LED Lenser "key-chain" flashlight
Offline pointless_noise
on: November 24, 2011, 09:45:47 AM
hey, I'm looking at getting an LED Lenser to replace my damaged maglite solitaire
just wondering what are peoples feelings of the K3 vs the P3 I can't make my mind up
K3, smaller, lighter
P3, takes a single AAA battery which I carry spares of most days already
any other pro or cons to each model I need something hardwaring  ???
cheers
Re: LED Lenser "key-chain" flashlight
Reply #1 on: November 24, 2011, 10:34:12 AM
I've never had any Led Lenser, but can recommend a Fenix E01 as it's a superb keychain light :tu:
gb Offline Millhouse
Reply #2 on: November 24, 2011, 10:39:12 AM
Between the 2, the P3. Much more convenient battery type.
As an alternative to the LED Lensers, you may want to take a look at:
Fenix E01
Nitecore T0
and for something with a lot more power, ITP A3.
Reply #3 on: November 24, 2011, 11:08:53 AM
If you want a 5mm led, go with the Fenix E01, much better and cheaper than those two you listed. The itp a3 is a much brighter 3 mode light, and in the price range of the two you listed. It's been discontinued a month or two ago but there are a lot of them out there. There is also a newer model of the itp a3 out, olight i3 with a sturdy pocketclip. You can't go wrong with any of the 3.
us Offline Sazabi
Reply #4 on: November 25, 2011, 01:50:49 AM
I'm curious, is the Maratac AAA also going to be using the upgraded i3 driver settings, or if it's going to stay at the old a3 levels, that may be a workaround for the a3 being discontinued.  I've not checked it out, though.
Re: Re: LED Lenser "key-chain" flashlight
Reply #5 on: November 25, 2011, 02:41:07 AM
There were four different itp a3, I have/had the last 3. There was the original one mode one, the xp-e q5 with mid-low-high, the xp-e q5 (I think, I lost that one so I can't check) with low-mid-high and the last SS one with an xp-g r5 and a low-mid-high sequence. The i3 continued to use the last version of the itp SS and Maratac uses the second one. Most vendors never changed the text during these changes so I was very pleasantly surprised when I got my last SS one.
« Last Edit: November 25, 2011, 02:43:26 AM by enki_ck »
us Offline Sazabi
Reply #6 on: November 25, 2011, 02:46:04 AM
Hmm, I didn't know that. :)  I wonder if the Maratac AAA will be upgraded to this latest model, unless Olight has that many leftover drivers of the second version (to be fair, I think I'd have preferred the third version better, with it starting out on low...).
Reply #7 on: November 25, 2011, 12:46:29 PM
fenix E01 it is
cheers everyone for pointing it out
