Syph007 · 6035 · 1299248
Reply #2460 on: March 22, 2015, 11:40:28 PM
I see. Well, I'm sure someone will. I almost did :)
au Offline TazzieRob
Reply #2461 on: March 23, 2015, 12:33:58 AM
I said I wouldnt ever bother with home anodizing, but Ive been browsing the caswell site and they do have a starter kit that I wouldnt mind trying.
Thats not for hard anodize, but I can do standard anodize and use colors not available to hard anodize like bright orange and OD green which would be popular I think.  As well as I can do one off scales of different colors and not have to commit 10-12 sets for a color based on cost.
Ive also been doing some research on hard anodizing and kinda want to figure out the difference and how it's done.  Seems to be sort of secret per shop, but I have some ideas and it would be fun to use my chemistry degree for something.  :D
OD green anodize with black tools would be very nice I think.  Did Vic ever release an OD green special run?
Hard ano requires higher voltage and cooling devices.
Thats what I figured, but since the amount of current needed depends on the surface area of the part, and sak scales are small compared to some things that get hard ano'd.. how much current would it take to anodize one set at a time?  Thats what im thinking... and I have no idea.   I know you have to bubble air through the sulfuric ( or maybe pure O2, not sure ) but Id like to figure it out.
If you know what the surface area of the piece is, you can work out how much current is required due to the required current density.  If your power supply can deliver constant current, the voltage will rise as the resistance rises with increased oxide thickness.  A smaller piece will require less current and voltage to achieve the required current density.  I don't know what they should be, but there must be some info available out there.  This article popped up in a quick google search
http://www.luster-on.com/AnodizingbyConstantCurrentDensity_001.pdf
ca Offline Syph007
  • SAK Surgeon
Reply #2462 on: March 23, 2015, 01:49:12 AM
Thanks for the info!  Yes I do remember the 720 rule and I have a power supply that can do constant current.  If I could get a 1mil thick coating on home anodize Id be pretty happy with that actually as stock anodize is thinner than that.
I had another realization as well with home anodize I can do some more fiddling around with masking and preserve the red of the shield I think which would be cool.
So I think I talked myself into ordering the starter kit tomorrow and see what I can figure out.  :D
OD green would be wonderful.... I like the OD green cerakote but I think id still prefer anodize.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #2463 on: March 23, 2015, 02:29:26 AM
If you have 3D CAD drawings of the parts you should be able to get pretty accurate surface area values.  Good luck with it, I'm interested to see what results you obtain  :cheers:
ca Offline Syph007
  • SAK Surgeon
Reply #2464 on: March 23, 2015, 02:53:35 AM
And its gone... seems people DO like 91mm alox.  I just ordered another 20 sets to be milled, and if I go ahead and get that anodize setup I can do OD green ones as well as black for the next batch...  :D
ca Offline Syph007
  • SAK Surgeon
Reply #2465 on: March 24, 2015, 12:26:09 AM
I did some reading on anodize theory, its really facinating.  The alum oxide grows perpendicular from the surface like little hairs from the surface.  The spacing of those 'hairs' its what determines the hardness (not layer thickness as I had thought).  Now.. the higher the current density the smaller the pore size (space between the hairs) and the harder it is to dye which is why hard anodize has less dye options as only some dyes are small enough to fit in the smaller pores!
Similarly if the current density is too low, the 'hairs' are too far apart and the dye wont be trapped, and color will leak back out even if sealed.
So!  This is right up my alley for careful controlled experimentation and taking notes it will be like being back in the lab, but making cool parts too...
And now that I found blue masking lacquer, I can mask off the shields and then dye the scales any color!  :D :D :D
« Last Edit: March 24, 2015, 12:28:14 AM by Syph007 »
Offline Glofindel
Reply #2466 on: March 24, 2015, 08:49:29 AM
Sounds awesome. The explanation of growing like hair gives me a goosebumps.
ca Offline Syph007
  • SAK Surgeon
Reply #2467 on: March 24, 2015, 07:59:42 PM
More 91mm grenade texture alox! :D  Compact toolset with brass liner.
Cheers!
us Offline sf_duke
Reply #2468 on: March 24, 2015, 09:08:06 PM
Nice mod Syph....the brass liner looks sharp...
Reply #2469 on: March 24, 2015, 09:27:01 PM
Beautiful. Now all it needs is a mini screwdriver (in brass instead of plastic) 8)
ca Offline Syph007
  • SAK Surgeon
Reply #2470 on: March 24, 2015, 09:42:37 PM
That would be cool.  I think that would be tricky to do by hand though.  :D
us Offline neillcurrie
  • Wanted: SpydeWrench
Reply #2471 on: March 24, 2015, 10:16:15 PM
I suspect you could make the brass screwed part, and solidly insert the screwdriver blade somehow (maybe a tight press fit would be sufficient, as the torque on the blade is very miniscule). But you'd have more of a problem tuning the fit of the whole screwdriver into the corkscrew.
