if you just put the screws in the scale from the outside, they have a tendency to strip very easily. I took a clip from a kershaw whirlwind and put it on a soldier once, it held up for about two weeks of pocket carry and then the screws got loose and started to back out constantly. Don't ruin your scale, either take it apart and do it right or send it to Rotokid and have him do it.
Epoxy will not do it , just not enuff surface area for a bond . Ditto for any other adhesive i can think of . Chris
Quote from: Mercury on April 20, 2010, 02:47:43 AM if you just put the screws in the scale from the outside, they have a tendency to strip very easily. I took a clip from a kershaw whirlwind and put it on a soldier once, it held up for about two weeks of pocket carry and then the screws got loose and started to back out constantly. Don't ruin your scale, either take it apart and do it right or send it to Rotokid and have him do it. So, what's the proper way to do it? Take the scales off, drill and tap the holes the holes, and then...?
Here's a picture of a wooden-scaled 111mm with a clip done by scibeer. It doesn't seem to be using the rivet at all. Surely that ebony is no stronger than AL, right?
my modest idea:1. If you do clip-mod on any of your alox-knife, then you have (only) ONE knife with clip2.And what about small sheath with clip that would be possible to insert inside the pocket?Then you could insert there ANY knife that would hold in your pocket as it would have a clip...(I carry my knife mostly on Belt-sheath, but some people may not like it probably...)
I have this pouch in med my soilder fits in it. Mike
I am so afraid my beloved soldier will fall out of my pocket. I use it more often than my multi so I would be lost.
Quote from: Mercury on May 22, 2010, 03:45:32 AMI am so afraid my beloved soldier will fall out of my pocket. I use it more often than my multi so I would be lost.My second modest idea: A time ago I did not want to have soldier because of missing key-ring, but you know - I had to have Soldier as everybody. And then after time it came to my mind a little strange idea how to attack a piece of rope to Soldier. (Cheap and for-everybody-easy, but not everyone may like it... But I carry a Soldier/Electrician/Ambassador/etc. in this way.)For more information see SOSAKOnline forum - there were after years - renewed discussion how to attach a piece of rope to Soldier (or any knife without key-ring). It was a week ago or so...Originally there is an old topic with name "Soldier - Holder" on SOSAK forum. Search for it.
You wouldn't happen to have a link. I looked for it but could not find it. It sounds like a good read.Mike
FusionBB MessageThere was a problem loading this page:Your permission set does not allow you to be here.Use your browsers Back Button to return to the previous page.
