A "how-to" for basic SAK mods. Pic heavy.
Gareth · 165 · 118310
Re: A "how-to" for basic SAK mods. Pic heavy.
Reply #30 on: March 12, 2009, 11:52:48 PM
I use Araldite - works a treat.
I have used Araldite as well.
Reply #31 on: March 12, 2009, 11:57:25 PM
What the heck is Araldite? ???
Reply #32 on: March 13, 2009, 12:02:47 AM
It's a poxy that comes in 2 parts, glue and hardener that you mix to make a super strong adhesive.
Reply #33 on: March 13, 2009, 12:10:29 AM
That would be epoxy, right Ben? :D
Reply #34 on: March 13, 2009, 12:13:02 AM
 :oops:
Poxy means something quite different huh.  :D
Reply #35 on: March 13, 2009, 12:13:57 AM
 :oops:
Lol. Maybe you're right, maybe it's a poxy epoxy? :D
Reply #36 on: March 13, 2009, 12:22:34 AM
 :oops:
Actually I think it works quite well myself.  :think:
Reply #37 on: March 13, 2009, 11:17:53 AM
Keep in mind that if you use epoxy you are not going to be swapping the scales again ('tis good stuff).  For our friends across the pond there is Goop.  Over here in the UK I quite like TimeBond Bostick.
Neil
Reply #38 on: March 14, 2009, 02:57:38 AM
Let's not forget our good friend JB Weld :D best cold weld epoxy out there :cheers: It mixes together from 2 parts as the Araldite but once the scales are on they probably ain't ever coming off again :o :D
gb Offline Magic Bus
  • Ruler of the E01 society!!
Reply #39 on: April 09, 2009, 09:47:00 AM
Like the others said Gareth, brilliant. Thanks. I'll be having a go at this sometime  :)
Gabba gabba hey!!
spam Offline zepla
  • Where is all that water coming from?!
Reply #40 on: April 26, 2009, 11:32:52 AM
Not into SAK's myself but I have to say that's a great tutorial  :tu: Even I got it!  :D ::)
Offline DannyZRC
Reply #41 on: May 03, 2009, 10:50:23 AM
is there a good resource for layer construction? a compendium of sorts?
it can be a bit difficult to divine exactly how the various tools go together from photos on the net, some things are quite obvious but other things can be quite difficult (like what backside tools play nice with what layers)
scotland Offline Nikos
  • Why is it doing that?
Reply #42 on: May 03, 2009, 12:18:51 PM
That would be really great! Not only would it help wannabe SAK modders, it would also help seasoned mod guys with those pesky "clients" requesting all sorts of bizarre and weirdo tool combos... ::) :D
Reply #43 on: May 03, 2009, 12:46:46 PM
It's a good idea, let me think about it.  What I'll try and come up with is a list of tools that can be used with no modification to the parts themselves and that will fit perfectly.  For example you can put a chisel in place of the awl but the chisel is slimmer and won't be a perfect fit.
Reply #44 on: May 03, 2009, 01:14:55 PM
OK so the very basics for a 91mm SAK are:
Main blade:
Opposite; small blade, combo tool or very rarely electrician and pruning blades (only currently found on the Master Electrician or Gardner or the XXVT?)
Back tool; corkscrew or Phillips screwdriver.
Metal saw/file:
back tool; small chisel, small flat screwdriver or plain backspring with no tool.
Wood saw:
Fish scaler/ruler: plain backspring with no tool.
Scissors:
Back tool; parcel hook, parcel hook with nail-file (only from the Compact) or plain backspring with no tool (older SAKs).
Pliers: plain backspring with no tool.
Magnifier:
Opposite;  in-line Phillips or White LED.  The layer can be a combination of any two of the three tools.
Back tool; plain backspring with no tool.
Cap lifter:
Opposite; can opener
back tool; awl.
This is the basics, there a plenty of tool layers out there that I haven't listed as I have no personal experience with them, I'm sure chaps like Spork or NKB could add to this.
As you can see without re-grinding tools or producing a less then perfect fit your options are a little more limited than people might wish for.
Reply #45 on: May 03, 2009, 01:47:06 PM
Main blade:
Opposite; small blade, combo tool or very rarely electrician and pruning blades (only currently found on the Master Electrician or Gardner or the XAVT?) Watch opening blade (from the Bantam frame) also fits if redrilled to 2.5mm, Divot repair tool from Golfer II, Small screwdriver from Automobile (anyone stripping such a rare knife for the tool will face the Budgies of Pain)
Metal saw/file:
Wood saw:
Scissors:
Back tool; parcel hook, parcel hook with nail-file (only from the Compact) or plain backspring with no tool (older SAKs). Some old SAKs also have a long nailfile on the back of the scissors, again they're rare so think twice before stripping.
