That's gonna be a tough one. I haven't had much luck mixing parts from 111mm knives and 91mm knives. The backsprings aren't compatable and the tang widths are different. It would be a lot of tinkering to get it to work. The double spring setup on the cybertool will make it even more fun. Maybe try to get the cybertool to work with one of the 111mm springs and keep the larger format. Going smaller with the OH blade will be a challenge.
Or if you wanted to go slimmer you could: get rid of the bottle opener, can opener, and small blade, and put a combo tool in place of the small blade. The combo isn't such a good pry bar as it is thinner than the bottle opener.
I can't add anything except another....Yikes!
[P.S. If I can't get a cybertool driver in there, then are there any small x-head screwdriver tools available? I guess my main needs from the bit driver are large x-head (replace corkscrew with one), small x-head (not sure - any suggestions?), large flat head (already there) and small flathead (the one that screws into the corkscrew won't really cut it - anything else available like the electrician driver?)
Quote from: Gareth UK on March 03, 2009, 02:20:48 AMOr if you wanted to go slimmer you could: get rid of the bottle opener, can opener, and small blade, and put a combo tool in place of the small blade. The combo isn't such a good pry bar as it is thinner than the bottle opener.Thanks, Gareth. Just out of interest, what's the combo tool? Not seen that before I don't think?<edit> - just seen it. 84mm combined slim bottle opener/flat driver/can opener - the curvy one?.P.S. If I can't get a cybertool driver in there, then are there any small x-head screwdriver tools available? I guess my main needs from the bit driver are large x-head (replace corkscrew with one), small x-head (not sure - any suggestions?), large flat head (already there) and small flathead (the one that screws into the corkscrew won't really cut it - anything else available like the electrician driver?)
I think you could start with a Hercules http://www.sakwiki.com/tiki-index.php?page=Hercules and swap the blade for a OHO and the saw for a metal file, would that bring you close to what you want? This may be where I have to bow out as I haven't modified a 111mm knife before and I don't want to give bad advice.
