What should my very first multitool be?
ge Offline iamBETTO
  • ןɐʇuǝɯǝƃpnɾ ʇou 'snoıɹnɔ ǝq
on: October 26, 2025, 07:09:01 PM
I am a literal total newbie.
Still doing my research to buy my very first multitool that will hopefully last me a lifetime.
I will probably buy the SURGE.
Maybe I will convince myself to get the ARC, because then I can operate it one-handed.
Operating it one-handed would be a huge benefit for a combat medic in the infantry like myself. Plus, I think it's the sexiest multitool I've seen so far.
But, the SURGE just seems very reliable and robust, so that's why I think it wins the spot for a first multitool for me.
Any thoughts?  ???
Any recommendations?   :dunno:
Try not to overwhelm me.  :D
Re: What should my very first multitool be?
Reply #1 on: October 26, 2025, 07:26:33 PM
Welcome!
I added some details to this question in the Alpha thread.
If considering a SURGE, you may consider looking for a CHARGE new if you can locate one or on the secondary market.
Blades and saw are one hand.  Same as a SURGE. Just lighter.
ge Offline iamBETTO
Reply #2 on: October 26, 2025, 08:39:39 PM
Welcome!
I really like the big scissors, and the T-Shank seems to be very useful.
« Last Edit: October 26, 2025, 09:19:44 PM by iamBETTO »
Reply #3 on: October 26, 2025, 08:52:21 PM
As a medic I would suspect you would have better scissors in your medic kit that can handle the materials required.  The SURGE SCISSORS not great on all materials.
The T-Shank is great for file or a variety of saw types. Again as a medic, unless you are needing to saw a tree branch to clear an area or to amputate still not practical.
I was just looking at it as most practical based on info provided.
The SURGE is a chunk of weight.
I carried a ST300 for several years in construction trades, I preserver my SURGE which is now assigned to my camp kitchen kit.
Not military trained, I do have a daughter who is a RN and has worked ERoom. And a son who is a Paramedic/Firefighter, that also on call as a SWAT medic fully trained for field operations including weapons.
Both use a RAPTOR, but not a MT in their respectful duties.   Just offering insight!  Your needs can be totally different in your world.
ge Offline iamBETTO
Reply #4 on: October 26, 2025, 09:00:29 PM
I do have dedicated tools.
I just want to have a robust and reliable multitool on me at all times not only when I'm out there, but also when I'm at home plan to go out in the woods and stuff.
Edit:
Which Leatherman would you pair with the RAPTOR as the ideal companion?
« Last Edit: October 26, 2025, 09:19:25 PM by iamBETTO »
Reply #5 on: October 26, 2025, 09:10:27 PM
I will give a +1 for the Raptor. My suggestion would be a Raptor paired with another multi-tool (be it knife-based or pliers-based).
I strongly suggest that, since you said you'll be carrying your multi outside of your military duties, you research knife-related laws you must comply with. As an example, some countries make carry of locking and/or one-hand opening blades more trouble than it's worth.
I'm also not sure how secure or durable the Surge's T-shank mechanism is. Some other options you may consider are the ST300/Rebar (though they lack outside opening tools) and the Wave (if you're okay with light-duty scissors in lieu of an awl).
With all that said, I'd suggest keeping your initial investment low and thoroughly assessing what features of your first multi see the most use and which are just "there." Trying new things out is one of the aspects of this hobby that can be really fun.
Hope I've been at least somewhat helpful, and good luck in your quest! :cheers:
ge Offline iamBETTO
Reply #6 on: October 26, 2025, 09:18:10 PM
Which Leatherman would you pair with the RAPTOR as the ideal companion? And why not the MUT?
Reply #7 on: October 26, 2025, 09:21:52 PM
Edit:
I am very biased!
I strongly believe the ST300 is the best heavy duty tool you can have on your belt or in a coat pocket.
I have observed on the Television show, the LAST ALASKANS, and read in a book about him, Hiemo Korth, a real outdoors man living in the Refuge Area of NE Alaska, carries a ST300 and twice after dropping a moose used his tool to draw and quarter his hunt.
And then later use the screw driver to release a band on his barrel to retrieve items stored inside. Also, adjust his carburetor on a snowmobile.
A REBAR is just a smaller ST300.
The BOND is similar, just tools are not locking. The BOND is most like the original PST LM first introduced.