Magnifier:
Opposite;  in-line Phillips or White LED.  The layer can be a combination of any two of the three tools.  Old style magnifier and phillips do not work on the new backspring.
Cap lifter:
back tool; awl.
Spatula: nothing on the back
Lighter: nothing on the back
Nice list Gareth. I've muddied the waters a little in blue above.  I've probably missed bits as well.
Neil
Reply #46 on: May 21, 2009, 04:26:53 PM
I was asked about the 84mm over on SOSAK so here is the list to the best of my knowledge.  Off the top of my head the 84mm is pretty easy. Again this should just be tools that don't require any reshaping to make them fit.
main blade/rounded tip blade
Opposite: Combo tool, small blade, small clip point blade (retired and from fairly old SAKs), nail file, watch opener, electricians blade, cap lifter (very rare, it was used before they came up with the combo tool)
back: corkscrew, Phillips or plain backspring.
Saw blade.
plain backspring.
Scissors (retired tool)
plain backspring or long nail file (this is rare so think twice about stripping one if you have it)
Cap lifter
opposite: can opener
back: awl or plain backspring.
Metal file (again an old and rare tool so only to be used for modding if the rest of the SAK is ruined, OK?  :))
plain backspring.
This also doesn't cover the Pocket Pal form of SAKs as I've never worked on one.
Anyone please feel free to jump in if I've made any glaring errors or missed anything out.
« Last Edit: May 21, 2009, 05:26:25 PM by Gareth »
Reply #47 on: May 21, 2009, 08:25:20 PM
Most useful chaps, thanks :tu:
I'd like to add that you can put other things on the back of the blades if you use a scale and liner which isn't cut out - an awl for example. It's a bit more fiddling around but it you don't want the corkscrew/phillips option it gives other possibilities :)
Reply #48 on: May 21, 2009, 08:28:08 PM
You're quite right you can do that, but it isn't quite a perfect fit is it?  Without looking isn't the awl a touch slimmer than the corkscrew?
Reply #49 on: May 21, 2009, 10:32:00 PM
Yep, tiny bit thinner but I got away with it on a 2-layer. Not sure how well it would work with anything thicker. Are there other backtools that are any thicker that would fit?
Reply #50 on: May 21, 2009, 11:20:00 PM
There's the hook.  Its OK width wise but its tang is a fraction too shallow which can lead to lack of snap.  If you could weld a tiny blob onto it that's all it would take to make a really good fit.  Alternatively you can just thin out the awl a tad.
Reply #51 on: May 21, 2009, 11:40:52 PM
Welding?! Oh my, not more skills I must acquire :O
spam Offline John
  • Avatar removed by request
Reply #52 on: July 04, 2010, 08:11:58 PM
Thanks Gareth I'm deff going to mod my compact now,just add an awl and saw I think,yes I said saw  ::)  :D I just need to know what liners to use and where to place the saw in the compact now  :think:
ca Offline Stirling3749
Reply #53 on: January 26, 2011, 05:57:16 AM
Can the awl go on the back of the file or saw? too thin perhaps?
Reply #54 on: January 26, 2011, 10:19:26 AM
You can thin down an awl to fit but its easier to sharpen a flat driver into an awl :)
us Offline Pacu
Reply #55 on: January 26, 2011, 08:55:50 PM
sooo how do you mod alox? Taking off the scales would be the major hurdle i gander.
I do like Nuphoria's copper cadet with scissors  :drool:
:like:    :MTO:
Reply #56 on: January 27, 2011, 12:12:22 AM
Ah yeah I meant to say "too thick?" as it does seem quite a bit thicker.
I think I'm going to go with your approach, just found some nice info on the SOSAK forums. thanks. :)
Offline ryanrrx
Reply #57 on: January 27, 2011, 07:09:06 AM
Here is a little “how-to” guide to a basic SAK mod on a 91mm cellidor knife, although most of the ideas are the same for other sizes as well.  I suspect ever modder has a slightly different way of doing things but this is the way that works for me with only a few basic tools, as can be seen in the first pic.
First thing to do is to pop off the scales from your donor knives.  I use an old SAK with a fairly blunt small blade and slip it under the scale.  Move it up to just behind the pin and pop the scale up.  Repeat for the other two pins.
