I guess it could work I am not sure about the JB holding up , you could do a dry run on a bit of scrap metal & see how well the JB Weld bares up under use before making the leap to putting a hole in your Shard.I would think you may need a hole a bit bigger than a 1/4 inch too allow more griping area for the putty
For it too work I reckon you need more blue/JB weld, at the points were there is the least amount of JB is were I reckon you could get crumbling of the hardened JB .I think a little experimenting is needed , see how you go with a 1/4 inch hole on a bit of scrap & take it from there .
what about 6 little holes and some scrollsaw and file work?
Quote from: sardauker on December 05, 2010, 11:26:14 PMwhat about 6 little holes and some scrollsaw and file work?That was the direction my head was going in..... probably still a total PITA!
I think with a small amount of fitting you could use the cap lifter like on the Artifact.(Image removed from quote.)Mike