Brass doesn't have the "give" that plastic offers, the fit would need to be especially precise, and maybe a tight cork or two would ruin the fit again  :( :(
us Offline Monrogue
  • Wooooo!
Reply #2472 on: March 24, 2015, 10:39:07 PM
Looks great Syph!
K-Tibbs
Reply #2473 on: March 24, 2015, 10:39:30 PM
Oh come on, if anyone can do it... ;)
Reply #2474 on: March 24, 2015, 10:43:55 PM
I don't think a tight fit is necessary. A little play would be fine, it can't fall out anyways. I remember seeing a metal one posted here on MTo some time ago.
I'll ask a friend of mine who just upgraded his 3D printer to a very sophisticated model. Maybe he can print one in a cool material/color.
ca Offline Syph007
  • SAK Surgeon
Reply #2475 on: March 24, 2015, 10:53:43 PM
That would be a good candidate cor printing.
As a challange to do by hand i would start with square bar stock and mark each side and use a jewelers saw to cut but sanding the inside part would take a long time.
ca Offline Syph007
  • SAK Surgeon
Reply #2476 on: March 25, 2015, 09:35:17 PM
I guess this one would be a yeoman tinker... hmm ya that sounds about right.  Just for conversation sake of the 7 91mm alox/Ti customs only one had the corkscrew so far, but whenever there is a poll people choose the corkscrew about 9 to 1.   :think:
Reply #2477 on: March 25, 2015, 09:48:13 PM
Unusual choice, two Phillips drivers :think:
I feel so special now, with the only corkscrew-equipped SAK ;)
Reply #2478 on: March 25, 2015, 09:52:40 PM
I realized this week that I don't have a single Vic SAK with a backlayered Phillips. :o And only two Wengers with that feature.
ca Offline Syph007
  • SAK Surgeon
Reply #2479 on: March 25, 2015, 09:57:35 PM
The custom 111mm Im putting together has 3 phillips! :D
ca Offline Syph007
  • SAK Surgeon
Reply #2480 on: March 25, 2015, 09:58:51 PM
Its not that its my preference for use, but I like the feel of the SAK better without the corkscrew.  To be honest I dont use either ever, but since it has to be there, I pick phillips.
« Last Edit: March 25, 2015, 10:00:16 PM by Syph007 »
us Offline sf_duke
Reply #2481 on: March 25, 2015, 10:11:34 PM
Sweet!!!  Nice work Syph.  Kirk13 on another thread coined this version the "Duke of Yeoman", but I like the "Yeoman Tinker" equally.
Funny you mentioned this.  I have only seen the two Phillips implements (inline and backtool) on Wengers and not on a Vic.  The Wenger Matterhorn is a good example of this.
Reply #2482 on: March 25, 2015, 10:14:33 PM
http://sakwiki.com/tiki-index.php?page=Master+Electrician :salute:
ca Offline Syph007
  • SAK Surgeon
Reply #2484 on: March 25, 2015, 10:45:26 PM
I was asked how my custom alox scales compared in thickness to normal scales.
Here is my super tinker vs a farmer.
And here is a standard super tinker compared to my alox super tinker.
us Offline sf_duke
Reply #2485 on: March 25, 2015, 10:58:29 PM
Thanks for posting the pics Syph.  Great to see the comparisons.
ca Offline Syph007
  • SAK Surgeon
Reply #2486 on: March 26, 2015, 05:40:10 PM
This would be the biggest 91mm alox Ive done so far with the new scales.  A troubleshooter!  This one is going to the man who did the 3D CAD file work... Tofty!
us Offline Monrogue
  • Wooooo!
Reply #2487 on: March 26, 2015, 05:50:07 PM
That's similar to my MechaRogue ;). Very nice.  Love that black/red theme.  So you haven't done any with T&T yet?
K-Tibbs
ca Offline Syph007
  • SAK Surgeon
Reply #2488 on: March 26, 2015, 06:11:48 PM
Nope I would have had to make the slots before anodize.  If I end up doing home anodize then I can do that better instead of guessing ahead of time.  So far Ive only done the tweezer on a Ti91.
Oh and now its been 8, 91mm mods and still only 1 corkscrew.... where is the love of the corkscrew eh! :D
us Offline tattoosteve99
Reply #2489 on: March 26, 2015, 07:10:34 PM
This is one of the first mods I was planning long ago. I'm so glad you got this working.
