What light did you carry today?
ca Offline buggs
Re: What light did you carry today?
Reply #2580 on: May 19, 2021, 09:38:45 PM
That's why I bought it. I wanted an output similar to an incandescent, but incandescent lights are harder to deal with; due to lack of battery life, and the fact bulbs with regular use, need to be changed regularly.  It's brighter, the battery lasts longer; there are no bulbs to change every couple of weeks, and it doesn't get hot after extended periods as much.
Cool, thanks for the response.   :hatsoff:
Offline Scorpion Regent
Reply #2581 on: August 22, 2021, 12:01:55 AM
Streamlight Stylus Pro USB.
us Offline parnass
  • 4x4 since '74
Reply #2582 on: December 08, 2021, 04:28:04 PM
I used this Streamlight Protac90 while browsing a dimly lit antique mall. Some of the overhead lights were off making it difficult to view the merchandise.
Retired engineer, author.
us Offline NutSAK
Reply #2583 on: May 17, 2022, 06:33:36 PM
A couple of favorites on me today.
Malkoff MDC w/VME and M61NL drop-in.  4000K Luminous SST-20 95 CRI
Peak LED Solutions Eiger. 4000K Nichia 219B 95+ CRI R9080
The Peak is a fantastic little task light that can be easily clipped to the brim/bill of a cap for use as a headlamp.  15 lumens for 4-5 hours on a Eneloop AAA.
The Malkoff is great for the more infrequent tasks requiring more output. 200 lumens for 2.5 hours on a 1000mAh 14500.
Both are made in the USA and will survive just about anything you can throw at them.
« Last Edit: May 17, 2022, 06:57:54 PM by NutSAK »
- Terry
Reply #2584 on: May 18, 2022, 03:39:13 AM
Nice pair!
The Peak Eiger is now on my list. The Maglite Solitaire doesn't have enough power for a go-to light, and my problem with Olight is that they are made in China. At $50, the Eiger isn't as expensive as I thought it would be.
wales Offline GearedForwards
Reply #2585 on: May 18, 2022, 05:17:20 AM
Nice pair!
Just curious, how come on the Olight thing, I thought you had quite a few?
us Offline NutSAK
Reply #2586 on: May 18, 2022, 07:49:35 AM
Nice pair!
I'm a long time fan of Peak, having owned their products for about 20 years, but I'm not much a fan of their use of QTC to offer variable output.  My opinion is that the decision to use QTC in their lights took them from one of the most reliable, indestructible lights ever made to one of lesser reliability.  So, I order mine as a single output light without QTC rather than variable output with QTC.  This can still be done, but since they're not advertised this way any more, you have to know what to ask for, and special order them.  If you're interested in that, I can send you a document Peak published years ago about the single-level options.
With that said, a high CRI light like this is what you're looking for if you're trying to get the visual accuracy that your incandescent solitaire provides.
« Last Edit: May 18, 2022, 08:16:16 AM by NutSAK »
- Terry
andorson
  • Guest
Reply #2587 on: May 22, 2022, 12:43:40 PM
I don't Carry Flashlight, but if I carry a flashlight, I must choose Fenix UC35 For its look and Brightness.
ph Offline Zephon
Reply #2588 on: June 03, 2022, 02:03:53 PM
Got something new in my pocket here. I’ll be trying out the Lumintop Frog this weekend. The default 10180 battery only lasted 3 days so I’m hoping the 10440 would last longer.
us Offline charlie fox
Reply #2589 on: July 28, 2022, 02:44:48 PM
Old Faithful today
"Never pick a fight with an old man. If he's too old to fight, he'll just kill you."
us Offline NutSAK
Reply #2590 on: July 28, 2022, 07:12:25 PM
That's a cool light!  I really like how those can eat multiple cells.  It would be a really good one to store in a vehicle with lithium 123s and/or AAs.
I like having a headlamp in vehicles also, and the reversible clip with a ball cap will take care of that need as well.
- Terry
Reply #2591 on: July 30, 2022, 05:21:08 PM
I have become a huge fan of those light clips that can attach to a cap.  A headlamp or even angle light is another good option.
ph Offline Zephon
Reply #2592 on: August 01, 2022, 11:12:16 AM
I was using the smaller HS10 and kinda drained the battery in just a couple of sessions. I now plan to try and use the HS40 - first with a small 18350 battery and if it’s not enough, go full size to 18650.  I’ve found the headlamps quite convenient especially when I need better illumination and need 2 hands to work on something.
My only gripe on the HS40 is the tint leaning towards green.
Reply #2593 on: August 12, 2022, 07:27:53 PM
Old favorite 4/7s ATOM A0 Titanium.  I got it specifically for the red led.  I put the red lanyard so I can remember its a red led.
