Online IMR4198
Re: Spartan lite, replacing the led
Reply #1 on: August 02, 2024, 12:16:33 AM
  The LED is in the scales, right?  The scales come off fairly easily.  Just as likely to be a connection as the LED.  Normally you soak the knife in hot water and pry off the scales.  You wouldn't want to do that with the batteries inside.  You could just see if Victorinox will repair it.  Best wishes.  G
 :dunno:
Reply #2 on: August 02, 2024, 12:39:55 AM
Gary's right.  You should be able to pop off the scales gently with another thin blade like from the classic SD.  I just did this on a Microlight Esquire without too much trouble.  If you're having difficulty getting the scale off, you could try putting a hot towel on it to help things a bit.  You could also try using a hair dryer but be careful that you don't get so close to the scales that you melt them.
Offline erich
  • New User
Reply #3 on: August 02, 2024, 07:24:52 AM
Thanks for your replies
No on the spartan lite the led is not on the scale.
It’s is like on the cyber tool lite
Envoyé de mon iPhone en utilisant Tapatalk
us Online IMR4198
Reply #4 on: August 02, 2024, 12:12:22 PM
   So the Spartan Lite has the batteries and LED in a little plastic pod.  Well, who knew?  You can always still send it back to the Ibach boys and girls.
   I hate to see someone who is making his (or her) first post get no answer at all.  So, sometimes I throw out an answer.  If you need to know anything about gold investing, marriage, electric car repair, tarot, or metal bands feel free just to ask me.  I don't know anything about those either but will gladly make up something for you.  Best wishes.  G
Reply #5 on: August 02, 2024, 01:09:57 PM
Disassembly is required. Should be a few threads around, here is one, spartan lite upgrade.
Reply #6 on: August 02, 2024, 01:25:30 PM
Good Gary.   :cheers:
Offline erich
  • New User
Reply #7 on: August 02, 2024, 01:51:28 PM
You made my day
Offline erich
  • New User
Reply #8 on: August 02, 2024, 01:52:32 PM
Thanks for the info and link!
gb Offline Little Tinker
  • If it ain't broke I can fix that.
Reply #9 on: August 02, 2024, 06:50:06 PM
We have ChatGPT for that.
