I think it has been repeated many times that Victorinox claims they stopped making 84mm scissors because the machine broke or wore out. This is from a company with many machinists and all the equipment to repair anything in the factory. Victorinox has been bleeding down the entire 84mm line for some time now. Someone decided that there was no need for an 84mm with scissors. It looks like there could be few (if any) 84mm at all in the future. There have been no new 84mm for a while now. Many of the popular models like the Tinker Small and Tourist have been discontinued recently. The 84mm (and the discontinued 85mm Delemont models) are a sign that the mid-sized tools are on their way out. Soon there will likely be nothing available (or very few) between 58mm and 91mm. Is that a bad thing? I suppose the market will decide that. Some would like to see the 65mm, 74mm, 84mm, and 85mm return. Doesn't look like that is in Ibach's plans. Best wishes. G
I'm surprised that 84mm hasn't already gone to alox only like the 93s.
For me, the value of the 84mm line is (1) applications where minimizing size and weight are important, and or (2) there isn’t a corresponding 91mm model.
...... I've always found the cellidor 84s to seem a bit pointless. The size difference between them and the 91 isn't that much ......
While an 84mm with scissors would be a pass for me, I suspect that the cost-benefit analysis (which has certainly been done) may have been a little off.
However doing a cost benefit analysis and rejecting the proposition is valid - If not highly surprising and disappointing for us.
I guess most people are of the same view as you and BP Roberts, that 84mm or 91mm doesn’t really make a difference. One of the main online Victorinox dealers in the UK doesn’t even bother stocking 84mm Cellidor. That’s probably for a reason.
Now if they ever cancel the Alox Cadet, that’s when we march on Ibach with torches and pitchforks.
Indeed, I am thinking of getting a couple of extra Sportsmans / Sportsmen in case of cancellation. I missed the Tourist being deleted and had to hunt round.Now if they ever cancel the Alox Cadet, that’s when we march on Ibach with torches and pitchforks.
