SAK Lanyard..?
AHB · 34 · 5821
wales Offline rp252
Re: SAK Lanyard..?
Reply #30 on: June 20, 2009, 09:59:12 PM
Has anyone tried non flame based heat sources, like an electric hob for example?  That could give a very clean paracord melt.
Re: SAK Lanyard..?
Reply #31 on: June 20, 2009, 10:06:10 PM
If it's not a loose end then I melt it with a hot knife blade. So, as you can see on the first two, after I trim the ends flush to the fob I heat an old SAK blade and use it to seal the cut cord.  It's just a way of not melting the areas you don't wan't to.  The far right one you can see that I used an open flame and melted the cord next to the bit I was trying to seal.
Re: SAK Lanyard..?
Reply #32 on: June 20, 2009, 10:37:18 PM
Tried it with a heat gun (man's hairdryer :P )  That worked.
Re: SAK Lanyard..?
Reply #33 on: June 21, 2009, 02:22:55 AM
I have a little Vic Alox thing that I use for sealing paracord. I heat it up on the gas hob then cut the paracord. Seals it nice and neat without making a mess.