I prefer simple…
Reply #8 on: October 26, 2025, 09:29:43 PM
Any Leatherman that fills your needs would pair ideally with the Raptor. As for the MUT, part of that is because I didn't think of it until you asked about it. My personal preference is for plain or fully serrated blades over combo edges (yet I carry a combo edge 111mm SAK very regularly...go figure!). The MUT has at least a couple of tools that may be too specialized or you may have no use for. And they're one of the more expensive offerings in Leatherman's current line-up.
ge Offline iamBETTO
Reply #9 on: October 26, 2025, 10:27:14 PM
I am very biased!
I prefer simple…
The SuperTool 300 seems to be very limited (and also limiting).
The tools are from the inside, which requires additional time to operate.
I don't like that.
It does look nice, and I'm sure it's really good, but I don't think it's for me.
The recommendation is appreciated regardless.
Thanks for the response.
I wasn't really considering the MUT, I was just curious about what other think about it.
I have medical shears, but you guys helped me discover the RAPTOR which I didn't know about, so I'm going to get that.
Now I need to redo my whole research about the multitool to optimize my loadout with the RAPTOR, and the Glock FM 78 fixed blade that I have.
« Last Edit: October 26, 2025, 10:53:32 PM by iamBETTO »
us Offline genevabuck
Reply #10 on: October 27, 2025, 12:44:24 AM
When in doubt, get a Wave. It’s the #1 selling multi tool of all time for good reason.
Reply #11 on: October 27, 2025, 12:58:28 AM
Thinking you asked about one hand opening, there is one tool Leatherman made that checks every box in that category. It allows you to open te pliers, or more accurately deploy the pliers with a firm flick, out the front, and every implement is located on the outside of the handles. It is the OHT.
Blades, a plain edge, and serrated blade.
A gut hook, a saw, flat blade and Phillips. All tools are liner locking.
I highlighted the handle imprints.
The only downside is the blades are considered short, but to me fully functional. Since you carry a folder you should have no issues.
This is a retired tool, but they are available. Besides Black, they were made in Stainless natural finish and Coyote Tan.
Specs
For years multi-tool users could choose from two distinct options when it came to a "one-hand-operable" multi-tool: one-hand-opening pliers OR one-hand-opening blades. Today, Leatherman has taken these two well-loved ideas and fused them into the first ever, 100% one-hand-operable multi-tool, the Leatherman OHT. This industry-first tool features spring-loaded pliers and wire-cutters so you don't tire your hand adjusting and readjusting your grip. Handles with visual imprints of the tool beneath make for quick identification. A lifesaving strap cutter and oxygen bottle wrench, threading for common-size cleaning rods and much more make this a one-handed workhorse of a tool.
SPECS
Primary Blade Length: 2.37 in. | 6 cm.
Closed Length: 4.5 in. | 11.5 cm.
Weight: 9.9 oz. | 280.6 g.
MATERIALS
420HC Stainless Steel, 154CM Stainless Steel, Black Oxide
TOOLS
420HC Knife, 420HC Serrated Knife, Bottle Opener, Can Opener, #8-32 Cleaning Rod/Brush Adapter, Large Screwdriver, Medium Screwdriver, Oxygen Tank Wrench, Phillips Screwdriver, Saw, Small Screwdriver, Spring-action Needlenose Pliers, Spring-action Regular Pliers, Spring-action Premium Replaceable Wire Cutters, Spring-action Premium Replaceable Hard-wire Cutters, Strap Cutter
Reply #12 on: October 27, 2025, 01:03:21 AM
The other tool I also carry is the VICTORINOX MXBS
The blade and serrated safety blade can both be deployed one handed.
Plus all on board implements are accessible with out having to open the handles.
us Offline Vadim
Reply #13 on: October 27, 2025, 01:04:49 AM
My vote for ST300, the best heavy duty tool.
Just look at the connection of the pliers to the frame, this thing is literally indestructible.
« Last Edit: October 27, 2025, 01:16:12 AM by Vadim »
us Offline ThundahBeagle
Reply #14 on: October 27, 2025, 03:04:58 AM
Sir:  respectfully that's like saying arborists use real saws, and not the surge or 111mm SAK saws.  That's a given.
Surge scissors among the best in the business.
However, yes, you are right.  I have an OG Surge.  One does require belt AND suspenders to keep ones pants up with that on your belt
Reply #15 on: October 27, 2025, 03:11:48 AM
BETTO
Outside of it being a bit on the heavy side, you will not be disappointed with the Leatherman Surge.  I have an OG, 2007 Surge and have not destroyed it yet.
If weight is an issue, the Wave is very good.
