Login
Register
Menu
Home
Help
Forum
Tool Talk
The Mod Squad
help with a knife - from chisel to V
dan.mandiel
9 ·
2092
« previous
next »
Print
Pages:
1
Go Down
dan.mandiel
Jr. Member
85
i need a surge :cry:
on:
October 22, 2014, 01:12:58 PM
hey guys, this is my first post.
i wanted to ask you experts, how do i reprofile a chisel ground knife into a V ground?
i dont have any access to sharpeners and diamond stones and those things, i do have a belt sander.
that knife has also a serrated part and its really dull and if anyone cant tell me how to sharpen it without a diamond rod that'll be great. Thanks
- Ok sir, we've found this good multitool without scissors-
-scissors.
- but sir, we figured it might not have scissors but it does have almost everything you need for a good price! -
- scissors.
- but sir..-
- sci. ssors.
ducttapetech
Zombie Apprentice
18,707
Whiskey Tango Foxtrot, over.
Re: help with a knife - from chisel to V
Reply #1 on:
October 22, 2014, 01:25:00 PM
Do you have any old sharping stones and files?
Merit Badges
dks
Absolute Zombie Club
21,692
Bored
Reply #2 on:
October 22, 2014, 01:57:18 PM
In theory you just need to sharpen the flat side of the edge (the one with no grind) until you have two equal grinds on both sides.
I have used a belt sander to produce an edge and is not the most accurate process.This will be easier on a larger blade and you really will need to further improve your edge with some other sharpening system, like stones.
It can be done, slowly, and whilst making sure that the blade does not overheat (guts burned or gets too hot, over e.g. 250C) as this will damage the heat treat.
You need to check the blade for grind and temperature very often, as it will be easy to grind more than you need.
I found that, for the finishing part, having the tip of the edge of the blade against the belt movement, (the tip of the edge fighting the belt in a way) gave me better control and I could see the edge forming better. However this will depend on how your belt sander is set.
Use a less aggressive sandpaper as this will help you grind gently and give you a smoother, nicer, edge. Also, as some sparks may fly make sure you do not have any flammable material close by.
For the serrated part I would use a round file.... but I very rarely sharpen serrated blades.
Knife threads
Country shopping guides
Battery-Charger-Light threads
Picture threads
Merit Badges
ironraven
No Life Club
3,071
American Clandestine Materials Executive (ACME)
Reply #3 on:
October 23, 2014, 01:33:41 AM
How big is it and how much time do you have to kill?
Your best bet is going to be to do it by hand. A file will let you rough in, but too roughly in my experince trying to put real edges on junky throwing knives. Sandpaper, starting 200 and working towards 1000 grit, either tacked down or on a clipboard, is my recommendation if it is a smaller blade. A marker will help you see what you're doing better as you remove the ink. If you want a convex bevel, put a peice of craft foam or a mouse pad between the paper and the clipboard.
Then just start working at it. Outside is good. Audio books will help, or movies if you can be sure you can keep metal filings out of the electronics.
AimlessWanderer
Zombie Apprentice
17,517
I'm not a pessimist, I'm an experienced optimist!
Reply #4 on:
October 23, 2014, 08:34:56 AM
You'll need to take quite a bit of material away to reprofile it (see attached sketch). As others have said, you'll need to be careful not to get the blade too hot and affect the hardness. Take a nice steady approach to avoid overheating or chipping the edge
Bah! I hoped that would have shown as an image ... oh well ...
Reprofile from chisel grind.doc
(Filesize: 27 KB)
pfrsantos
23,214
Oxygen and magnesium toghether?! OMg!
Reply #5 on:
October 23, 2014, 01:14:36 PM
Having a belt sander is a good help. You just need to get a support to keep the blade at an angle. See this video, it might help.
Cupboard
No Life Club
2,017
Reply #6 on:
October 25, 2014, 02:30:59 PM
this is 50ft-trad's picture:
If you want to do it by hand it is possible and you can get diamond stones pretty cheap. The only problem you might find is something like the Leatherman Squirt's blade is actually fully chisel ground, it's not just the final grind.
(Filesize: 21.4 KB)
AimlessWanderer
Zombie Apprentice
17,517
Reply #7 on:
October 25, 2014, 03:24:31 PM
Thanks Tom
Mike 56
No Life Club
1,698
Reply #8 on:
November 01, 2014, 07:33:22 PM
Buy a sharpmaker sharpen the blade normally just a few extra times on the flat side of the blade when you sharpen it will re profile the blade a little at a time. The sharpmaker will also do a good job on the serrated part of the blade.
Mike
Mike
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
The Mod Squad
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$152.99
PayPal Fees:
$8.68
Net Balance:
$144.31
Below Goal:
$155.69
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
