Don't break open the piggy bank just save your money, its not worth it
Quote from: duckman1975 on February 20, 2009, 12:50:50 AMDon't break open the piggy bank just save your money, its not worth it You wish Ducky
WOW ...but i thing ill skip this one....i have no money left
Quote from: cliosguy on February 19, 2009, 11:24:58 PMWOW ...but i thing ill skip this one....i have no money left Heh I'm in the same boat as you are
Quote from: donvito on February 20, 2009, 05:01:57 AMQuote from: cliosguy on February 19, 2009, 11:24:58 PMWOW ...but i thing ill skip this one....i have no money left Heh I'm in the same boat as you are welcome aboard
Quote from: MultiMat on February 20, 2009, 01:02:49 AMQuote from: duckman1975 on February 20, 2009, 12:50:50 AMDon't break open the piggy bank just save your money, its not worth it You wish Ducky This means war multiy
Quote from: duckman1975 on February 20, 2009, 01:03:48 AMQuote from: MultiMat on February 20, 2009, 01:02:49 AMQuote from: duckman1975 on February 20, 2009, 12:50:50 AMDon't break open the piggy bank just save your money, its not worth it You wish Ducky This means war multiy The War is over Duckster , I just bought a Charge TTi on ebay for $51us & it is coming from Singapore . I hope I have done the right thing. The seller does not have much of a feedback score & I have over kwackers mod LM's for a long time.Good luck fellas.
As the rather lousy edgeholding on the serrated 420 steel blades always annoyed me, i sent some spare 154CM PE blades through an aquaintance of mine to a German knifemaker called Juergen Schanz, and he serrated them for me by hand, not with some serrating machine as i previously thought.I specifically asked him to try to use the Spyderco pattern as much as possible, as over the years i have found this to be very effective.As you can see in the pictures he did a marvelous job, and the ones already in use not only perform perfectly, they keep their edge notably longer than the standard serrated blades.
I am quite a bit short this month too.. I've bought 5 Charge's this month! I also have a Fallkniven F1 on the way, and a Vic Workchamp.. I just can't afford it right now. Believe me, I want this tool bad; but it's not possible..