My personal preference is that I carry my Leatherman Rebar every day but the Surge is in a backpack or in the truck.  Where you want outside tools the Surge or Wave will do you just fine, but if you need a decent scissors, the wave falls short in my book
us Offline Rich_SD
Reply #16 on: October 27, 2025, 04:00:03 AM
Welcome BETTO   :cheers:
A lot of guys here have a nostalgic love for Leatherman's older multitools, so you'll get a lot of recommendations for those.  While I love the older tools too, the new tools are better on a functional level.  You can open all of the ARC's tools with one hand, and it has a Magnacut blade that will stay sharp longer that almost all other Leatherman blades.  It's a little expensive, but it's definitely worth the price... especially if you're looking for a "one and done" multitool.  That said, you can't go wrong with any of the Leathermans.  They're all outstanding tools.   :tu:
Reply #17 on: October 27, 2025, 04:05:18 AM
Yep, from my experience the TShank saw was short and difficult to cut, but you can upgrade to a better saw blade and change your saw you actually need.
And, yes a 111mm saw cuts very well when I have needed.    On the Surge I primarily left the file in the handle.    And used a OHO Vic or FARMER When I needed to cut grey conduit or wood of. By type when working construction.
And, another yes, 2” straps on my suspenders every day.   ST300 would weigh things down too!  Just less moving parts to track.
gb Offline Crunchie64
Reply #18 on: October 27, 2025, 08:18:56 PM
I think you’d love the Raptor if you tried it.
To pair with it?
Rebar or Supertool 300 are solid and great value. No real downside if you’ve got a fixed blade for quick access.
Want something you can carry every day in the UK? Bond, no doubt.
If you think you’ll still want to buy an Arc one day, just save all the in between steps and buy the Arc.
You’ll save money in the welling run, and you won’t have a drawer full of unused multitools.
If you don’t need hex and Torx bits, and don’t want to risk dropping tiny parts in the mud, try to track down a used Free P4. It might even be better fit you than an Arc.
us Offline Vadim
Reply #19 on: October 29, 2025, 04:01:15 AM
But my Tried and True is my Spirit!
ge Offline iamBETTO
Reply #20 on: October 29, 2025, 11:35:52 AM
I like the idea of replaceable wire cutters, so I think I'll stick with Leatherman.
Although, the Victorinox multitools do look very good, and the curved plier handle is in fact more comfortable...
Still struggling between the SURGE and the ARC right now.
The SURGE has an awl with a hole that will allow me to perform some rope/leather-work, and it's the beefiest of them all also allowing me to do medium-heavy duty work without concerns.
But, the ARC just screams luxury and beauty, and it's also the best one-handed multitool I've seen so far.
Reply #21 on: October 29, 2025, 01:51:33 PM
I'm going to lose a lot of friends with this post, but MTO is all about speaking your mind about tools....
The Surge is probably your best bet, but it's bigger than you think it is.  If you are a larger individual, that may work to your advantage, but if you are a smaller person, I'd suggest getting a Wave or Wave Plus.  I wouldn't waste money on the fancy new tool they are calling the Wave Alpha- it is just like the Charge.
The Charge (and now Wave Alpha) are gimmicks.  I don't know how well that translates for you, but basically the Charge (and Wave Alpha) are just Wave models that they put fancy materials on it so they can charge more money (hence the name Charge) despite it being either the same (or less) functionality.  But you feel good because you spent more on it.  :facepalm:
The titanium in the Charge series (or aluminum or G-10 or whichever version you buy) provides no benefit whatsoever.  It is not actually covering any of the steel so you don't get any benefits from the increased toughness or corrosion resistance of the titanium.  It's not in a significant quantity to decrease weight, and in fact that additional framework required to bolt on a titanium slab actually adds more steel and therefore weight.  Some folks will tell you that the titanium feels better in their hands and I am convinced that those people tell themselves that to justify that they paid more for something that offers no actual benefit.
And the Arc?  Well, that is even more expensive and useless.  I have bought CARS for less than what that thing retails for and I wouldn't recommend it with a gun to my head for someone looking for something to actually use.  It's great for Instagram and showing off to your hipster friends when you use it to pop open a craft brew bear behind the Starbucks, but that's pretty well the end of that.
The Raptor is, IMHO also a waste of money.  It is far too complex and the blades are too thick to get into the tight places that dedicated EMT shears get into.  Further it has too many nooks and crannies (small areas for dirt and grime to accumulate) that it would be difficult to effectively sterilize after use- particularly as a combat medic where you can't quickly wipe it off as you go from patient to patient.  And, as mentioned, it's not cheap and therefore not disposable like a set of issue shears would be, so you are stuck with that dirt and grime forever.
