Short answer is no and long answer no.
1. Surge scissors are allmost same lenght as whole Rebar need to mod whole scissors shorter.
2. Pivot size of Surge scissors are too large for Rebar pivot so you need to fill pivothole and then drill new holes to it.
3. After modding scissors shorter most likely on pivot side you need to drill new holes for pivot and make new spring for scissors since if you shorten it tension will be way different.
4. since Surge pivot size is larger you need to refill pivot and drill new ones.
5. Then there is locking mechanism, it has different locking mechanism than outside tools you would need to think how to make that work.
Conclusion it is way too much work and it may not even work properly afterall, but if you have spare scissors (few spare ones too) , tools, skills and most of all will to make it.
I wouldnt say its impossible but highly unlikely to happen.
Only Tools Matters
