Amazing transformation, J2000E!May I ask for the details on your ultrasonic cleaning procedure? Time, temperature, and preferred cleaning agent?Thanks,Myron
Long nailfile on the back of the scissors moved to the other side compared to the older 246fmaU
No problem at all Myron. I use hot tap water to begin with and on top of that my ultrasonic cleaner heats the water. My tap water is about 50 degrees Celsius (122 F?) and I do not believe the cleaner heats it up to more than maybe 60. I can still pick up things and if it would be more than 60 I would not be able to do that... Time is somewhere between 5 and 20 minutes depending on what kind of dirt we are talking about.And the secret detergent is.... YES (Fairy in the rest of the world I believe). edit - a healthy amount of detergent - about 1 dl to a litre.The above works great on those watch bracelets too... ;-) There are nasty things living in watch bracelets... If people knew!On bicycle parts I pre wash with cold/solvent degreaser but that has never been needed on multitools. Yet.
I'm probably missing something obvious here. But what do you mean?Nice pics
