hex bits set?
Magnus · 12 · 2785
Offline Magnus
hex bits set?
on: December 17, 2009, 10:18:55 AM
does anyone know where you can get a hex bit set, something like this, but in standard bits that are compatible with the SOG bit adapter?
edit: or failing that, even just a bit holder that is similar and can be belt/pocket carried.
« Last Edit: December 17, 2009, 10:25:45 AM by Magnus »
no Offline Medic82
Re: hex bits set?
Reply #1 on: December 17, 2009, 10:36:33 AM
You can buy one from SOG if you want http://sogknives.com/store/QTR-SKT.html
Or at any hardware store
Offline Witmen
Re: hex bits set?
Reply #2 on: December 17, 2009, 04:57:38 PM
I make a sheath that holds a multi tool and a hex bit set.  The sheath has one compartment for the tool then a small pocket for a bit holder,  The bit holder has slots for 7 bits and a bit adapter.  It increases the usefullness of a SOG by a whole bunch when you can carry bits with you.
Re: hex bits set?
Reply #3 on: December 17, 2009, 06:18:45 PM
Pics please  :pok: :D
I bought a cheap set from a DIY store I think and then cut it down to contain the 6 I actually wanted to carry with my SOG.
no Offline Medic82
Re: hex bits set?
Reply #4 on: December 17, 2009, 06:38:48 PM
He posted some pics here http://forum.multitool.org/index.php/topic,13585.0.html
Offline Witmen
Re: hex bits set?
Reply #5 on: December 17, 2009, 06:50:21 PM
Thanks medic,  I actually make them slightly different then that now.  That one is still my personal EDC setup,  But the sheaths I make for customers is different.  I will post pics of the current model here shortly
« Last Edit: December 17, 2009, 07:26:47 PM by Witmen »
Offline Witmen
Re: hex bits set?
Reply #6 on: December 17, 2009, 07:22:13 PM
First of all forgive the horrible cell phone pics.
This is the bit holder and bit adapter
This sheath can also be used either horizontally or vertically.
Offline Magnus
Re: hex bits set?
Reply #7 on: December 19, 2009, 07:27:17 PM
I will bear your product it mind Witmen, unfortunately I am not a fan of nylon sheaths.  It does give me some inspiration however.
Offline ecfiffer
Re: hex bits set?
Reply #8 on: December 24, 2009, 12:50:39 PM
wow dude that looks friggin sweet!  good job!
Offline Magnus
Re: hex bits set?
Reply #9 on: December 28, 2009, 12:05:51 AM
I guess I should have asked this in the first place, but, do the leatherman bits actually fit into the SOG bit adapter?  or is the recess not deep enough?
gr Offline boleneger
Re: hex bits set?
Reply #10 on: January 29, 2010, 11:06:07 PM
The L/M bit does not fit in the original SOG bit adapter. A as you say the adapter is not deep enough and left me screw the bit with the pliers   :rant: .I bought a bit adapter from the hardware  for 2.5 euros and it was perfect.
Re: hex bits set?
Reply #11 on: February 01, 2010, 04:23:13 PM
Magnus,
I'm not sure what you are trying to do  :think:
Is this any good to you?
Its left over from a screwdriver kit
I can drop it in the post if you need it  :salute:
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
