The Lansky kit is a good sharpening system and you should get good results with it. What I would do is set up your clamp and get ready to sharpen but first mark your edge with a sharpie first. Then when you start sharpening see where the stones are hitting the bevel. You maybe hitting the shoulder of the bevel and not going all the way to the edge. If you are hitting the shoulder you need to take some metal off and work all the way to the edge. The sharpie mark will help there. Once you work to the edge you need to check to see if you are forming a burr on the other side of the edge. You can feel this with you fingers of look under a bright light to help. Once you have a burr switch sides and do the whole process again on the other side. Once you have formed a burr on both sides alternate strokes very lightly from one side to another to remove it. Do this process for each stone. Once you get to the higher grit stones the burr will be harder to feel for and see so take your time.
it will proberly be down to your technique now im no expert but i get a good edge on my knives and marples chistles my chistles i use a bog standard oil stone for my knives however i bought a fallkniven u1 penknife for a edc and while i was there i got a fallkniven dc4 sharpening stone no oil or anuythin g is needed just use a angle of about 15 degrees and i find that supurb its about 15 quid posted to your door works well for me others have different ideas and techniques.
Quote from: craigy on December 11, 2010, 01:59:35 AMit will proberly be down to your technique now im no expert but i get a good edge on my knives and marples chistles my chistles i use a bog standard oil stone for my knives however i bought a fallkniven u1 penknife for a edc and while i was there i got a fallkniven dc4 sharpening stone no oil or anuythin g is needed just use a angle of about 15 degrees and i find that supurb its about 15 quid posted to your door works well for me others have different ideas and techniques.I was looking at the DC4. I know so little about stones, though, that I don't really understand why this one would be better/worse than others?
Or just get a Spyderco Sharpmaker
WOW! Thanks for all the help everyone! I went ot gun show today and had my user Cadets sharpened by the guy there, but I left one dull spartan to practice on. I'm going to try the burr technique described above using the Lansky in the holes marked "15" and see what results I can get.Is 15 the right hole? I've heard people say both 15 or 20 in the past...I hope I can get better results this time. If not, I guess I'll have to spend some more $ ( says the wife ) to get either a Sharpmaker or some stones, undecided which to get yet.
just found this on youtube dont know if it is ok to post links on here if not mods please deleate.could it be worth getting somthing like this?wicked edge sharpener.http://www.youtube.com/user/clayallison1969?feature=pyv&ad=5468531054&kw=knives#p/u/0/mzL41ygQG0o
My bad.... i meant to say 40 inclusive edge, 30 bevel. Bare with me, my mind has gone to a distant planet the past week, with all the rushing around i'm doing. My apologies. I was just rereading the thread and even confused myself on my post. All other information is correct, just switch the words bevel and edge and the post reads correctly. I've never had an issue sharpening to that degree, sometimes, depending on what i'm using the knife for, i'll make it even steeper like 22 per side, but nothing more. If you need help sharpening, just PM me. Like i said, try a medium grit for maybe 15 or 20 passes on both sides, and see if you get a burr. That will put you on the right track.
One thing to keep in mind when sharping a knife you are sharping from the edge to the back of the blade not from the point to the handle.When you are done sharping with your Lanky sharpener your Smith ceramic sharpener works good for final sharpening. Using light pressure push the blade though from the point to the handle.Mike
Quote from: SuzukiGS750EZ on December 12, 2010, 05:24:34 PMMy bad.... i meant to say 40 inclusive edge, 30 bevel. Bare with me, my mind has gone to a distant planet the past week, with all the rushing around i'm doing. My apologies. I was just rereading the thread and even confused myself on my post. All other information is correct, just switch the words bevel and edge and the post reads correctly. I've never had an issue sharpening to that degree, sometimes, depending on what i'm using the knife for, i'll make it even steeper like 22 per side, but nothing more. If you need help sharpening, just PM me. Like i said, try a medium grit for maybe 15 or 20 passes on both sides, and see if you get a burr. That will put you on the right track.I think I'm confused now So, if I want to keep it simple without the bevel, should I continue to use the 20 hole like I have been?Quote from: Mike 56 on December 12, 2010, 06:05:35 PMOne thing to keep in mind when sharping a knife you are sharping from the edge to the back of the blade not from the point to the handle.When you are done sharping with your Lanky sharpener your Smith ceramic sharpener works good for final sharpening. Using light pressure push the blade though from the point to the handle.MikeMike, do you know what angle the smith's is? If it is a different angle than what I'm using on the Lansky, will that mess up the edge?