The Supertool 300 and Rebar are both great tools and I would recommend them, but you want one handed opening blades, so that takes both of them out of the running.  Unless you would consider one of them and a dedicated folder, like a Spyderco, Benchmade, Cold Steel, CRKT or similar, which would give you the one handed opening blade you really want.
Concentrating on the one handed opening need, I see someone has suggested the OHT.  Remember that the OHT (or One Handed Tool) says that all of the tools open one handed, and they are right- technically.  Realistically, the pliers are ambidextrous and the rest of the tools either open with the right hand or the left, but not both.  So while you only need one hand, you can really only access half the tools with that one hand.  You will have to either use your other hand to access the others or switch the hand holding the tool.
Or course, some of our in house lefties are going to point out that they can contort their hands in such a way as to access all of their tools, but that's not the point- as a combat medic it has to be easy to access or it's useless.  Adrenalin dumps and fine motor skills don't go together.
The Victorinox Spirit and SwissTool (all versions of each) are great choices, but suffer the same issues as the Rebar and SuperTool 300- you will still need a one handed opening knife because they don't have one handed opening functions.
So, after crapping on pretty well everything here, what would I actually suggest?
Well, I think you were on the right path with the Surge.  It's a good tool.  If you want pretty well all the function of the Surge at a more reasonable price, look up the Bibury 17 in 1 tool which is very similar to the Surge, but about 1/3 of the price.  The Surge is better, but not 3 times better.
But remember the Surge (and Bibury) are both big, heavy tools.  If you want to go a bit lighter, go for the Wave or Wave Plus.  Similar design, but in a more normal size and weight.
I would also suggest having a look at the Gerber Center-Drive.  It's bigger like the Surge but not quite as heavy and the pliers, knife blade and screwdriver can all (actually) be deployed with one hand.  Provided you are right handed anyway.  And, it takes standard bits- I don't know what the availability of Leatherman's fancy flat screwdriver bits are in Georgia, so that may be a concern.
Good luck and be safe out there.
us Offline Vadim
Reply #22 on: October 29, 2025, 02:57:50 PM
And remember, the Leatherman Surge is a multi-tool that only has a metal file on board or a wood saw (both very short for the size of the tool itself).
To carry a file/saw, you should always carry a sheath with you or put the file/saw somewhere else, which means a great chance to lose it.
And the most funny part is, when you need a wood saw at the right moment, you are surprised to find that there is a file.
« Last Edit: October 29, 2025, 03:07:40 PM by Vadim »
Reply #23 on: October 29, 2025, 03:39:48 PM
I agree with Grant, the Gerber Center Drive is a very capable tool that might suit your needs very well.  Unless you feel that you should have a saw in your multitool.  The Center Drive doesn't have a saw.  The Surge is heavy and has a lot of capability, but it might be more than you need, and it has removable parts which can get lost.  I'd skip the Raptor since you already carry the medical shears.  Because you already carry a knife and shears, you're clearly seeking the tool to do everything else, and the Wave may be a better choice than the Surge because it is a little smaller and has less removable parts.
If you'll forgive me for making your search even more confusing, there is a thread in the general forum about favorite combinations of multitools with Swiss Army knives and you will see that a lot of us do carry both.  It's adding one more item to your kit, but you can exponentially increase capabilities without too much redundancy if you carry the right pair of tools. For example, I might carry a Leatherman Sidekick because it has the pliers, a one hand opening blade and a saw, with a Victorinox Mountaineer because that has a file and scissors.  Here's a link to that thread. https://forum.multitool.org/index.php/topic,7543.0.html
Or you can simply carry any Swiss Army Knife that has the right tool set for your needs and a real pair of pliers such as the Knipex Cobra.  Of course, we all understand and appreciate that nothing is really going to impress your buddies more than that big Surge or the latest development from Leatherman, the ARC.  If any of us doubted that we wouldn't be here.  If any of your friends have multitools or if there is a shop where you could handle them before you buy one that could be better for you than the opinions of strangers on the internet.  Best wishes on your search.
ge Offline iamBETTO
Reply #24 on: October 29, 2025, 04:08:09 PM
Thank you for dedicating your time for this awesome post.
I have a some questions, if you don't mind, about Leatherman SURGE vs. Bibury Pro.
• How does the Bibury Pro's 3Cr13 steel hold up to heavy abuse (e.g., wirecutting or splicing 550 cord under stress) vs. Surge's 420HC? Any failures after 6+ months heavy use?
• Do the replaceable cutters last as long as Surge's?
• Is it as bulky as the Surge?
