93mm awl: how to fit in a 91mm
Offline Raphael Vilamiu
on: October 06, 2024, 10:16:14 AM
I saw many times people using the inline awl from the 93mm in their custom 91mm, replacing the small blade.
I measured the awl to be 0.4mm thicker than the blade, which seems to show I need to thin either the awl (1.8mm) or the spacer (1mm) by this amount.
I made a try with the spacer and it got clear that I can't figure out how to do it by myself for lack of skills with tools. And I think thinning the awl would be better, since the spacer would have only 0.6mm in the end.
TL;DR: I'm too dumb to find a way to thin the awl. Can anyone point me out to instructions on how to do it?
us Online lazar
Re: 93mm awl: how to fit in a 91mm
Reply #1 on: October 06, 2024, 01:52:38 PM
I recently fit a 93mm awl into an 84mm.  I thinned it out on a 1x30 belt sander.  Went slow and sanded at different angles to keep it even.  I also shortened it some to fit, peened brass into the pivot hole and drilled new hole with 2.2mm drill bit, and reprofilled  the pivot area.
Reply #2 on: October 06, 2024, 03:30:58 PM
Thanks for the info. If you didn't have one (I don't), do you figure you could do it in some other way?
us Online lazar
Reply #3 on: October 06, 2024, 05:59:20 PM
Maybe lay some sandpaper down and rub the awl back and forth a few million times.
Or you could do away with the spacer/key ring and find a washer/washers in the appropriate thickness.  I've done this on mods that have multiple blade layers.
Reply #4 on: October 06, 2024, 10:15:13 PM
Looks like I need more tools 😬
I guess the washer route could work but that's so less elegant...
us Online lazar
Reply #5 on: October 06, 2024, 11:00:34 PM
Victorinox uses a washer next to the main blade on the Alox Cadets, it's not so bad.
Reply #6 on: October 07, 2024, 03:13:01 PM
I went ahead and used washers. I think it works well.
Thanks for the help!
us Offline IMR4198
Reply #7 on: October 07, 2024, 04:55:44 PM
How about a photo, Raphael?  Some others would love to see what you did.  Best wishes.  Gary (IMR)
 :hatsoff:
us Online lazar
Reply #8 on: October 07, 2024, 06:27:50 PM
Sweet!  You're welcome
 :hatsoff:
We definitely need a pic or two!
Reply #9 on: October 08, 2024, 01:39:04 PM
Sorry for not sending photos before but I was lost with the interface. Here it goes.
Reply #10 on: October 08, 2024, 01:45:58 PM
I only used one 0.5mm washer for the large blade. It should be 0.4mm but I don't have one. You guys can see the back of the liner is a bit strange. That happened when I tried to put the titanium scales on. They bent the liner. I needed to file the pins rings a bit and then they fit. It's a bit ugly but I don't think it affects in any way.
One day when I have a belt sander, I think I'll open the knife and do it correctly. But I live in a flat and don't have much space so, it won't be so soon.
« Last Edit: October 08, 2024, 02:21:25 PM by Raphael Vilamiu »
us Offline IMR4198
Reply #11 on: October 08, 2024, 01:47:07 PM
So nice.  I saw where the liner flared a little.  I don't think things are meant to be perfect.  Good work.  Best wishes.  G