Quote from: gustophersmob on December 13, 2010, 01:38:17 AMQuote from: SuzukiGS750EZ on December 12, 2010, 05:24:34 PMMy bad.... i meant to say 40 inclusive edge, 30 bevel. Bare with me, my mind has gone to a distant planet the past week, with all the rushing around i'm doing. My apologies. I was just rereading the thread and even confused myself on my post. All other information is correct, just switch the words bevel and edge and the post reads correctly. I've never had an issue sharpening to that degree, sometimes, depending on what i'm using the knife for, i'll make it even steeper like 22 per side, but nothing more. If you need help sharpening, just PM me. Like i said, try a medium grit for maybe 15 or 20 passes on both sides, and see if you get a burr. That will put you on the right track.Yeah, I'm sure I was using the 20. But I didn't know anythign about a burr. Plus I didn't do that many passes either.I will try again tomorrow night on my Spartan and see what I can do.Thanks again for your help, I appreciate very much I think I'm confused now So, if I want to keep it simple without the bevel, should I continue to use the 20 hole like I have been?Quote from: Mike 56 on December 12, 2010, 06:05:35 PMOne thing to keep in mind when sharping a knife you are sharping from the edge to the back of the blade not from the point to the handle.When you are done sharping with your Lanky sharpener your Smith ceramic sharpener works good for final sharpening. Using light pressure push the blade though from the point to the handle.MikeMike, do you know what angle the smith's is? If it is a different angle than what I'm using on the Lansky, will that mess up the edge?Yes, are you positive you're using a 20* hole? I've had no issue with my SAKs on 20 degrees whatsoever. Use the coarse stone and like i said, do 20 passes each side and feel for a burr. You should feel a burr.
Quote from: SuzukiGS750EZ on December 13, 2010, 01:40:15 AMQuote from: gustophersmob on December 13, 2010, 01:38:17 AMQuote from: SuzukiGS750EZ on December 12, 2010, 05:24:34 PMMy bad.... i meant to say 40 inclusive edge, 30 bevel. Bare with me, my mind has gone to a distant planet the past week, with all the rushing around i'm doing. My apologies. I was just rereading the thread and even confused myself on my post. All other information is correct, just switch the words bevel and edge and the post reads correctly. I've never had an issue sharpening to that degree, sometimes, depending on what i'm using the knife for, i'll make it even steeper like 22 per side, but nothing more. If you need help sharpening, just PM me. Like i said, try a medium grit for maybe 15 or 20 passes on both sides, and see if you get a burr. That will put you on the right track.Yeah, I'm sure I was using the 20. But I didn't know anythign about a burr. Plus I didn't do that many passes either.I will try again tomorrow night on my Spartan and see what I can do.Thanks again for your help, I appreciate very much I think I'm confused now So, if I want to keep it simple without the bevel, should I continue to use the 20 hole like I have been?Quote from: Mike 56 on December 12, 2010, 06:05:35 PMOne thing to keep in mind when sharping a knife you are sharping from the edge to the back of the blade not from the point to the handle.When you are done sharping with your Lanky sharpener your Smith ceramic sharpener works good for final sharpening. Using light pressure push the blade though from the point to the handle.MikeMike, do you know what angle the smith's is? If it is a different angle than what I'm using on the Lansky, will that mess up the edge?Yes, are you positive you're using a 20* hole? I've had no issue with my SAKs on 20 degrees whatsoever. Use the coarse stone and like i said, do 20 passes each side and feel for a burr. You should feel a burr.Yes. Use the 20. The bevel will always be there. Knocking the shoulder off as someone said is taking the primary bevel down to a thinner angle. Which would make it less resistant when cutting, but less bevel means less strength behind your edge unless you convex your edge. But lets not get into that. 20 should work, work the edge until you get a burr. Reread what i wrote about detecting a burr. You should be fine, reread what ive said good luck, report back!
Well, how did it go?