• Bibury as a "beater" spare vs. Surge as a "lifetime" investment - worth the $100 savings if it quits after a year of duty?
• Warranty reality: Bibury's Amazon returns vs. Leatherman's 25-yr lifetime - any horror stories from clones failing mid-op?
• Surge or Bibury for mixed duty/bushcraft?
us Offline Rich_SD
Reply #25 on: October 29, 2025, 04:36:01 PM
I’ll amend my recommendation for the ARC. If you’re not going to really use the tool, I’ll agree with the folks above me about not buying one of Leatherman’s more expensive tools; however, if you plan on using it almost daily like I do, then the premium features of the ARC are more than worth the price.  Magnacut blades are far more than just a gimmick.  They hold their edge much longer than 420HC blades, and much MUCH longer than the soft steel Victorinox uses.  I use the crap out of my blade, so it’s nice to not have to sharpen it so often.  Also, one hand opening is extremely useful if you use your tool a lot.  If you don’t, then just buy something pretty and/or less expensive.
A couple folks recommended the Gerber Center Drive.  If the screwdriver is 100% the most important tool for you, then I’ll agree with them - either the Center Drive or the Dual Force.  Otherwise, there are better options. Personally, I don’t use either very much because they’re horrible for pocket carry - something very important to me, but not others.
Finally, if you’re on a budget and are not sure a premium tool is right for you, there are a lot of knockoffs that are pretty decent.  Grant recommended a Bibury, so that might be a good option too, especially if you’re not sure how or how often you’ll use your tool. If you wait for a sale on Amazon, you can get one of those for $40 or less. They even have one hand opening blades!  At six times the price, is a Leatherman ARC 6 times better than a Bibury?  That really depends on you - your needs and resources.  During my lean years, I would never buy something like an ARC over a cheaper but functional alternative.  Still, cheap tools have a place in my life. They’re perfect for punishing jobs that could likely damage your tool. I use mine to cut rat poison on concrete and to submerge in muddy water when working on my irrigation. They’re also perfect for when your friends or neighbors ask to borrow a multitool - I can hand them something that I don’t care if it gets lost or damaged :rofl:
ge Offline iamBETTO
Reply #26 on: October 29, 2025, 04:43:41 PM
I’ll amend my recommendation for the ARC. If you’re not going to really use the tool, I’ll agree with the folks above me about not buying one of Leatherman’s more expensive tools; however, if you plan on using it almost daily like I do, then the premium features of the ARC are more than worth the price.  MagnaCut blades are far more than just a gimmick.  They hold their edge much longer than 420HC blades, and much MUCH longer than the soft steel Victorinox uses.  I use the crap out of my blade, so it’s nice to not have to sharpen it so often.  Also, one hand opening is extremely useful if you use your tool a lot.  If you don’t, then just buy something pretty and/or less expensive.
I carry the Glock FM-78 fixed blade on my vest, so I'm not concerned about the multitool blade.
The 420HC on the SURGE seems to be enough, in my opinion.
Am I wrong?
The pliers, wire cutters, blade, saw/file, and the awl w/ needlehole are the things I actually need.
The ARC doesn't have a needlehole on the awl, so leatherwork won't be possible with it.
How moddable are the Leatherman multitools?
Can I just put the needlehole there myself?
us Offline Rich_SD
Reply #27 on: October 29, 2025, 04:56:48 PM
Am I wrong?
No, if that’s what’s right for you and your needs, it’s the right answer.   :tu:
If a needle hole in the awl is important to you, I would consider the Wave Alpha instead of modifying the ARC - but that’s just my preference for Magnacut talking which you said you don’t need.  Still, the Wave Alpha’s scissors are excellent.  ;) :D   All of that said, the Surge seems like the best option for you.
Reply #28 on: October 29, 2025, 05:02:43 PM
If that is your concern, then just maybe the simpler solution would be the SIGNAL! 😉
It come in several different colors, plus includes a diamond file (removable), fire starter, and end of handle is good for pounding in tent stakes and removing with carabiner.
ru Offline madfishcat
Reply #29 on: October 29, 2025, 05:16:10 PM
rebar/swtool spirit
They are very easy to modify, especially if they are 20 years old :)
It's simple: you use electrical erosion to destroy a metal surface, make a hole with a drill, and remove sharp edges with a reamer. Or you cut a groove with a grinder and close it with welding, then polish it and you're done. There are many options, it all depends on the strength of your desire :)
December Goal: $300.00
Due Date: Dec 31
Total Receipts: $105.48
PayPal Fees: $6.12
Net Balance: $99.36
Below Goal: $200.64
33%
December Donations