Next you are going to drill out the pins.  You can see here that I start with a centre mark on the pin head to act as a guide for the drill.  After taking the pic I realised the mark was a bit off and so did it again.
Now all you need to do is drill out the pin.  I use a 2.5mm bit.  Take care not to drill too much and damage the bushes.  For the pin holding the back tools I do a very little drilling and then file the rest of the head off.  All you need do then is punch through the pins to release the tools and backsprings.  Remember and take note of which is the centre bush as it is smaller than the other two.
Now you will have a pile of bits and there is no going back.  Take this opportunity to give all the tools, liners etc a good clean.  Most of the time a bit of a scrub with a scour pad will do the trick.
A quick shot here to show the new and old liners next to the blades.  On the new liner (top) you can see an indent that will sit next to the blade tang.  This is to compensate for the slimmer tang that can be seen on the newer blade next to it.  The most important thing you need to keep in mind is not to mix up old and new parts.  They won’t work and the blade will sit wrong in the finished knife, striking the top of the small blade.  Ask me how I know.  ::)
The next thing I do is to prep up the new pins.  If you can get pin stock that is 2.5mm for the outside pins and 2.2mm for the centre ones (2.25mm is the Vic standard but I don’t think anyone has yet found a supplier).  I always give myself plenty of extra length to work with.  If you look at the pin sitting on the vice you can see the “peak” left after having cut it to size with a pair of snips.  You need to file this flat to give a nice even surface to work on.
Take a small hammer and peen over the edge to give a nice, flattened, mushroom shaped top.  Repeat the filing and peening for all four pins.  The last part is to lightly file the other ends of the pins to a slight point.  This will help in getting the tools and liners to slip over the ends.
You can now put the bushings on the peened end of the pins (make sure the bushes are sitting the right way up) and put them through the full liner.  I always start from the opener side and work up to the blades.  This lets the SAK sit flat without rocking on the corkscrew that sits out quite a bit.  You can also keep a made up SAK near to hand as a reference, just to make sure you are putting things in the right place.
As I don’t use a jig of any kind you will almost inevitably come across the problem of getting the tool to sit well with the spring.  Don’t worry; get all but one of the tools sitting where they should be.  One of the tools will end up sitting like the saw below, that's OK just drop on the next liner.
I have had to do the next bit with two pics, simply because I don’t have an extra hand to hold the camera.  Hold everything together with one hand as seen in the first pic.  You can see the tool sitting beside the spring instead of on top of it.
With the other hand put a fine screwdriver or similar between the pin and the spring.  Leaver the spring away from the pin and keep strong pressure on with the other hand.  When you remove the screwdriver everything should pop into place.  Repeat this for all the layers.  You may find this tricky at first but with just a little practice this takes no time at all.
We are now on the home straight.  :)  When you have the blade layer in place (don’t forget the spacer next to the small blade), along with the last liner, we need to look at the final peening.  Drop the bushes onto the pins.  You will now need to cut the pins to length.  Try not to make the pin to long, you only need 1-1.5mm to work with.  Once cut you will have the same nasty tool marks as you did when prepping the pin.  As before you will need to file the top flat for a good surface to work on.  Once you have it ready then give it a couple of strong taps while holding the SAK on a flat metal surface.  I use one of the flats on my vice as an improvised anvil.  Use the ball-peen to help work the edges of the pin out to fill the bushing.  You can see the three stages here: the far right pin has just been cut, the one next to it has been filed and the one on the far left has mostly been peened.
The MOST important thing is not to over do it.  Keep checking the tools for any side play, once it has gone stop hitting the pin!  If you still have any metal sitting proud of the bushing then file it down (the scales won’t go on it you have to much there).  Once you have cut, filed and peened all the pins give the tools a last check over for any play and pop the scales on.  Job done, you are now the proud owner of your first mod.
As I said at the start there are certainly other ways of doing this.  This way works for me, but if I have made any glaring errors (either in the modding or the writing) please jump in and say so.   Thanks for reading.  :salute:
i love that saw wow it looks beffy wowzers..
Reply #58 on: January 27, 2011, 07:45:57 AM
No argument there Ryanrrx. Vic saws are the best for their size.
Offline ryanrrx
Reply #59 on: January 27, 2011, 08:03:07 AM
ive never seen one like that
i serioisly wana mod that into my skeletool or style cs
i doubt it will fit thoe
