G-Shock GM-S110LB-2A help needed
styx · 6 · 6845
hr Offline styx
on: July 25, 2025, 08:11:48 PM
As the title says, I am in dire need of some help.
My wife's GM-S110LB-2A was found and gnawed on by one of the dogs we are taking care of (long story short, we are fostering 2 4 month old pups). The watch itself is ok, but the strap is ripe for the dump. Now I've found replacement straps that cost close to 50% of what we paid for the watch, but my wife has also expressed an interest in NATO style nylon straps.
Since my knowledge of G-Shock watches is rudimentary at best, I'll appreciate any help
au Offline pietervn
Re: G-Shock GM-S110LB-2A help needed
Reply #1 on: July 26, 2025, 10:16:59 AM
Bugger
You will need strap adaptors if you want to run a nato strap. Aliexpress is probably the easiest and cheapest to check if that will work. Amazon may have a few options too.
This video will give you an idea how they work, it is for a different model though: https://www.youtube.com/watch?v=Feup9XvRwcU
Another good article: https://www.g-central.com/how-to-get-official-strap-adapters-for-g-shock-dw-5600-ga-2100-ga-b2100-gm-2100/
Cheers, Pete
Reply #2 on: August 04, 2025, 04:38:03 AM
You can confirm this for yourself, but I suspect that the lug width of the watch is 16 mm.
One option, as Pete says, is to get adapters (search for “G-shock adapters”) that will connect the watch to a more standard width (usually 20 mm or 22 mm) NATO strap.
A second option may be to get a 16 mm NATO style strap.  This should attach directly to the watch without the need for adapters, but may be a bit narrower than some folks prefer.
A third option might be a third-party strap specifically designed for G-Shock watches, but not an OEM part.  These seem to be pretty reasonably priced.
At the risk of stating the obvious, you’ll want to verify that the strap length is sufficient for your wife’s wrist as well, keeping in mind that the last hole on most straps is some distance from the end of the strap.  Probably not an issue for most people, but I have larger wrists and also don’t like a super tight fit, so I have to be careful when ordering watch straps that I don’t end up with one that is too short.
Please let us know what you decide and how it goes!
hr Offline styx
Reply #3 on: August 07, 2025, 09:29:45 PM
I found an adapter and a Nato strap, they were delivered today and my wife is very happy with the new set up.
thanks guys
Reply #4 on: August 07, 2025, 11:39:18 PM
I love a happy ending!
Reply #5 on: September 12, 2025, 03:10:45 PM
:worthless:
 :pok: :pok:
