Yemao YM-M28 Tactical Flashlight.
on: April 12, 2026, 09:35:27 PM
I just received this flashlight today and my first impressions are fairly good.
PXL_20260412_181550987A by Chako, on Flickr
PXL_20260412_181604629A by Chako, on Flickr
I am gravitation more and more away from traditional round bodied flashlights to the rectangular shaped flashlights that fit in a pocket better and don't roll around if you decide to lay it on a flat surface.
Included is the flashlight, a rubber lanyard, a USB-C charging cable, and a tiny instruction sheet that required my needing a magnifier to read the small print.
PXL_20260412_181644184A by Chako, on Flickr
The flashlight is mostly a solid cream coloured plastic body with black textured side panels. There is an included pocket clip. On the front are 2 LED bulbs. 1 is warm and tends to give you a wider illumination pattern. The other LEDv is a blue spot light. There is also a COB light on the front side that also has a red LED and a very anemic UV light.
PXL_20260412_181729012A by Chako, on Flickr
The one side has the USB-C charging port behind a rubber door.
PXL_20260412_181743402A by Chako, on Flickr
PXL_20260412_181854883A by Chako, on Flickr
The back side has a nice big pocket clip. You could use the clip both ways...pocket up or pocket down.
PXL_20260412_181759485A by Chako, on Flickr
A better look at the wide warm beam flood LED and the cold blue spot LED.
PXL_20260412_181836268A by Chako, on Flickr
On the tail end are the 2 switches. One for the forward facing main LEDs. The second button controls the side firing COB display.
PXL_20260412_181843777A by Chako, on Flickr
There are 3 levels of light for both flood and spot. Pressing the main button with a long press switches from flood to spot and back again. In either mode, a quick press of the main button will give you a lower light level, etc... There is also a tuirbo mode that fires both front facing lights for maximum power.
Here is the warn flood function.
PXL_20260412_181917069A by Chako, on Flickr
Here is the cold spot function.
PXL_20260412_181933909a by Chako, on Flickr
Pressing the other button controls the side COB light. There are 2 levels of intensity of this function. If you long press, it will rotate the white light to a red LED. If you press 1 time when the red LED is active, you will make it blink. Pressing 1 more time will give you a very weak UV light.
PXL_20260412_181957139a by Chako, on Flickr
PXL_20260412_182013548a by Chako, on Flickr
PXL_20260412_182108066a by Chako, on Flickr
Here is turbo mode showing both front facing LEDs firing.
PXL_20260412_182149625a by Chako, on Flickr
My thoughts:
Pros:
- I really like the formfactor of this flashlight.
- The use of 2 buttons makes using this flashlight easy enough.
- Press the main button and you will get the warm flood light at maximum power. Long press to get the maximum power spot light.
- Pocket clip is versatile.
- Battery power gauge is easy to read.
- COB light is fairly strong and gives you 2 levels of power.
Cons:
- Lanyard is a cheap rubber that is semi stretchable.
- Red light is very strong and might not be good at keeping your night vision.
- UV light is anemic.
- Still somewhat complicated but not as bad as some other flashlight offerings out there. Getting to the UV function can be mildly entertaining.
- If you quickly triple press the COB light button, a brief green icon will flash on the battery gauge, and you lock down the flashlight. Pressing that button another 3 times unlocks the flashlight. I managed to lock myself out a few times fiddling with the flashlight.
Overall:
I really like this flashlight. For its price, it hits way above what you would expect.
Re: Yemao YM-M28 Tactical Flashlight.
Reply #1 on: April 13, 2026, 02:32:31 AM
Nice write up!
Reply #2 on: April 13, 2026, 02:40:06 AM
 :hatsoff:
Reply #3 on: April 15, 2026, 03:40:39 AM
I am EDCing this flashlight and this is what I have found thus far.
- Not happy with the button placement on the end. When I try to press one button, I find that my big fingers will tend to press both.
- The battery does run down quickly. Charging appears to be almost as quick as discharge during use.
- Wish the flashlight would remember the settings better. It remembers if you last used either flood or spot, but not at which level you last used.
- This is personal preference but I wish the spot and flood functions started at its weakest beam first. Instead it starts at medium then full, and last on weakest.
- Not sure why they included a UV function. Not only is it fiddly to activate, but it is so weak to be useless.
- The shape is excellent and it feels solid in the hand.
- Pocket clip is rather stiff and difficult to use on a pocket.
- For the price, I feel it is good value despite it's shortcomings.
Reply #4 on: April 17, 2026, 05:31:46 AM
Garbage pickup tomorrow morning so I decided to bring this flashlight out with me tonight to bring the bin to the road. The more I use this flashlight, the more I dislike the dual tail buttons. I once again pressed the side COB tail button by accident and got blinded by the side light right into my eyes.
It depends on how you hold it. If my thumb has to reach over to the far button, then both will get activated. This is really bothering me. The light it throws is powerful enough, but dual activation when not wanted is a PITA as you spend some time turning the one light off.
The price is still good for what you get, but not enjoying using this light at first press in the dark.
Reply #5 on: April 17, 2026, 01:35:33 PM
While I generally think two-button interfaces are quicker and more intuitive to use than single-button interfaces for multi-mode lights, it sounds like this one has a significant design flaw.
Reply #6 on: April 17, 2026, 03:03:24 PM
That or there is a significant design flaw in the user.  :rofl:
Total Receipts: $10.00
PayPal Fees: $0.69
Net Balance: $9.31
Below Goal: $290.69
 3%