Reply #2594 on: September 07, 2022, 07:33:28 PM
Carrying this Manner E02 with Nichia led.  Its a great light that really needed to be carried more.  I had it in a pack but changed it for something else.
Reply #2595 on: September 08, 2022, 08:56:16 PM
Streamlight Microstream USB.  What I like about this one, and its larger brother the 2xAAA, is the simple user interface and the stiff clicky that rarely activates accidentally.  On this USB flavor, the light body slides apart to reveal a micro USB charging port.  I have found the Microstream series to be highly reliable.
Reply #2596 on: October 30, 2022, 04:48:15 PM
For a light that is around 15 years old, this Fenix L0D Q4 is still a perfectly acceptable keyring light.
no Offline nakken
Reply #2597 on: October 30, 2022, 05:24:21 PM
Very nice :tu:
I have been carrying the Seeker 2 for work the last few days. It's a bit larger than the ones I've previously carried, but what a torch!
Reply #2598 on: October 30, 2022, 06:26:17 PM
Very nice :tu:
Looked up the specs on the Seeker 2.  That's a lot of lumens in a handy size.  :tu:
no Offline nakken
Reply #2599 on: October 30, 2022, 07:10:58 PM
Cheers Gareth :hatsoff:
I failed to mention that this is the pro edition, so it has a bit more (3200 lm). I rarely use the highest setting though, because it gets burning hot :ahhh
Reply #2600 on: October 31, 2022, 03:13:09 PM
They sure picked the right name for that light!
I don't hesitate to carry a light with me ever.  Just the other day as I was getting ready to leave I added a second light to my work carry.  Sure enough I ended up using it to better see in an area that is shaded.  I always have my Auroa key chain light but the light I added was my Zebralight.  Sorry no pics.
As the time will be changing soon I am rarely without 2 lights.
no Offline nakken
Reply #2601 on: November 04, 2022, 11:21:07 AM
Carrying this tiny Blocklite with my PST today
Reply #2602 on: November 04, 2022, 01:48:16 PM
I've been carrying the excellent Rovyvon Aurora A28 recently. It has a nice, stiff clip so its pretty secure in the pocket.  I attached an O-right for easy grabbing.  It has 4 levels of output, plus 2x floody LEDs on the side of the light, and a UV light.
https://www.amazon.com/dp/B0811SRKXR?ref=nb_sb_ss_w_as-reorder-t1_ypp_rep_k0_1_11&amp=&crid=31J85V05NN47I&amp=&sprefix=rovyvon+a28
Reply #2603 on: November 04, 2022, 03:11:35 PM
 :tu:  I carry the A5 and its been a terrific light.
us Offline NutSAK
Reply #2604 on: November 04, 2022, 04:22:31 PM
These Rovyvon lights have a proprietary replaceable battery pack that includes the circuit board?
- Terry
Reply #2605 on: November 04, 2022, 05:38:05 PM
Built-in LiPo battery is rated at 330 mAh and yes I'm assuming its connected to the circuit board. The 3rd Generation Auroras converted over to USB-C charging which has me very tempted to get the newer generation.
edit, theres also a magnetic tail on the G3 which is another plus for me.
us Offline NutSAK
Reply #2606 on: November 04, 2022, 06:33:47 PM
Here is an example of the replacement unit for the A29: https://www.batteryjunction.com/rovyvon-ra20-replacement-batt-a23.html
I'm very much against proprietary parts like this in any equipment I use.  I'll except in in disposable items to a degree, but not something I plan to use for many years.
- Terry
Reply #2607 on: November 04, 2022, 07:37:01 PM
It's a compromise, by moving away from standard batteries it enables different designs and form factors. This isn't to everyone's tastes, but does serve a purpose.
Reply #2608 on: November 04, 2022, 08:06:37 PM
I'm willing to buy a new light in 2030 when this one conks out.
Reply #2609 on: November 04, 2022, 10:03:17 PM
 :tu:.  I don't imagine battery life expectancy to be terribly short ( whatever that means ).  I fully understand what you're saying tho.  Rough look at equivalent batteries, they are rated at 500 charge cycles.  Once they get to 80% tho they are said to be at their end lifespan.  Considering heavy usage of charging 2-3 times a week which for me is not anywhere near my usage its hard to know exactly how long it'll last.  My guess is 3-5 years to get the battery to 80%  :dunno:.  Again just a total random guess.
Again I fully understand what you're saying and tend to agree but this light is pretty great.  When it dies maybe I can replace battery/PCB?
Appreciate your thoughts and comments.
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
