Updated: March 5, 2009 11:11 HRS
PRICES REDUCED
ADD $3 for shipping and handling to prices shown for USA delivery
ADD 4% for PayPal - MO's and personal checks OK
The Spyder Adventura folding lockback knife is futuristic and fastidiously engineered for high performance and a distinctive look. PlainEdge VG-10 blade is hollow-ground with an unsharpened swedge-grind up top. VG-10 steel is similar to ATS-34 with added Vanadium, Molybdenum and Cobalt. Back-lock and Spyderco Round Hole are positioned to facilitate easy single hand deployment.Oblong slots in blade and handle diminish weight.
# Filing on the blade crown keeps thumb in controlled contact with blade
# Left/right, tip-up/tip-down adjustable pocket clip
# Clip has rounded, tapered end to stop wear and tear on pockets
# Blade: 3-¼"
# Open: 7-½"
# Closed: 4-¼"
# Weight: 3.8 oz.
# Material:
# Blade: VG-10 steel
# Handle: Stainless steel
Sell for $75
The Flash II ( FSA-6 ) Knife is New In Box
Sell for $27
http://www.amazon.com/gp/product/B00020BNYK****************************************************************
Spyderco’s stainless steel A.T.R (At The Ready) comes well-heeled with high-tech tactical features and is fully coated in non-reflective Black Carbon Nitride. Drilled out of the stainless handle and clip are a series of holes. The holes lessen the folder’s weight and make position spots for the thumb and fingers to index the knife into different grip-holds. The integral Compression Lock, locks open the blade by using part of the handle scale using fewer moving and wearable parts. Tip to tang the blade with a snub-nose that cants upward becoming thicker at the tip for extreme and strenuous use. The hollow-ground blade has an additional dagger-grind down its center effectively balancing both sides while simultaneously enhancing tip strength. Unlike a traditionally ground dagger, the spine is non-sharpened. Positioned above the Spyderco Round Hole, a Cobra Hood™ juts a flange of steel out, over either side of the blade, guiding the thumb into position over the hole for rapid, by-feel, deployment.
SPECIFICATIONS:
Blade Length: 3 7/16''
Length Closed: 5''
Overall Length: 8 1/2''
Weight: 5.4 oz.
Blade Style: Modified Clip Point
Blade Finish: Black TiN
Edge: Serrated
Blade Steel: VG-10
Rockwell Hardness: 59-61
Locking Mechanism: Compression Lock
Handle Material: Stainless Steel
Liners: Stainless Steel
Fittings: Stainless Steel
Pocket Clip: R/H or L/H, Tip Up
Country of Origin: USA
SELL for $92
New In Box - Spyderco C88SBK Salt 1 Knife, Black FRN Handle, Rustproof H1 Steel Blade, SpyderEdge. $53
New in Box - Spyderco C24GPS Blackhawk - G10 - GIN1 s/s blade $99
New in BLUE Box - Spyderco C13PS Pro Ventor - stainless steel handle with inlaid Draton for non-slip grip, stainless steel clip & fits almost any hand. G2 s/s blade. Overall length is 6 5/8" & the blade length is 2 5/8". $67
New in Box - Spyderco Navigator C62BLS $52
New in Box - Spyderco Navigator C93S ( #115V) $47
New in Box - Spyderco White Goddard C18WMPS $95
New in Box - Spyderco Gray Goddard C16PSGY (#115V) $82
New in Box - Spyderco White Delica C11PSWH $47
New in Box - Benchmade 530 Pardue Plain Edge/ Satin Finish Blade/ Noryl GTX 830 Handle Scales/ Ambidextrous Dual Thumb-Stud, Made in USA $57
New in Box - Benchmade 520 Presidio - Plain Edge/ Satin Finish Blade/ Black Aluminum Bi-Directional Grip Handle Scales/ Ambidextrous Dual Thumb-Studs, Made in USA $111
New in Box - Benchmade (H&K) #14700BX - Plain Edge/ Black Oxide Blade Finish/ Black Aluminum Handle Scales $87
New in Box - Benchmade (H&K) #14750BX - Plain Edge/ Black Oxide Blade Finish/ Black Aluminum Handle Scales $82
INOVA BOLT #2L LED flashlight ( lightly used, no box ) $30
http://www.brightguy.com/products/Inova_Bolt_2L.phpADD $3 for shipping and handling to prices shown for USA delivery
TRADES: a Paladin 540 - SureFire LED's ( NO MODS ) - SOG PPP - NIB Charge TTi with leather sheath
