Modified Muji (tool) Pouch
Offline kaevin
on: February 22, 2025, 07:22:50 AM
The goal was to keep the small tools that can help out most of the tasks at home. Putting it to some easily accessible place and the bigger tools to somewhere else.
I got a MUJI Nylon Pouch, and made a cut at one of the middle shallow pocket. Then hand sewn some elastic bands as needed to hold the tools in place without them knocking each other in it.
Leatherman ratchet driver
Vessel double ended bit
Magnet
Heat shrinks
Duct tape and pvc tape on cards
Foam stickers
A set of hex bits with a bit extender modified to be LM compatible
Staedtler Mars Techno lead holder
Leatherman file of Surge
Zip ties
Bahco wrench
Knipex Cobra 125
A ratchet from Sellery
Toughbuilt 5 in 1 (utility knife, pry bar, bit holder, wire cutter/stripper, vessel 65mm double bit modified to 60mm)
Surge (with 2 magnets wrapped in heat shrink for plier spring action)
Engineer PZ-67 (locking plier, screw extraction plier)
Rubicon RVT-212 (a little bit too long but I can bare with it)
Missing a lighter. And may be some electrical, steel wire and some glue. And may be a small tape measure as well.
What do you think?
« Last Edit: February 22, 2025, 07:38:06 AM by kaevin »
Re: Modified Muji (tool) Pouch
Reply #1 on: February 22, 2025, 07:26:22 AM
December Goal: $300.00
Due Date: Dec 31
Total Receipts: $68.48
PayPal Fees: $3.90
Net Balance: $64.58
Below Goal: $235.42
December Donations
