That looks really good Zed! I have got to remember to start taking pictures of my mods and builds as I do them. I did a Vic Classic in wood scales a couple weeks ago and I should have posted it. Next one for sure!
Quote from: gadgetguy35 on March 26, 2010, 01:23:14 PMThat looks really good Zed! I have got to remember to start taking pictures of my mods and builds as I do them. I did a Vic Classic in wood scales a couple weeks ago and I should have posted it. Next one for sure!cheers mate, and yes post them up i need ideas
Quote from: Zed on March 26, 2010, 01:27:04 PMQuote from: gadgetguy35 on March 26, 2010, 01:23:14 PMThat looks really good Zed! I have got to remember to start taking pictures of my mods and builds as I do them. I did a Vic Classic in wood scales a couple weeks ago and I should have posted it. Next one for sure!cheers mate, and yes post them up i need ideas For my first wood scale mod, I kinda cheated. I took a cheap freebie SAK classic knock off with wood scales that were way too big, and I sanded them to fit a real classic. I had to reprofile the ends and adjust the cutouts so it was like starting a mod halfway through. It ended up ok, but nothing to write home about. I then proceeded to disassemble a Vic Camper, cleaned it, and reassembled it as a Spartan. It worked very well except I over peened the backspring tools rivet, so they bind slightly. I am practicing more and more. My very first mod was a Cybertool 34 turned Supertinker with cyberdriver in it. Rotokid had to fix that one, as I had no spare pinstock and no real idea of what I did wrong.
Quote from: gadgetguy35 on March 26, 2010, 03:23:36 PMQuote from: Zed on March 26, 2010, 01:27:04 PMQuote from: gadgetguy35 on March 26, 2010, 01:23:14 PMThat looks really good Zed! I have got to remember to start taking pictures of my mods and builds as I do them. I did a Vic Classic in wood scales a couple weeks ago and I should have posted it. Next one for sure!cheers mate, and yes post them up i need ideas For my first wood scale mod, I kinda cheated. I took a cheap freebie SAK classic knock off with wood scales that were way too big, and I sanded them to fit a real classic. I had to reprofile the ends and adjust the cutouts so it was like starting a mod halfway through. It ended up ok, but nothing to write home about. I then proceeded to disassemble a Vic Camper, cleaned it, and reassembled it as a Spartan. It worked very well except I over peened the backspring tools rivet, so they bind slightly. I am practicing more and more. My very first mod was a Cybertool 34 turned Supertinker with cyberdriver in it. Rotokid had to fix that one, as I had no spare pinstock and no real idea of what I did wrong. I wouldn't worry about it mate, it's all a learning curve. With a little more practice you'll get a good feel as how much more peening is needed. Until then: hit-check-hit-check-hit-check-hit-check-etc. It takes a bit longer but you shouldn't end up with binding tools that you'll want to re-do.If it bothers you, you could always just remove the one pin. Neil did a good guide here;http://forum.multitool.org/index.php/topic,9057.0.html
That is genius! I just checked out Neils walk through, and I think I will try it on my spartan as soon as my pin stock arrives from Tom in the mail. the mod I am getting back from him has a back spring Phillips that I want to swap for a corkscrew, problem is, the knife is a four layer with a cybertool layer in it. Hints/tips would be welcome!
Quote from: gadgetguy35 on March 26, 2010, 03:54:40 PMThat is genius! I just checked out Neils walk through, and I think I will try it on my spartan as soon as my pin stock arrives from Tom in the mail. the mod I am getting back from him has a back spring Phillips that I want to swap for a corkscrew, problem is, the knife is a four layer with a cybertool layer in it. Hints/tips would be welcome!I have to admit the thickest SAK I've done this on was just two layers so I'm not sure how easy four layers would be. A good general tip though is to make sure that you put a long, thin taper on the rod to be tapped into place. It means that the liners and tools don't have to be absolutely perfectly lined up, just very nearly so.
Even with practise mods go wrong This afternoon I thought I was finishing off a four layer 93mm ..... All went well until I checked the scissors layer, no snap I'm actually pretty annoyed as I've had to drill out the pins and pull the whole thing apart again. I know what I did wrong but that isn't making me feel any better right now
I've given in with it for the day before I do something rash with it Its using parts I can't easily replace if I muck it up big style
Quote from: Neil on March 26, 2010, 05:44:57 PMI've given in with it for the day before I do something rash with it Its using parts I can't easily replace if I muck it up big style Garage door job?
Although it is always followed by remorse, there are few things more satisfying (for a second at least) than wanging a non-conforming SAK at the garage door! Usually accompanied by a ritual "chant" that rhymes with clucking bell......
Quote from: DaveK on March 26, 2010, 06:26:32 PMAlthough it is always followed by remorse, there are few things more satisfying (for a second at least) than wanging a non-conforming SAK at the garage door! Usually accompanied by a ritual "chant" that rhymes with clucking bell...... Quote from: Neil on March 26, 2010, 05:35:57 PMEven with practise mods go wrong This afternoon I thought I was finishing off a four layer 93mm ..... All went well until I checked the scissors layer, no snap I'm actually pretty annoyed as I've had to drill out the pins and pull the whole thing apart again. I know what I did wrong but that isn't making me feel any better right now If it's not to soon, can I ask what went wrong? Far easier to learn from others mistakes I find.
Quote from: Gareth on March 26, 2010, 06:41:35 PMQuote from: DaveK on March 26, 2010, 06:26:32 PMAlthough it is always followed by remorse, there are few things more satisfying (for a second at least) than wanging a non-conforming SAK at the garage door! Usually accompanied by a ritual "chant" that rhymes with clucking bell...... Quote from: Neil on March 26, 2010, 05:35:57 PMEven with practise mods go wrong This afternoon I thought I was finishing off a four layer 93mm ..... All went well until I checked the scissors layer, no snap I'm actually pretty annoyed as I've had to drill out the pins and pull the whole thing apart again. I know what I did wrong but that isn't making me feel any better right now If it's not to soon, can I ask what went wrong? Far easier to learn from others mistakes I find. Way too soon <looks at tray of parts and seethes>Oh, OK I finished peening and didn't like the look of the head on the middle pin. The edge had chipped out, functionally fine but ugly. I don't do functional but ugly so decided to replace the pin. As you know you can do this without stripping the knife down but you have to be careful. Anyways, I wasn't careful and slightly bent the new pin going in. I'm just hoping that when I put it together again that I haven't damaged the liners. This would normally be bad but on this occasion it would be very bad as they are all brass
