leatherman kick disassembly
Offline jay_imok
on: November 12, 2007, 03:36:35 AM
is it a black art to disassemble a leatherman tool with knurled nuts? is there a special tool, or do i just grab 2 pair of pliers and commence twisting? there is no provision for a screwdriver, torx/ phillips/ allen/ or otherwise.
thanks
Offline Anthony
  • Improvise.
Re: leatherman kick disassembly
Reply #1 on: November 12, 2007, 04:03:22 AM
Do a search in this forum for posts started by Spoonrobot...he took one apart and went through all the details...he used two pairs of locking pliers if I remember correctly.
He took a Kick and a Blast apart and filled the Kick handles with as many tools as he could fit..so he basically made a Blast in a Kicks body! :D
Reply #2 on: November 12, 2007, 04:07:01 AM
Here's the thread Corrugated was referring to: http://forum.multitool.org/index.php/topic,1509.0.html
In it, Spoonrobot says he used a Leatherman Crunch on one end of the screw and a vise-grip plier on the other.
Reply #3 on: November 12, 2007, 04:22:11 AM
Be real careful though if you try it. It's easy to have the pliers slip and booger up the knurled screw heads.
Also be warned, Leatherman uses Lock-tite on the threads to discourage disassembly. We've been told that heating up the screw head (with a soldering iron for instance) will soften the lock-tite. Haven't tried that trick yet myself.  :-\
Reply #4 on: November 13, 2007, 03:02:07 AM
thanks
Hey Jay, weren't you planning on buying a pocket clip for your Kick anyhow? Here's an idea; how about you buy two.
I just realized that Leatherman puts serrations around the inside of the hole on the pocket clip. They match up perfectly with the 6mm knurled heads on the Kick. Not accidentally of course; the clip hole serrations are intended to minimize the amount of 'wiggle' in the clip when installed.
So here's the great part: Buy two clips, then use them as wrenches to disassemble your Kick like you want to! No boogered screw heads!
* clip wrench 1.jpg (Filesize: 51.45 KB)
* clip wrench 2.jpg (Filesize: 53.39 KB)
Offline Leatherman123
Reply #5 on: November 13, 2007, 03:15:27 AM
WOW! That is a really great idea!
B
Offline jay_imok
Reply #6 on: November 13, 2007, 11:22:49 AM
thanks all - this information will keep me busy for awhile!
Offline supratentorial
Reply #7 on: November 17, 2007, 05:32:41 PM
...I just realized that Leatherman puts serrations around the inside of the hole on the pocket clip. They match up perfectly with the 6mm knurled heads on the Kick. Not accidentally of course; the clip hole serrations are intended to minimize the amount of 'wiggle' in the clip when installed.
Nice!   :multi:
Offline Anthony
  • Improvise.
Reply #8 on: November 17, 2007, 06:12:54 PM
Can two Kick pocket clips also dissassemble other Leatherman tools with those bolts, or are the Kick bolts a diffrent size than other tools?
Reply #9 on: November 17, 2007, 06:19:02 PM
Yes, I tried on my ST 200 and it worked fine!
B
us Offline WhichDawg
Reply #10 on: November 25, 2007, 11:38:59 AM
great thread, I will be using these technics/tricks in the near future! ty for sharing.
Reply #11 on: November 27, 2007, 02:54:48 AM
Sorry Corrugated, somehow I missed this question earlier:
The Kick pocket clip 'wrenches' will fit all the screws on a PST, PST II, Flair, Crunch, Pulse, and Mini-Tool.
They will also fit the blade-end screws on a SuperTool, SuperTool 200, Blast, Fuse, Kick, Core, Charge AL, and Charge ALX.
Hope this helps (better late than never, right?)  :P
Offline Anthony
  • Improvise.
Reply #12 on: November 27, 2007, 02:58:02 AM
I'm torn between getting two pocket clips taking my Kick and Blast apart, or just sell/trade them away :P
Reply #13 on: November 27, 2007, 03:01:17 AM
if you do take em apart Cman, and still don't want them, let me know (with them all apart!) maybe we could work out something :)
Reply #14 on: November 27, 2007, 03:01:47 AM
Eeek! Why would you want to get rid of them?
Offline Anthony
  • Improvise.
Reply #15 on: November 27, 2007, 04:42:04 AM
Not really "get rid" of them...but I'll never carry them as long as I have a Powerlock/Wave/Crunch :multi:
Reply #16 on: November 27, 2007, 04:46:50 AM
mmmm cargo pants!
Total Receipts: $84.35
PayPal Fees: $5.00
Net Balance: $79.35
Below Goal: $220.65
26%
